Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Sep 27, 2018 at 10:53 AM
    Totall4285
    Totall4285 Well-Known Member
    Palm Harbor, Fl.
    2017 Tacoma TRD Sport
    It's not the gas. I have over 1500 miles multiple gas fills. Very different from initial flash.
  2. Sep 27, 2018 at 10:54 AM
    SpeySquatch
    2016 TRD OR DCSB
    Exactly why 1.05 will be the tune to rule them all.
  3. Sep 27, 2018 at 10:55 AM
    Totall4285
    Palm Harbor, Fl.
    Looking forward to it
    GPatriot likes this.
  4. Sep 27, 2018 at 10:57 AM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    Turn the truck on, leave the button alone.
    hbaade, TRDOBSESSED, riz_atx and 2 others like this.
  5. Sep 27, 2018 at 12:08 PM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Unless you are wheeling then long press the button until it says Trac Off. I’m in 4lo a lot offroad and it’s off by default there
    acemastr[QUOTED] likes this.
  6. Sep 27, 2018 at 12:36 PM
    Shellshock
    Iowa
    same. people are the worst.
    tdnick, Anchovy and tjpratt like this.
  7. Sep 27, 2018 at 12:37 PM
    Shellshock
    Iowa
    oh god it is about that time. winter gas makes me cry. such garbage.
    bshammer0[QUOTED] likes this.
  8. Sep 27, 2018 at 12:42 PM
    riz_atx
    Sohail
    Spicewood Texas
    Being in Texas I’m not sure what winter gas is. What’s the one sentance description?
    MacFly likes this.
  9. Sep 27, 2018 at 12:51 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    It's all about the RVP (evaporation) of the fuel. Winter gas needs to be able to evaporate at lower temperatures for combustion, summer gas needs to control evaporation for purposes of potential vapor lock and to reduce emissions. The impact on consumers is that winter gas contains slightly less energy than summer gas so generally summer gas is more expensive than winter gas, you get lower MPGs on winter gas and depending on your vehicle may notice performance changes. I notice about a 2mpg drop with winter gas calculated over the last 2 winters in the truck
    riz_atx[QUOTED], MCDavis and MacFly like this.
  10. Sep 27, 2018 at 12:52 PM
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    technical description: Edited for content and clarity
    ... involves the Reid Vapor Pressure (RVP) of the fuel. RVP is a measure of how easily the fuel evaporates at a given temperature. The more volatile a gasoline (higher RVP), the easier it evaporates.
    Winter-blend fuel has a higher RVP because the fuel must be able to evaporate at low temperatures for the engine to operate properly, especially when the engine is cold. If the RVP is too low on a frigid day, the vehicle will be hard to start and once started, will run rough.
    Summer-blend gasoline has a lower RVP to prevent excessive evaporation when outside temperatures rise. Reducing the volatility of summer gas decreases emissions that can contribute to unhealthy ozone and smog levels. A lower RVP also helps prevent drivability problems such as vapor lock on hot days, especially in older vehicles.
    Everyday description: Mileage goes down with winter blend. 10-20% depending in circumstances.
    riz_atx[QUOTED] likes this.
  11. Sep 27, 2018 at 1:07 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Depends how you drive and the conditions. For standard on pavement driving (no snow) I'd just leave it in the default mode 1. I don't ever drive in the snow/ice but if I did I would probably roll around in mode 2 a lot in those conditions. The one day it did snow here I did exactly that. I would advice caution doing this though because it will let you get yourself into serious trouble where as mode 1 will not. In mode 2 you could easily give it too much throttle and completely spin out where as mode 1 will not allow this even if you floored it on solid ice. Mode 2 would also be decent if you were on a muddy road but at that point you may want to hop into 4Hi...same if there's a ton of snow but Auto LSD would be good for those times when it's like off and on snowy conditions and you don't necessarily want to be in 4Hi. Mode 3 is really only for one thing...hooning. Doing donuts and being stupid. You could hoon in mode 2 but it's going to stress the TRAC system and diff...not recommended.
    dingel5 likes this.
  12. Sep 27, 2018 at 1:10 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Don’t even get me started on that :rofl:
    Shellshock[QUOTED] and Chipi3s like this.
  13. Sep 27, 2018 at 1:11 PM
    SpeySquatch
    2016 TRD OR DCSB
    Perfect description. Well done thank you. This truck has as many modes and buttons as a NASA space shuttle
    StayinStock and riz_atx like this.
  14. Sep 27, 2018 at 1:12 PM
    SpeySquatch
    2016 TRD OR DCSB
    Not to mention gas stations increase prices in gas during summer because people travel more. Memorial Day gas prices go up because it’s a big travel day
    Shellshock and bshammer0[QUOTED] like this.
  15. Sep 27, 2018 at 1:23 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    This truck is very quirky. I thought it was feeling different with 1.04 then I swapped to Exon gas and I was back to normal.
  16. Sep 27, 2018 at 1:51 PM
    Anchovy
    TRD Ferguson
    I personally have been noticing that the shifting in my slush box is becoming sloppy, mostly at low speeds, compared to when I first flashed
    Yellowplatypuss and Totall4285 like this.
  17. Sep 27, 2018 at 5:16 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Alright guys, if weather permits I will have a full run down of 1.05 and videos, explanations via video, other cool stuff this weekend
    redrelyt12, advan7, Phich and 46 others like this.
  18. Sep 27, 2018 at 5:19 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
  19. Sep 27, 2018 at 5:19 PM
    TWTaco
    TWTaco Well-Known Member
    Dave
  20. Sep 27, 2018 at 5:19 PM
    mexanese.502
    mexanese.502 Well-Known Member
    Kentucky
    2017 Limited BADASSMF
    OV Tuned
    Freaking Sweet
Thread Status:
