Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Oct 11, 2018 at 7:05 AM
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    So wierd. 7 months after I bought my Tacoma (long before I bought OVTune) I took the camper from here in Ohio to the Rockies. I never had one issue with performance in the mountains (except for the crappy AT of course).
  2. Oct 11, 2018 at 7:08 AM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    So what were Toyota’s good reasons? Emissions and mileages?
  3. Oct 11, 2018 at 7:09 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    The truck won't go ape shit but the load, torque calcs are lowered so you might get det, you will very likely see erratic shifting.
    1.05 should improve mountain driving over anything else as it totally modifies target angles and calculations for angles.
    What I mean is in stock form and previous tunes the angle you get is what is in the modeled tables.
    1.05 changes the actual models (4D models) so the ecu actually requests more throttle, regardless of gear or downshift etc.
    It nearly doubles the maximum angles in higher gears before downshifting. (6th gear 28 percent to now 50 percent)
  4. Oct 11, 2018 at 7:10 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    A lot said. And so your answer to the possibility of "learning" is ??? I'll check back much later than this afternoon. I'm content with 1.04. Anticipating 1.05. Thanks for the work. Stay safe.
  5. Oct 11, 2018 at 7:16 AM
    OVTune
    OVTune
    The "learning" is always going to "exist" in a way. It isn't really learning, but rather using one of the many tables at its disposal to achieve a better driving experience. It's not recording your drive and modifying the hard code, it's recording feedback from all sensors and selecting "map set A" "map set B" etc ( map sets from A to P). They are already condensed in 1.05, and the transmission ones are in 1.04
    It's kind of difficult to explain.
    I have tested one thing to eliminate it (force map set A always) however more data is needed to see how safe this is. By literally blanking out the 3rd 4D axis it's forced to use only 1 table set.
    SigSense, ksanti808, Chipi3s and 6 others like this.
  6. Oct 11, 2018 at 7:17 AM
    Matt3400
    Matt3400 Well-Known Member
    2007 Lexus GX470
    As someone that can actually see Pikes Peak from his front door and soon to have 285/70/17 tires, I really do need to get this tune (and 4.88's).
    Shellshock likes this.
  7. Oct 11, 2018 at 7:18 AM
    amazingswami
    amazingswami Member
    This makes sense, but how often does it update its data set for table selection?
  8. Oct 11, 2018 at 7:24 AM
    dingel5
    dingel5 Mocphus
    Paul
    P Town, California
    2016 MGM SR5 AC AT 4x4 OVTuned 2.0B (Un)Dongled OG
    In progress.... And getting better!
    Yep... Aliens.
    Shellshock, MasonicTaco and TD90S like this.
  9. Oct 11, 2018 at 7:28 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    It sounds like this is also the case on a M/T truck (obviously everything but the slushbox shift tables).
  10. Oct 11, 2018 at 7:48 AM
    MOC221_
    Frank
    Whoa...
    @OVTune, how does this translate for M/T tunes?
    IIRC you mentioned "per gear" specific table modifications before for M/T.
    (For everyone else, yes I know the ECU does not "talk" to our M/T transmissions. But, if you assume stock tire size, speed and RPM should give enough data to assume a gear). Also, the truck should "know" what Tcase range you're in - inputs from Tcase internal limit switches.
  11. Oct 11, 2018 at 7:49 AM
    Ron1965
    Ron1965 Go Bruins.......
    Ron
    Socal
    2018 Cement TRD ORSB PREMIUM/TECH
    OVtune Mooseditty Custom;DD Exhaust;Nitro 5.29’s;SCS Brushed Copper;AFe Custom CAI
    Been on 1.04. 91 for about 3000mi..Truck runs great. Don’t notice any “learning”. Yesterday I ran 85mph up a fairly steep hill for about 3mi Truck stayed in 5th the whole way.Left a Pro and another OR way behind..Maybe it’s just the difference in each truck we are seeing?? Love1.04
  12. Oct 11, 2018 at 7:53 AM
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    1.04A or 1.04R?
    MOC221_ likes this.
  13. Oct 11, 2018 at 7:54 AM
    Ron1965
    Ron
    Socal
    Did not get tsb——so just plain 1.04. Forgot to mention that.. Maybe it’s the tsb?
    MOC221_ likes this.
  14. Oct 11, 2018 at 7:57 AM
    MOC221_
    Frank
    1.04A 91 M/T > 1.04R 91 M/T in my case.
    Power-wise at least.
    2016trdtacoma likes this.
  15. Oct 11, 2018 at 7:59 AM
    TacoSauceHB
    TacoSauceHB Well-Known Member
    Brian
    Rathdrum, ID
    2017 _TRD Off-Road DCLB 4X4 Tech Package
    King 2.5 ext travel, Camburg uniball UCA, SCS Ray10 wheels, 285/75/16 Cooper STT Pro's, CMC , MBRP exhaust, K&N cai , OVTune 1.05 , T-rex billet grill, Rigid DS Pro ditch lights, SDHQ ditch light brackets, Leer 100XQ Shell, ShmellFab Sliders, Victory 4x4 Roof rack, LED headlights. SOS Concepts bumper, Smittybilt X20 Winch, Nitro 5,29 gears, ECGS clamshell bushing.
    I also feel it has a lot to do with the driver and how heavy your foot is. I see a lot of people bragging about their MPG's and all I can think of is that one guy who goes the speed limit everywhere and hardly experience any WOT scenarios. I drive like an asshole and not afraid to admit it lol, I like to have fun. Maybe that's why I noticed a huge difference after reflashing. I was driving on the tune for 6 months, not sure about mileage.
  16. Oct 11, 2018 at 8:15 AM
    RC84
    RC84 Well-Known Member
    3G Double Cab TRD OR
    SCS F5 - 17x8.5 Matte Gunmetal Cooper ST Maxx - 255.80.17
    I've been out for a minute and would like a quick update, as a lot of info seems to be buried. Has any of the iterations gained any additional hp/tq since the chart posted in post #1?
    After flipping through a few pages...seems like there has not been any additional gains # wise, but more so improvements to the driving characteristics.
  17. Oct 11, 2018 at 8:23 AM
    GF8er
    MT. Hood
    I'm with you on this. I was loving 1.04A but decided to apply the tsb and run 1.04R. 1.04R was great at first, but that changed after a few weeks. After reflashing 1.04R91 a few days ago my mileage is back up to where it was (+2mpg) I guess I'll see how long it lasts this time.
    MOC221_[QUOTED] likes this.
  18. Oct 11, 2018 at 8:28 AM
    brohirrim
    brohirrim Well-Known Member
    I was installing a front camera the other weekend and disconnected my battery and I was halfway through a tank of gas (of driving back and forth to work). Monday morning the throttle was way more sensitive and the truck spent the whole freeway drive in 5th, never 6th. My tank mpg average dropped by 2 during the 30 minute drive... (19.x to 17.x).
    I am but a simple man but that felt like a pretty straightforward correlation = causation lol
    edit: 1.04 on stock tires/suspension
  19. Oct 11, 2018 at 8:35 AM
    MacFly
    MacFly Well-Known Member
    2018 Cement Tacoma TRD Off Road AT
    OVTune, AT Habitat, Firestone RRs, ARB CKMA12 compressor
    Same here, I'm gonna miss the mountains when I finally move. Only had time to drive around for about 10 minutes on the tune yesterday, but I definitely feel a difference. Interested to see how things go over time, and how 1.05 will feel when it finally comes out
  20. Oct 11, 2018 at 8:38 AM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Same! I drive my truck like i stole it
    Lift and tires this truck struggles to maintane certain speeds, i have to constantly feather the throttle till i find a spot that it wants to drive in. I hate you Toyota, you cheap son of a guns. Ima sell this truck in 6 years if it doesnt break by then.
Thread Status:
