Tacoma Loose Bed design Flaw explanation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Milowilli, Aug 27, 2015.
  1. Jul 19, 2018 at 1:34 PM
    #121
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Those look like really slick washers. Does 1/4" have any visual impact to the body lines matching between the cab and box? Even if so I bet they'd work fine as a small body lift under the cab, too.
    EDDO[QUOTED] likes this.
  2. Jul 19, 2018 at 1:37 PM
    #122
    DaveInDenver
    David
    Grand Junction
    Unexceptional
  3. Jul 19, 2018 at 1:44 PM
    #123
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Just surfing around McMaster, these look interesting.
    https://www.mcmaster.com/#polyurethane-washers/=1ds9uog
    They are polyurethane cushioning washers, durometer of 40A, so not very firm, maybe a bit less than an Energy Bushing body mount. They also have spring bushing that are 95A, which would be firm.
  4. Jul 19, 2018 at 1:44 PM
    #124
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    No noticeable difference in how the bed sits. As far as the cab goes, I wouldn’t suggest that. I replaced my OEM cab mounts with poly bushings.
    DaveInDenver[QUOTED] likes this.
  5. Jul 19, 2018 at 2:28 PM
    #125
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    I removed the passenger front bolt (where the thump was coming from) and just loosened the other 5. Used a pry-bar between the frame and the bed to lift it enough to get the washer in there. In order to make sure that the metal mount sleeve goes through the large hole in the washer, find the lightest person you can (with at least one good eye) to look down the hole while you position the washer. When they tell you it has disappeared, drop the bed. Re-torque bolts and call it good.
    llamasmurf and Stryker420 like this.
  6. Jul 19, 2018 at 2:57 PM
    #126
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    My process was basically this with the exception that (if memory serves) I used something like a big screwdriver or socket extension as a centering tool to position the washer before dropping the bed since I was working alone.
  7. Jul 20, 2018 at 9:53 AM
    #127
    Stryker420
    Stryker420 Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    So which one did you go with?
  8. Jul 20, 2018 at 10:46 AM
    #128
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Would this possibly explain the loud bang I get going over speed bumps sometimes???
    Stryker420 and Sidney Vicious like this.
  9. Jul 20, 2018 at 10:55 AM
    #129
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    A delrin washer would work too. Easy to find, east to drill/machine to the right size!
    I actually did a body lift with homemade delrin washers and have had no issues in 5 years. The delrin is soft enough to prevent this, and I lifted the cab to match.
    AndreasMaximus likes this.
  10. Jul 20, 2018 at 9:24 PM
    #130
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    Yup, mine sounded like a toolbox was thumping into the box of the truck on bumps.asy way to tell is if the bed bolts are sticking up proud of the box.
  11. Jan 3, 2019 at 8:02 PM
    #131
    SuperWhite05
    SuperWhite05 Well-Known Member
    Stephen
    Mississippi
    '14 Super White TRD Off-Road 4x4
    255/80/17 Cooper ST/Maxx 885 OME Coils 5100 Billies Ironman Replacement Leaf Pack Wet Okole Seat Covers Pop n' Lock Tailgate Lock csjumper Map, dome, DTRLs, and license plate LED's Flyzeye V2W-1215 and 3VP-RS LED's Colormatched Door handles, side mirrors w/ turn signals, and grille 17x8.5 Matte Dark Bronze Stealth Custom Series Wheels Shorty Antenna Differential Breather Rear Fox 2.0 Shocks Adam's Polishes Products Black WeatherTechs Front and Rear Redline Hood Struts Pioneer AVH-4100NEX Bestop Supertop
    @RadRed06 you ever notice this on washboard roads?
  12. Jan 6, 2019 at 6:51 PM
    #132
    TRDProBuddy
    TRDProBuddy Well-Known Member
    MD (Kent Island)
    2015 TRD Pro (Inferno)
    Do happen to know the outside diameter of the shaft by chance?
  13. Jan 6, 2019 at 7:27 PM
    #133
    Newfiebruh
    Newfiebruh Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    Has anyone had their bedsides come loose? one side has an extreme amount of freeplay (basically can blow in the wind). I've noticed some small plastic plugs are missing, but surly theres something more that holds it in place? I haven't had a chance to check because we just got dumped on with 2 feet of snow and its quite unpleasent out lol
  14. Jan 6, 2019 at 8:01 PM
    #134
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    If you are asking about the metal sleeve in the mount, it is approximately 1".
  15. Jan 6, 2019 at 8:02 PM
    #135
    TRDProBuddy
    MD (Kent Island)
    EDDO likes this.
  16. Feb 10, 2019 at 4:03 PM
    #136
    s.e.charles
    s.e.charles Well-Known Member
    I thought that when I looked at the pictures. and someone mentioned spraying w/ WD40. if there's rubber in the connection assembly, I would use silicone or Boshield.
  17. Feb 10, 2019 at 5:07 PM
    #137
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    You are spraying the exposed threads under the bed. Over time road grime gums up the threads. Guys are spraying them to clean the threads out before removing the bolts. If you don’t your forcing all the gunk through the threads making your job harder and possibly stripping something.
    GilbertOz and DaveInDenver like this.
  18. Feb 10, 2019 at 6:02 PM
    #138
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    That's correct but he was referring to something I said earlier trying to diagnose it.
    And to that point he would be correct, WD40 probably wouldn't be the proper lubricant since it would break down rubber over time. Not sure if it's any worse than road salt and grime, so the actual material used in body mounts is probably pretty impervious to a lot of solvents. But still it is probably safer to use silicone or Boeshield.
    In my case it didn't and couldn't solve the fundamental problem anyway, so it was something I only did the one time.
  19. Mar 19, 2019 at 8:50 PM
    #139
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    This used to happen on my 2nd gen quite a bit. Frame flex from trails is partly the cause. I fixed the problem by removing each bolt to clean and applying Red Lock-Tite to each bolt. I also torqued each bed bolt to 66.5 ft. lbs.
    mikalcarbine likes this.
  20. May 28, 2019 at 3:04 PM
    #140
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    So is this a problem only if you have a shell or rack? Or is it a problem with all 2nd gen tacoma? I am asking because just befor I installed my shell I checked all the bed bolts and they were all tite. I just checked aftering reading this thread and all 6 bolts were loose after having the shell for 2 1/2 years. Also if you keep the bolts torqued to specs will that help?
