Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jul 31, 2017 at 9:10 PM
    #2241
    Toytaco2k17
    Toytaco2k17 Well-Known Member
    Kenneth
    Chapmansboro Tn
    2016 Nissan Titan XD Pro4x Diesel
    Stock
    My truck would jerk back and forth between 1800 to 2500 or so rpm almost like it missing or running out of fuel. Not all the time but usually when I was going up a small grade with light throttle.
  2. Jul 31, 2017 at 9:11 PM
    #2242
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    My old Jeep did that once. I had some shit fuel in it. Burned the tank and put bette fuel in. Never had the problem again.
    Toytaco2k17[QUOTED] likes this.
  3. Jul 31, 2017 at 9:13 PM
    #2243
    motomaster132003
    motomaster132003 Well-Known Member
    2016 Tacoma TRD OR DCSB
    My MT will do that as well if I am in 2nd gear, roll a speed bump and then try to get back up to speed.
  4. Jul 31, 2017 at 9:16 PM
    #2244
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    Same here. Was there a fix from Toyota? I know OV figured it out but I don't have that....yet!
  5. Jul 31, 2017 at 9:21 PM
    #2245
    Toytaco2k17
    Kenneth
    Chapmansboro Tn
    Stock
    Yeah but this is when you were going 50mph in say 5th gear and let off the throttle and then lightly press it or on the interstate doing 80 in 6th and let off the throttle some and got back on it.
  6. Jul 31, 2017 at 9:22 PM
    #2246
    Toytaco2k17
    Kenneth
    Chapmansboro Tn
    Stock
    Yeah I have had that issue with bad gas in the past.
    Herniator[QUOTED] likes this.
  7. Jul 31, 2017 at 9:28 PM
    #2247
    motomaster132003
    I have had that happen as well. I just thought it didn't want to pull 6th and would down shift to 5th and it would fix it. Haven't had that happen if I am 3000 plus rpm.
  8. Jul 31, 2017 at 10:16 PM
    #2248
    Egnaro
    Egnaro Watch this
    Brett
    AZ
    16 Inferno DCSB Offroad 4x4
    Ricochet full skids, Mobtown rear with swing-out, toytec boss 2.0, OV tuned
    Just a quick FYI, if you get your truck updated by the dealership for whatever reason, check with @OVTune and make sure your tune from him is still the right one before you flash back to it. Maybe he can clarify more.
  9. Jul 31, 2017 at 10:25 PM
    #2249
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Yes if you get an ECU / Calibration / TCM Calibration update from the dealership please let us know and do NOT over-write it with a previously made tune.
    I believe I got all pending files sent out, if I missed you please let me know.
    There are two customers with 04B01 ECU versions that will have to go to their local dealerships for a simple calibration update. OR you can use Techstream-Lite + the tactrix cable to do it from home.
    Unfortunately this calibration update is a minimum required because of the transmission, and the files are locked to eachother upon flashing so we can't do it our way. :( if you have this file version I will email you tomorrow.
    goodnight
    hbaade, MOC221_, bshammer0 and 3 others like this.
  10. Jul 31, 2017 at 10:33 PM
    #2250
    Lwood
    Lwood Well-Known Member
    Lynwood
    16' TRD Sport DCSB
    Thanks for all the hard work Mat.
    Hank Heel and Egnaro like this.
  11. Aug 1, 2017 at 5:06 AM
    #2251
    Egnaro
    Egnaro Watch this
    Brett
    AZ
    This morning I flashed 1.01B to my truck. After the flash completed I clicked ok and tried to do the identification again just to see the versions and such. It said failed. I tried to start the truck, it wouldn't start. Hmmm....
    I closed the program and unplugged the cable. And turned off the truck.
    Not gonna lie, I was kinda worried, but I turned the truck back on, plugged there cable back in and opened the program. I tried to do the identification again, failed. So I decided to try to flash the 1.01B one more time. This time when it finished I clicked ok and turned the truck off like it tells me to.
    I turned it on again I tried identification, success. I tried to start the truck, success!
    :goingcrazy::goingcrazy::goingcrazy:
    I guess turning the truck off after is like restarting your computer after a software install.
    So I'll be driving today and will give feedback of stock (thanks to dealership) to 1.01B. Initial feel is night and day though. I had 1.01A prior to dealership update.
    speedtre, Ares32 and MOC221_ like this.
  12. Aug 1, 2017 at 5:50 AM
    #2252
    wantone
    wantone Well-Known Member
    Baton Rouge, LA
    2017 TRD Offroad DCLB White w/tech package and 6AT
    DeeZee bed mat, Weathertech floor mats and in channel wind deflectors, Carista, center console tray, tinted windows, LED interior lights, 265/75R16 AT3s, carhartt seat covers, bakflip MX4
    Got my files at 12:15 am central time! Wrote them to truck just a few minutes ago. Will drive off and on today and report back at some point.
    FYI, I have stock intake and exhaust.
    Oh, and I'm unhooking my shift sense pro also.
    DES2009 and Egnaro like this.
  13. Aug 1, 2017 at 6:04 AM
    #2253
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    No stutter on way to work today and I was getting that in a couple of places each day with 1.01A and the pipe. Very happy stutter and backfiring is gone. Something has changed with how the auto shifts and cant put my finger on it. Did not run ECT this AM as I wanted to compare to past commutes with cruise on so no update on accelerator pedal feel. D without ECT feels good. This is not comparing to the stock tune. The OVTune is so much better than stock. The way the truck drives changed completely. This is mostly addressing issues I had after adding the Spec U pipe to the tune. I had run the tune about 700miles before adding the pipe. Then another 700 miles with both and with more than 200miles off-road total now.
    @OVTune I still feel the engine falls on its face when you go WOT from a dead stop, it takes way too long to get to 2K RPM and start making power.
    I hope that there will be some data logging or dyno time with the Spec U pipe used to make the 1.02 update. I know there is more untapped power in this engine.
  14. Aug 1, 2017 at 6:33 AM
    #2254
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    kashtyaatsi and sig916 like this.
  15. Aug 1, 2017 at 6:34 AM
    #2255
    Egnaro
    Egnaro Watch this
    Brett
    AZ
    You missed it, it was a one time deal
    :boink:
    He is working on an 87 tune, its not released yet.
  16. Aug 1, 2017 at 7:25 AM
    #2256
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I was not getting any misfires other than random or on a cold start before the engine was fully up to temperature. My logs just showed the timing going insane right at 1750 RPM with light throttle input.
    bshammer0 and Egnaro like this.
  17. Aug 1, 2017 at 8:28 AM
    #2257
    rnicholls
    rnicholls Well-Known Member
    2016 TRD OR DCLB
    Can't tell if yall got into my head or not but had a cold start this morning and was sitting at about 1600 and felt this back and forth motion. It felt like vibration but more static. Will load B tonight for sure.
  18. Aug 1, 2017 at 8:53 AM
    #2258
    FLJoe
    FLJoe Well-Known Member
    Joe
    Wellington, FL
    16 Blazing Blue Taco Limited AT
    OV Tuned
    I don't have the tune yet, but have the new crank sensor and on idle I was watching timing bounce between 4-25°. Something isn't right in these motors.
    bshammer0 likes this.
  19. Aug 1, 2017 at 10:51 AM
    #2259
    Egnaro
    Egnaro Watch this
    Brett
    AZ
    Mine still shutters in first at 1800 rpm
  20. Aug 1, 2017 at 1:22 PM
    #2260
    su.b.rat
    su.b.rat broken truck
    got 1.01B on my MT last night, ran about 100mi today.
    no stutter, pulls a little better than 1.01a from what i can tell. it runs normal with a pretty linear throttle and feels a bit cleaner or filled out in terms of power delivery... relying on the butt dyno of course. makes me feel I'm doing something good for the motor by removing all this weird muting Toyota had on there. "had" being the key word.
    pretty damn fulfilling to have this truck drive just like it should and what i was eventually hoping for with motor performance. drives really nice with the MT and our 4.3's.
    anyone silly enough to still be waiting around for verified driveability improvements, stop waiting and get your wallet. i think i can only speak for the MT's... leaving an AT owner for their reports.
    thanks, Mat. looking forward to further development.
Thread Status:
