Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Oct 11, 2018 at 10:38 AM
    lanmaster53
    lanmaster53 Well-Known Member
    Tim
    2019 Tacoma TRD Pro Super White 6MT
    Would be epic if we could flash from our Android phones...
    MacFly likes this.
  2. Oct 11, 2018 at 10:43 AM
    Shellshock
    Iowa
    Naw you’ll be good. I’ve been from zero to 12,000 feet and mine didn’t explode. I even pulled a trailer up through the vail pass
    Chipi3s[QUOTED] likes this.
  3. Oct 11, 2018 at 10:45 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Thanks for the insight as to why some of us experience this behavior. Easy cure for me, correct or incorrect, was to remove the negative battery lead and let the tables clear. If that is all it takes, which was a once in four month occurrence I am okay. Knew it was not the Tune and there was no reason to reflash. Figured it had to be in the Mother Ship mess of an ECU. Again, looking forward to 1.05.
  4. Oct 11, 2018 at 10:47 AM
    Shellshock
    Iowa
    My favorite part of being tuned is when I went through the mountains cruising along at 2500-3000 rpm and I heard the Tacoma next to me downshift and screaming at 5000-6000 rpm to make it up the pass
  5. Oct 11, 2018 at 10:48 AM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    I always found on 1.04 that driving a little more 'enthusiastically' after starting the truck made it run better... of course only up to a certain degree as the engine is cold.
  6. Oct 11, 2018 at 10:51 AM
    Shellshock
    Iowa
    I’m somewhere in the middle. I do so much highway driving that my numbers are way better than most people see. I usually set the cruise at 65-70 cuz the sooner I get somewhere, the sooner I have to work again lol
    dingel5 likes this.
  7. Oct 11, 2018 at 10:53 AM
    GoldenBrew
    Golden, Colorado
    Vail is easy from East to West - a little tougher from West to East. Try Monarch and Cottonwood. Still your truck will not explode. I've pulled my camper over all of them with no issues. Good news about elevation - it allows lower octane.
  8. Oct 11, 2018 at 10:53 AM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    I wish i could use the cruise control. Its all over the place on gears and a guaranteed loss of mpgs.
    bensonxj likes this.
  9. Oct 11, 2018 at 10:54 AM
    SpeySquatch
    2016 TRD OR DCSB
    Yah...wondering if a little snowflake was part of the design team. They wanted to make their mark so they made a sensitive Tacoma that instead of offending no one, offends EVERYONE
  10. Oct 11, 2018 at 10:55 AM
    SpeySquatch
    2016 TRD OR DCSB
    Run Bootcamp, basically hold option when you power on
  11. Oct 11, 2018 at 10:56 AM
    Shellshock
    Iowa
    I came from the west to east. I did better up the pass with 3,000 lbs of trailer than a lot of other cars did just by themselves. There wasn’t any place I couldn’t maintain the speed I wanted
  12. Oct 11, 2018 at 10:56 AM
    Shellshock
    Iowa
    Can’t make everyone happy, but you can make everyone unhappy!
  13. Oct 11, 2018 at 11:01 AM
    GoldenBrew
    Golden, Colorado
    Oh the advantage of having a MT. I have the AT so I used the S mode and locked out anything above 4th. Ran fine in the power band all the way up the pass. Had the MT in my Gen 2 - thought 1st was so low it was only good for pulling the house off the foundation!
  14. Oct 11, 2018 at 11:01 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    1.05 uses the throttle/torque changes to stay in gear. I was doing 80mph across the bridge over Tampa Bay during the tropical storm and only going up the bridge with a 40mph headwind did it change to 4th.
  15. Oct 11, 2018 at 11:04 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    Oops, that slipped out... ;)
  16. Oct 11, 2018 at 11:05 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    Don't worry, I won't tell the cops you were doing 80mph.
  17. Oct 11, 2018 at 11:06 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Isn’t that the normal speed limit down there?
  18. Oct 11, 2018 at 11:07 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    *ehem* 'yes'
    Prairie Hawk, MOC221_, TC_Mic and 2 others like this.
  19. Oct 11, 2018 at 11:07 AM
    GoldenBrew
    Golden, Colorado
    just realized my radio gets 105. So happy now! I can stop waiting and just enjoy the sound 105 brings to my ears.
  20. Oct 11, 2018 at 11:08 AM
    Rob81680
    Rob81680 Member
    2016 TRD Off Road
    @OVTune
    With that being said, is it/would it be possible to add an aftermarket MAP sensor and tune for it? Is there an input on the ECU that could be used this way?
Thread Status:
