Tacoma loses power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by M.v, Sep 23, 2024.
  1. Sep 23, 2024 at 5:02 PM
    M.v
    M.v [OP] Member
    M.v
    2005 grey Toyota Tacoma PreRunner 2WD 4.0L
    Hello, I have my 2005 Toyota Tacoma it’s been loosing power and it would only start if the check engine light was on. Most of the time it won’t start, I have to wait for hours so it can turn on. But the dash board doesn’t show the it overheating. Does someone know the problem?
  2. Sep 23, 2024 at 5:15 PM
    545 Well-Known Member
    2015 Access Cab
    You have not given enough info to even start troubleshooting
    Can you read the codes?
    What’s the history of the vehicle?
  3. Sep 23, 2024 at 5:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you mean when you turn the ignition key to the ON Position without going all the way to the START Position and the "Check Engine Light" is not on, it certainly will not start as that means that the ECU is not communicating. So you wait until the "Check Engine Light" comes on and then it will start.
    Is that what you mean?
    If it is losing electrical power. Have you checked the battery terminals on the battery to make sure they are clean and tight?
    TnShooter likes this.
  4. Sep 23, 2024 at 5:55 PM
    M.v
    M.v [OP] Member
    M.v
    @Jimmyh yes, exactly on the on position, I have to wait till the check engine shows up so it can turns on. sorry for the confusion. Yes the battery terminal is clean and tight, just bought the battery too.
  5. Sep 23, 2024 at 6:10 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Easiest first thing you can try is swap the EFI relay with a known good relay (horn relay should be the same) and see if that cures it, if not then we have some testing to do.
    M.v[QUOTED][OP] and Jimmyh like this.
  6. Sep 23, 2024 at 6:21 PM
    M.v
    M.v [OP] Member
    M.v
    @Dm93 okey, thank you I’ll try that I’ll let you know if it works.
    Dm93 likes this.
  7. Sep 23, 2024 at 6:44 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    :fingerscrossed:, we have seen a few bad EFI relays so hopefully that's it.
  8. Sep 24, 2024 at 10:21 PM
    M.v
    M.v [OP] Member
    M.v
    @Dm93 I changed the efi and the horn, but now When the switch is on the on position the gauge's start to glitch. it would still do the same problem but not as often.
  9. Sep 25, 2024 at 5:11 AM
    Knudsen
    Knudsen Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
    Do what @Dm93 says, but here’s my guess:
    maybe some corrosion on the relay or socket. I would inspect both (good light and magnification). Note any discoloration and describe it here. Then I’d reseat the relay 4 or 5 times.
    I doubt the relays are inexpensive, but if they are, maybe replace it. If that doesn’t help, you have a spare.
    You might be better off waiting until dm93 replies.
  10. Sep 25, 2024 at 8:01 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Did you notice any corrosion in the box when you were messing with the relays?
  11. Sep 25, 2024 at 9:23 AM
    M.v
    M.v [OP] Member
    M.v
    no, but I did notice that the old fuse that the efi had was hot. And there were fuses not on the correct place. I changed them in the right place and now my radio ain’t working. Jaja
  12. Sep 25, 2024 at 9:49 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Are you sure about fuses being in the wrong places? Maybe you weren't looking at the diagram right.
  13. Sep 29, 2024 at 11:03 AM
    M.v
    M.v [OP] Member
    M.v
    Okey I fixed the fuses and put them the correct position but it’s still having the same problem.
  14. Oct 1, 2024 at 8:46 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So when the truck is broken (no CEL with the key on) check at the EFI Relay terminals as shown and see what's missing
    At the EFI relay, key on.
    Pins 1 and 5 should have power and pins 2 and 3 should be ground.
    Test light to battery negative and pin 1
    Test light to battery positive and pin 2
    Test light to battery positive and pin 3
    Test light to battery negative and pin 5
    Jimmyh likes this.
