Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Sep 17, 2018 at 12:29 PM
    tater taco
    tater taco no it all
    Todd
    ground zero of the zombie apocalypse
    2016 ACLB TRD OR Quicksand OV Tuned 2.0 (91)
    OVTuned, decatted dump tubes
    Only read Mat's posts or ask him directly what your calibration ID will be after 1.05. There is way to much speculation in this thread to take anyone else's post to heart.
    speedtre likes this.
  2. Sep 17, 2018 at 12:31 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    My assumptions are from reading his posts. My confusion is from reading other people's. This is because to me, my assumption seems like the only logical one.
    riz_atx likes this.
  3. Sep 17, 2018 at 12:50 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I have the same assumption.
    KTJO 4x4 and riz_atx like this.
  4. Sep 17, 2018 at 1:01 PM
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    Mat can program the ECU calibration ID to whatever he wants, he even mentioned he can program the it to read "OVT" instead of "04B0X".
    If you have ECU firmware 04B03 and flash to 1.05 via PCMFlash, your ECU firmware will stay at 04B03, yes it will contain fixes from latest TSB (04B04) that Mat put in. But it does not alter the table and memory locations.
    If you flash to latest TSB 04B04 via Techstream, that WILL alter the table / memory locations, which make legacy tunes 1.04 and older incompatible.
    In other words, if you are on 04B03, you can flash to 1.05. If you don't like 1.05, you can flash back to 1.04, 1.03, etc. If you are on 04B04, you can flash to 1.05. If you don't like 1.05, you can't flash back to 1.04 and older. Unless Mat puts out a new version of 1.04 that is compatible with 04B04, say 1.04R :anonymous:
    Hope that clears up some of your confusions :cheers:
  5. Sep 17, 2018 at 1:03 PM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    yes, too big of a gap between 4th and 5th. and too close of a gap between 5th and 6th. shortening up 5th would solve alot of issues folks have.
    speedtre, dingel5 and 2017TRDpro like this.
  6. Sep 17, 2018 at 1:08 PM
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    Mat has released 1.04R for 04B04 and 04A71
  7. Sep 17, 2018 at 1:11 PM
    2017TRDpro
    2017 TRD Pro
    Yes, that was my point. I guess my sarcasm didn't come across as I hoped. He have the ability to release revised version of legacy tune that are catered to the updated ECU firmware.
  8. Sep 17, 2018 at 1:14 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I’m not implying that Matt’s tune is diminished, only that the benefit might be when comparing a pre and post TSB vehicle. By all accounts, everyone agrees that the TSB ‘helps alot’. So that has to eat into the gains made by Matt.... the tune is going on a vehicle that’s performing better than one without the TSB. End results are probably near identical... the gains slightly different.
  9. Sep 17, 2018 at 1:17 PM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Until stock learning kicks in and it turns back to shit for all those folks not on the tune. The reports are already coming in on those TSB threads about learning.
  10. Sep 17, 2018 at 1:23 PM
    RushT
    North Texas
    Fair enough. If the TSB gains are fleeting and temporary, then yes, it matters when you flash. Flash before TSB or after learning cripples you, benefits seem (are) greater.
    riz_atx[QUOTED] likes this.
  11. Sep 17, 2018 at 1:24 PM
    2017TRDpro
    2017 TRD Pro
    I think even 1.04R has some learning. For the past couple of days, I been driving around town in S5 instead of D, I swear S mode shifts are better than D, and the "race to 5th" is not as prominent in S mode. I flashed 1.04R August 14th, have about 1000 miles on it.
  12. Sep 17, 2018 at 1:24 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Matt has 100% controll over the ECU. Learning has been programmed to do nothing. No learning happening.
    riz_atx likes this.
  13. Sep 17, 2018 at 1:25 PM
    2017TRDpro
    2017 TRD Pro
    That is true with 1.04 and 1.03, I am not so sure if that's true with 1.04R.
  14. Sep 17, 2018 at 1:34 PM
    Anchovy
    TRD Ferguson
    Why would it not be?
  15. Sep 17, 2018 at 1:56 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Think Mat has killed the OEM learning on those and it will be that way on 1.05. It is the learning that makes the OEM TSBs a big disappointment and a POS. JMO. Hope 1.05 comes in the next week or so.....
  16. Sep 17, 2018 at 2:07 PM
    KkelX4
    KkelX4 Well-Known Member
    2017 Tacoma TRD OR
    RTT Rack
    I think you're right for sure, but I also think that 6th is just too tall for this engine. Not even so much for the engine, but the aerodynamics of the vehicle combined with the lack of low available torque make 6th far less efficient and useful above 60mph. I mean, sure you can go 75,80mph in 6th. But I know when I'm doing that I'm getting 16-17mpg. Which I think is the exact opposite of what you'd see in similarly specced vehicles with a sixth gear.
    commbubba19[QUOTED] likes this.
  17. Sep 17, 2018 at 2:37 PM
    2017TRDpro
    2017 TRD Pro
    This is based on my experience so far with 1.04R, so its pure speculation on my part, but I don't think learning is completely eliminated from 1.04R (based on latest TSB 04B04). With 1.03, I feel no difference in shifting behavior between D and S mode, even after several months and thousands of miles. With 1.04R, there is a difference in shifting behavior between D and S mode, about 1 month since flash. S mode drives like how D mode drove when I first flashed to 1.04R.
    S mode have its own set of maps and learning does not impact S Mode, following that logic, I think some learning occurred, although the degradation / impact of learning is drastically reduced with 1.04R, compared to OEM tune.
    I am confident Mat will eliminate learning in 1.05, but until then, I'll just drive around town with 1.04R in S5.
  18. Sep 17, 2018 at 3:21 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Either take your truck to the dealer, or risk doing it yourself with the TechStream software.
  19. Sep 17, 2018 at 3:23 PM
    Shellshock
    Iowa
    I’ve got 2,000+ miles on 1.04r and it runs as good if not better than the day I flashed. But I don’t have a slushbox to deal with…
    Pickupman2007 likes this.
  20. Sep 17, 2018 at 3:36 PM
    Anchovy
    TRD Ferguson
    As far as I'm aware S mode is just a gear limiter. The truck can and will downshift if it thinks it will stall. There's no stopping that. But it will not go into a gear higher than the S gear you are in
    tjpratt likes this.
Thread Status:
