Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Sep 14, 2018 at 10:00 PM
    SpeySquatch
    2016 TRD OR DCSB
    If “throttle by wire feel” means the same as cabled throttle, like my 2003 Tacoma had, then yes you are correct. It was a single cab 4-banger I lifted and got extended fabtech spindels and 31” tires. Had exhaust, intake, etc. when you stomped that thing went and I knew exactly what the vehicle was going to do. I miss that truck. Many of my younger years memories spent in that little mini taco.
    speedtre and DiabloTRD like this.
  2. Sep 14, 2018 at 10:01 PM
    DakoTaco
    DakoTaco Well-Known Member
    North Coast
    2016 MGM OR Tacoma
    Avid front bumper guard OVtune HPS Intake Tube Meso designs counting
  3. Sep 14, 2018 at 10:03 PM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    Mat's last post fills me with confidence!
    KTJO 4x4 likes this.
  4. Sep 14, 2018 at 10:06 PM
    SpeySquatch
    2016 TRD OR DCSB
    Am I only the only one confused partially on this. Why don’t you want the throttle to open more?
  5. Sep 14, 2018 at 10:10 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    You WANT it to open more. As it stands though it does not open more when it should
  6. Sep 14, 2018 at 10:16 PM
    SpeySquatch
    2016 TRD OR DCSB
    Oh...he’s talking about current stock tune and tables. I thought he was talking about 1.05
    hr206 and Chipi3s[QUOTED] like this.
  7. Sep 14, 2018 at 11:12 PM
    thedriza
    thedriza Well-Known Member
    Portland, OR
    2017 Tacoma DCSB
    5.29 gears, OME HD lift, OVTune
    I don't think the turbo is on anymore
  8. Sep 15, 2018 at 12:01 AM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    I’m a functioning pessimist, get it right...
    Rather than deluded optimist am I right?
    DakoTaco[QUOTED] and bshammer0 like this.
  9. Sep 15, 2018 at 4:23 AM
    tjpratt
    tjpratt Well-Known Member
    Travis
    Aurora, Colorado
    2016 Limited 4X4 Tacoma
    3.75" Lift / OME OVTuned
    This.
  10. Sep 15, 2018 at 5:07 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    That's exactly what I mean
  11. Sep 15, 2018 at 6:35 AM
    60calHowdaHunter
    60calHowdaHunter Well-Known Member
    Dave
    Arizona
    2016 Tacoma 4x4 offroad
    none
    Matt, for OffRoad 4x4 trucks AT transmission, is it possible to make it so when you are off the throttle, coasting to a stop (like 15mph to 0) the transmission does not downshift? In these model trucks, allegedly because the brakes are tied to the ECU (crawl feature) and go thru the ECU (not a direct peddle to pad line) it is very difficult to make a 'smooth' stop (this was discussed in other threads) - we think because the engine RPM differences (changing due to downshifting) make the vacuum change, therefor making the brake sensitivity change, causing driver to constantly try to compensate the brake peddle pressure. Anyway, know you are busy and I DO NOT WANT TO DELAY 1.05, so if easy yeah, if not, next release. thanks for considering it (or if anyone else has this truck and managed to fix this annoyance, LMK!)
    treimche likes this.
  12. Sep 15, 2018 at 6:43 AM
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    HELLS BELLS BABY!!!! Bring this shit on ,,,
    Reypac24 and DiabloTRD like this.
  13. Sep 15, 2018 at 8:26 AM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    You don’t have a vacuum booster in your truck. Your truck has a different system.
  14. Sep 15, 2018 at 8:29 AM
    60calHowdaHunter
    Dave
    Arizona
    none
    doesn't surprise me - whatever that system is however, it makes it real hard to stop smoothly! No worries, it's keep me challenged at every red light :)
  15. Sep 15, 2018 at 8:35 AM
    60calHowdaHunter
    Dave
    Arizona
    none
    Oh, for Matt - disregard my thoughts on the downshifting - I guess the idea of fixing the smooth breaking dies here, like it died a long time ago in other threads. oh well, but if anyone can figure out how to brake smooth on these things gets my sincere appreciation!
  16. Sep 15, 2018 at 9:09 AM
    Anchovy
    TRD Ferguson
    I've never had a problem with smooth braking :notsure:
    Herniator likes this.
  17. Sep 15, 2018 at 9:11 AM
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    I notice it. I'm used to applying brake in a normal manner, but then backing off to next to no brake pressure as I near the stop. It's a technique I use in the planes I fly for a living; if done right, passengers never know you stopped.
    I can't do that in this truck.
    GPatriot and Frito like this.
  18. Sep 15, 2018 at 9:13 AM
    Anchovy
    TRD Ferguson
    I do the same thing, can't explain it
  19. Sep 15, 2018 at 9:13 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    1.03 had much better braking to a stop, less harshness. Came back in 1.04 for me
  20. Sep 15, 2018 at 9:38 AM
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    Ditto.
Thread Status:
