Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Sep 26, 2018 at 7:44 AM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Not currently.
  2. Sep 26, 2018 at 7:47 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    soon :D
    speedtre likes this.
  3. Sep 26, 2018 at 8:04 AM
    Rus$
    Rus$ Well-Known Member
    Russ
    2018 Tacoma DCLB AT TRD Off Road
    You guys didn't get the files yet?
  4. Sep 26, 2018 at 8:28 AM
    tater taco
    tater taco no it all
    Todd
    ground zero of the zombie apocalypse
    2016 ACLB TRD OR Quicksand OV Tuned 2.0 (91)
    OVTuned, decatted dump tubes
    probably closer to never
    riz_atx[QUOTED] likes this.
  5. Sep 26, 2018 at 9:07 AM
    Double Phister
    Double Phister Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
    You're probably right. The speed sensors are wired into the "skid control" ECU. Then the speed is put onto the CANBUS. The dash and other ECUs read it from the bus.
  6. Sep 26, 2018 at 9:14 AM
    riz_atx
    Sohail
    Spicewood Texas
    When you install a hypertech calibrator into your taco, you attach it inline to the back of the speedometer. This makes me believe that the speed "signal" comes from the source in the drive train to directly behind the gauge cluster. There are wires that go from the oem harness behind there to the radio to disable features while you are moving, ie the same speed signal wire you can get a bypass for (nav in motion mod).
    When you connect via the ODBII port with Techstream, you get access to all the ECU's the vehicle has so I bet if OVTune wanted, he could probably access any of them. Since hypertech is an inline solution, it makes me wonder if its possible at all via ecu change only. Feels like the hypertech is doing the math inline
  7. Sep 26, 2018 at 9:18 AM
    Double Phister
    Sacramento, CA
    I have the hypertech. I haven't looked at what it's bypassing. I just assumed it was reading the speed signal on the CANBUS and feeding a new one to the CANBUS the dash sees. I looked at the wire diagrams going into the dash and didn't see a direct line from the skid control ECU to the dash. That's just me guessing though.
    I'll look at the radio pins to see what the NAV bypass is doing.
  8. Sep 26, 2018 at 9:20 AM
    riz_atx
    Sohail
    Spicewood Texas
    Im guessing too on some of it.
    It would be great to have a software only solution though.
    Edit: The information in the HU is also updated with the hypertech calibration change. This is why i thought the source was there behind the gauge cluster
  9. Sep 26, 2018 at 9:21 AM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Damn you got me. Lol
  10. Sep 26, 2018 at 10:17 AM
    KkelX4
    KkelX4 Well-Known Member
    2017 Tacoma TRD OR
    RTT Rack
    If that's the case someone would have to write a script that intercepts the canbus and outputs the corrected speed. And the computer would have to be rewritten to read from the script instead of wherever it does now. Pretty complicated. Hypertech is still probably the best stop gap
    riz_atx likes this.
  11. Sep 26, 2018 at 10:59 AM
    SpeySquatch
    2016 TRD OR DCSB
    It seems to be a common 2018 meme. Lol
    Chipi3s[QUOTED] and riz_atx like this.
  12. Sep 26, 2018 at 11:21 AM
    MacFly
    MacFly Well-Known Member
    2018 Cement Tacoma TRD Off Road AT
    OVTune, AT Habitat, Firestone RRs, ARB CKMA12 compressor
    Subbing for future updates
  13. Sep 26, 2018 at 12:21 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    it's possible to reprogram the tach over OBDII for larger tires.
    however, this is not implemented in our solution yet.
    I already have the communication data to do so,
  14. Sep 26, 2018 at 12:27 PM
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Awesome work Matt, really looking forward to 1.05!
  15. Sep 26, 2018 at 12:42 PM
    Double Phister
    Sacramento, CA
    We don't need to modify our tachometer. It's the speedometer that changes with tire size. Is that adjustable?
    commbubba19, GPatriot and riz_atx like this.
  16. Sep 26, 2018 at 12:48 PM
    KkelX4
    2017 Tacoma TRD OR
    RTT Rack
    Yayyyy
  17. Sep 26, 2018 at 12:50 PM
    riz_atx
    Sohail
    Spicewood Texas
    can you comment on what @Double Phister said?
  18. Sep 26, 2018 at 1:06 PM
    SpeySquatch
    2016 TRD OR DCSB
    I’m confused. Do you mean something different from starting the truck and driving how it is on start V.S. reaching up and pushing the button that has the icon of the vehicle with the swervy tire lines?
    I thought you were supposed to do daily driving with what the truck defaults with when turned on
  19. Sep 26, 2018 at 1:19 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Damn, you got me? Or
    Damn you, got me?
    :duel:
    dingel5 likes this.
  20. Sep 26, 2018 at 1:48 PM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
Thread Status:
