Tacoma loud bang passenger side only over speed bump.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12tackoma, Aug 30, 2016.
  1. Aug 30, 2016 at 9:18 PM
    12tackoma
    12tackoma [OP] Member
    2012 Tacoma trd
    Total Chaos Uca Bilstein 6112 with toytec top mounts at 3" 285 70 17 duratracs
    2012 TRD OR Bilstein 6112 toytec top mount 3" lift Total chaos UCA 40k miles. Aligned correctly.
    After installing the lift there is a loud bang on the front passenger side when going over speed bumps. It rides smooth when hitting the bump only on the drivers side. I have taken it to two shops and reinstalled the front suspension literally 5 times. Still cannot figure it out.
  2. Aug 31, 2016 at 12:41 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    All I can think of is the shock is bottoming out.
    Fenwick1993 and ManBeast like this.
  3. Aug 31, 2016 at 10:48 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    x2.
  4. Aug 31, 2016 at 10:49 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    x3
    Fenwick1993 likes this.
  5. Aug 31, 2016 at 10:52 AM
    gnorv
    gnorv Member
    You can put a zip tie on the shaft to see how far the shock is getting compressed.
  6. Aug 31, 2016 at 10:56 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It is the extension that is the problem, not the compression.
  7. Aug 31, 2016 at 11:18 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I will add that the 6112 body shocks are designed for 2" of lift in the Baja/Pro trucks. You are running them on 3" lift, still doable. The Total Chaos UCAs will give an extra +1" droop, making it similar to a 4" lift at max droop, pushing the limits. Your driver side likely barely misses topping out due to the slight driver side lean, while your passenger side is just past that limit and makes contact. The back side of the speed bump drops away quickly and allows the suspension to rapidly extend before the full weight of the truck is on it.
    Jimmyh and TacomaArto like this.
  8. Aug 31, 2016 at 11:24 AM
    UoD
    UoD Well-Known Member
    Charleston, SC
    2015 Tacoma TRD Sport DCSB 4x4
    N-Fab 3" Main Tube Textured Nerf Bars (T0580CC-TX), Toyota OEM Bed Extender, Swapped Entune Plus for Entune w/ Nav, Undercover SE Tonneau, TRD Pro wheels, Falken Wildpeak AT3W's (265/70/17)
    I don't have a lift. Completely stock 2015 TRD Sport. I too get a very loud bang coming from my passenger side when hitting a bump at speed. It almost sounds as if someone toss a large rock at the side of the truck. It doesn't happen when I go over a speed bump though. It's only if I hit something like train tracks or a small pot hole when traveling at a moderate rate of speed.
  9. Aug 31, 2016 at 11:25 AM
    T4RFTMFW
    Same issue. It isn't applicable only to lifted suspensions.
  10. Aug 31, 2016 at 11:26 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    x4.
  11. Aug 31, 2016 at 1:56 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    that's what she said... :eek:
  12. Aug 31, 2016 at 3:41 PM
    devkurf
    devkurf Member at Large
    midwest
    It may be one of the bed bolts has backed out. Go out and lift up on each corner of the bed to see if there is any play. My money is on the passenger side front bolt being loose. If I get time, I'll dig up the thread where it was discussed.
  13. Aug 31, 2016 at 3:44 PM
    devkurf
    midwest
