Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Oct 8, 2018 at 2:14 PM
    MacFly
    MacFly Well-Known Member
    2018 Cement Tacoma TRD Off Road AT
    OVTune, AT Habitat, Firestone RRs, ARB CKMA12 compressor
    I am also a bit worried with people saying re-flashing makes a big difference, so I just figured I'd have to re-flash on a semi regular basis, but I was not aware that Mat advises against this.... Did he say why, or does anyone know why that would be a bad idea?
  2. Oct 8, 2018 at 2:16 PM
    dingel5
    dingel5 Mocphus
    Paul
    P Town, California
    2016 MGM SR5 AC AT 4x4 OVTuned 2.0B (Un)Dongled OG
    In progress.... And getting better!
    I could get approximately 3.8 gallons for $20! :poking:
    Chipi3s likes this.
  3. Oct 8, 2018 at 2:20 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    When you reflash you reset all your fuel trims. Your ecu has to make all of its adjustments again and it takes time for the ecu to make them. I find it very odd that people are saying the learning has come back when @OVTune has said the learning has been eliminated. Possibly bad gas?
    TelosHedge likes this.
  4. Oct 8, 2018 at 2:26 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    I did not reflash but had the same issue - I removed the negative lead to the battery - afterwards it was fine and using the same tank of gas. I doubt in my case it was the gas. Many posts in the last few weeks about this and many tagging @OVTune ???? no insight from Mat yet.
  5. Oct 8, 2018 at 2:27 PM
    MacFly
    Does switching to a different octane tune do the same as reflashing? Seems like a decent number of people are having the same issues, and noticing an "immediate" change after reflashing, and I am guessing they're running the same tank of gas in the process. I had been assuming that the "quality" (maybe characteristics would be a better word) was changing on people over time due to folks here saying the tune takes time to 'settle in'. I have also read on here that learning is reduced, while others say eliminated completely. Curious which it is...
  6. Oct 8, 2018 at 2:35 PM
    tjpratt
    tjpratt Well-Known Member
    Travis
    Aurora, Colorado
    2016 Limited 4X4 Tacoma
    3.75" Lift / OME OVTuned
    Everyone I've heard says it's an immediate change for the better.
    Bad gas wouldn't explain that.
    I haven't done it. But I am noticing it's not as smooth as it was.
    bshammer0 likes this.
  7. Oct 8, 2018 at 2:37 PM
    TEXAS BS
    TEXAS BS Formerly known as MMXVII
    JB
    Texas
    2017 ACLB TRD OR 4X4
    It sounded like Matt did not know until he got the last set of factory tables that there where tables that block or ignored changes he made to other tables.
    I think 4R came out before Matt made this descovery.
  8. Oct 8, 2018 at 2:38 PM
    Shellshock
    Iowa
    I think people are convincing themselves that there is a problem and it’s placebo effect :crazy:
    dskakie, MOC221_, mZiggy and 3 others like this.
  9. Oct 8, 2018 at 2:41 PM
    iPaint
    iPaint Well-Known Member
    Nebraska
    2017 TRD OR DC 4x4 AT
    You never had 04B04 or 1.04R on your auto, did you? I bet it would have been noticeably better.
  10. Oct 8, 2018 at 2:41 PM
    MacFly
    Entirely possible, but it does seem on the surface that some people are independently noticing a difference after re-flashing. Personally I don't think I'll mind having to re-flash every few months if it keeps the truck driving well, and doesn't do any damage to the damn overpriced thing.
  11. Oct 8, 2018 at 2:41 PM
    Shellshock
    Iowa
    It would if it’s just recalibrating faster due to parameters being reset.
  12. Oct 8, 2018 at 2:42 PM
    iPaint
    Nebraska
    I unplugged the battery yesterday to reset the ECU. There is a change.
    KTJO 4x4 and Tac0Tic0 like this.
  13. Oct 8, 2018 at 2:42 PM
    GoldenBrew
    Golden, Colorado
    Stop talking Politics. :)
  14. Oct 8, 2018 at 2:42 PM
    Shellshock
    Iowa
    Correct. I had the first auto TSB way back when.
    I’d be curious to see the difference now, but i have zero intentions of going back to an auto after the miles I’ve logged on both.
  15. Oct 8, 2018 at 2:44 PM
    Shellshock
    Iowa
    I put in a new battery last weekend. Mine seems the same :notsure:
  16. Oct 8, 2018 at 2:51 PM
    iPaint
    Nebraska
    DON’T GO BACK!!! MT ftw! lol
    I think that the reset is going to have a more noticeable affect on the AT trucks. It’s not significant, but noticeable.
  17. Oct 8, 2018 at 2:54 PM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    All I'm going to say is that 1.05 in the wet is awesome fun
    hbaade, DiabloTRD, dingel5 and 4 others like this.
  18. Oct 8, 2018 at 2:55 PM
    Shellshock
    Iowa
    I hope controllable fun and expected and not unexpected fun like 1.03b was
    MOC221_ likes this.
  19. Oct 8, 2018 at 2:55 PM
    TelosHedge
    TelosHedge tiny moron
    Central NC
    18 Inferno Sport DCSB 4x2
    You're going to notice a change between what your truck has adjusted over time vs a clean slate based off a brand new flash/reset battery. Do not mistake this as the 'learning' of shift tables and throttle response curves that Mat has eliminated. All fuel injected OBD2 cars make adjustments based on their connected sensors' feedback over time.
    I wouldn't call this the Placebo effect - it's definitely something provable. However, I will say it sounds like people like the feeling of the immediate changes they feel when they reflash/reset - whether those changes end up being better or worse for the vehicle or driving scenarios over time.
    Tac0Tic0 and tjpratt like this.
  20. Oct 8, 2018 at 2:57 PM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    You'll be happy with the throttle control
Thread Status:
