Tacoma outselling Ranger 2:1
Discussion in 'General Automotive' started by WVTacoma08, Jul 12, 2020.
  1. Jul 16, 2020 at 6:45 AM
    #181
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Our 3.5s are complicated and so is the 5.0, minus the turbo they're really no different. It's not like they're some old carb pushrod V8. The 2.7 and 3.5 ecoboost are solid reliable engines. Early 3.5s did have some issues with timing chains stretching. Which is bullshit but Ford got it mostly worked out and that had nothing to do with them being boosted. As of late both Ecoboost variants are more reliable than the 5.0...
    Hopefully the Tacoma will get a small boosted V6 in the next refresh. Pretty clear the Ranger will when it changes over to the Bronco chassis. That's really my only knock on my truck is the power. And small turbo 6 would 100% fix that.
    jetfishn likes this.
  2. Jul 16, 2020 at 6:45 AM
    #182
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I never said that Ford "will" put it in the next Ranger, I simply pointed out that it's possibile since they are sharing the platform.
  3. Jul 16, 2020 at 8:33 AM
    #183
    ChuckTownRC51
    ChuckTownRC51 Well-Known Member
    Mark
    2016 TRD Off Road 4x4 Double Cab
    None, yet
    That's a good looking truck. And I'm pretty sure the moon roof is standard on the pro, which is why it wouldn't be an option.
  4. Jul 16, 2020 at 8:44 AM
    #184
    ChuckTownRC51
    Mark
    None, yet
    A motor with turbo + GDI (with intermittent port injection) + VVT is way more complicated than the 3.5 Toyota and a Coyote engine that has proven reliable for a decade now. Besides the engine having a lot of complications there's also the internal pressures that these engines have to deal with. The combustion pressure inside an Ecoboost engine is incredibly higher than what you'll find on a naturally aspirated engine with port injection. I don't have the numbers in front of me right now but I've seen them before and it's a pretty crazy difference. The higher the pressure = the lower long term reliability. It's all a matter of personal opinion and preference but I'll stay away from it. I haven't bought a Ford product since my F150 cracked an engine block towing a 3k pound trailer cross country.
  5. Jul 16, 2020 at 9:17 AM
    #185
    mchertel
    mchertel Well-Known Member
    Mark
    Colorado Springs CO
    2020 Tacoma Off-road
    Toytec 2 inch boss lift
    Thanks. Ya it must come with a moon roof. Not sure where I heard that. Not sure why it wouldn’t either.
    ChuckTownRC51[QUOTED] likes this.
  6. Jul 16, 2020 at 9:41 AM
    #186
    jetfishn
    jetfishn Well-Known Member
    One engine by Ford to stay away from now is the coyote 5.0L V8 Ford engineers have managed to screw it up royally, between 2018-20 these engines in the F150's have been exhibiting heavy oil usage. The fixes have been less than stellar, reprogramming pvc, and second adding a longer dipstick, which only hides the oil usage. The only difference between tried and true 2017 and back 5.0L engines is they added a new type block in 2018, plasma weld cylinder bores, you can draw your own conclusions there. There are plenty of videos on youtube about this defect in the 5.0L.
  7. Jul 16, 2020 at 10:11 AM
    #187
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    dAMN!!! truck looks great man
    mchertel[QUOTED] likes this.
  8. Jul 16, 2020 at 10:49 AM
    #188
    RX1cobra
    19 OR
    Our 3.5 and the Coyote both run direct, port injection and VVT. Again, the difference is only the turbo on the ecoboost. A turbo doesn't make it way more complicated.
    Of course a turbo engine (when in boost) will have higher cylinder pressures than an N/A (type of fuel injection has no impact here). What makes you think higher cylinder pressure means the engine is less reliable if it was designed for that higher pressure from the get go?
    Our engines have a much higher compression ratio than Toyotas of old so we run higher cylinder pressures too. Does that make ours less reliable? The 4 cylinder Tacomas have more load on them than the V6 so are they also less reliable because of that?
  9. Jul 16, 2020 at 11:14 AM
    #189
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    I have an extended cab 1999, tons of space. Gonna swap from a 99 Explorer.
    shakerhood likes this.
  10. Jul 16, 2020 at 11:46 AM
    #190
    ChuckTownRC51
    Mark
    None, yet
    Oh, you're one of those people that just like to argue on the internet. I'm pretty sure it's a universal truth that gas engines subject to higher combustion pressures are less reliable over time than those with lower pressures. If you want to argue that I suggest you find someone else. Have a good one.
    RX1cobra[QUOTED] likes this.
  11. Jul 16, 2020 at 2:30 PM
    #191
    willconltd
    willconltd Well-Known Member
    Orlando, Florida
    I went with the eddie bower edition. Seats, center console, plus the overhead console. Even got the compass and outside temp working. Don't forget the temp sensor if you are going all out!
    photogr4x4[QUOTED] likes this.
  12. Jul 16, 2020 at 2:56 PM
    #192
    CDNTacoma2019
    CDNTacoma2019 Well-Known Member
    Ontario, Canada
    2019 SR5 DCLB 4x4
    I wish the TRD Pro didnt didnt have a moonroof.....dont want one. Also wish fewer had the ugly snorkle.
  13. Jul 16, 2020 at 3:00 PM
    #193
    CDNTacoma2019
    Ontario, Canada
    2019 SR5 DCLB 4x4
    That was the only decent engine Ford had left. I am thankful I have a Toyota.....neighbor has a 2010ish F150 and the body is rusting away in the back....out in the driveway every few weeks working on it to keep it running. Worthless garbage.
    jetfishn[QUOTED] likes this.
  14. Jul 16, 2020 at 3:48 PM
    #194
    mchertel
    Mark
    Colorado Springs CO
    I like the moon roof but would want a snorkel. I don’t mind not having the hood scoop either. It’s just more height to look over on the trails.
  15. Jul 18, 2020 at 7:12 AM
    #195
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    I first ran across the 5.0 issues when I was checking out the new Mustangs. They run insanely high compression, like 12:1. They squeeze a TON of power out of them, 460 horse stock, which is really awesome. But like you say, there are lots of issues that make me question how long this engine will last (which is probably just until the warranty expires)
    Have you heard about the BBQ tick? Some of these 5.0s will start bottom end ticking after the first oil change. It's excessive play in the main bearings and the rod caps. There are you tube videos of people fixing this by doing a bottom end bearing job. Eventually the bottom end will drop out pre maturely.
    This has been happening for years and Ford has a TSB saying it's normal. It happens on trucks and Mustangs about equally.
    Way to go Ford, screw up the last V8 you'll probably make. Gotta stay away, even though I want one bad.
  16. Jul 18, 2020 at 12:07 PM
    #196
    jetfishn
    I ran across the excessive oil burning in the 5.0L 2018-20's when researching new trucks. Couldn't believe how many had the issue and felt sorry for them as this was a brand new truck to most of them.
  17. Jul 18, 2020 at 1:29 PM
    #197
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    That engine has been around for quite a while, so how in the heck did Ford screw it up? Acura did the same with the K24 the first year of the 2nd generation TSX (2009). Honda put that engine in everything from Accords, to TSXs, to Elements, CRVs, etc., and for some reason they started having oil burning issues in 2009? WTF Honda?????
    I think they fixed it in 2010, but that doesn't explain how a (K-series) engine that has been around for over a decade has oil consumption issues.
  18. Jul 18, 2020 at 6:20 PM
    #198
    timothom
    They started doing some kind of plasma electro-coating plating liners in 2018, like they do on the GT350 5.2L Voodoo (which also has oil burning issues).
  19. Jul 19, 2020 at 8:11 AM
    #199
    shakerhood
    Southern Ohio
    The compression ratio in the Tacoma 3.5 is about the same, Ford also just introduced a new 7.3 Pushrod V8 too.
  20. Jul 19, 2020 at 2:23 PM
    #200
    jetfishn
    Ford took a aluminum 5.0L block and instead of using tried and true cast iron cylinder liners they somehow machine weld each aluminum cylinder with a hard metal thin bead of metal then bore it out to about .025 thousandths, call it good. uh. No rigidity, warpage could be a huge factor using this method, as well as abnormal cylinder wear, its a horrible idea. Yet Race tested??? No thanks. I hope the new truck owners can get a class action lawsuit going against ford and get their money back on this Pile. Ford keeps giving lame excuses for why the engine is burning oil when they know full well what the problem really is. You can do research and see the mustang 5.0L cylinders with abnormal wear pics. This method should never have been released to public. Its been used for yrs for outboard motors, etc, but apparently is horrible for trucks.
