Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Nov 1, 2018 at 11:49 AM
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    fake news
    honey, Capt_Awesome and YotaDriver631 like this.
  2. Nov 1, 2018 at 12:00 PM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    You're not going to try and flash again? I went for service today and thought I had them onboard to flash the TSB, but Nooooo it didn't produce the symptoms. So I said screw it and Flashed 62-18 myself. Took no more then 10 minutes to load the TSB and 1.04R after. It had to be a connection hiccup for you. Just my experience today YMMV.
    On a side note- It takes longer to do a test drive and tell me they can't reproduce the issue then actually just flashing the firmware. It just makes no sense to me.
    ihatemytruck, PhogDog and speedtre like this.
  3. Nov 1, 2018 at 12:03 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    What version of techstream did you use?
    Did you trickle charge your battery?
    Got the CUW files from here?
  4. Nov 1, 2018 at 12:06 PM
    speedtre
    speedtre Well-Known Member
    DirtySouth
    '17 DCLB TRD OR AT 4x4
    All you need to know....and no, I didn't trickle charge.
    2016+ Toyota Tacoma V6 ECU Tuning Alpha Release
    Egnaro, riz_atx and Supr4Lo like this.
  5. Nov 1, 2018 at 12:07 PM
    Supr4Lo
    Surprise, AZ
    Techstream Ver 13.10.019 that I got off the internet and CUW file I got from this thread (I used the file for 04A61 ).
    No charger on battery but I just recently drove the truck before hand.
  6. Nov 1, 2018 at 12:10 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    So what exactly is being tested on 1.05 ? Also no mention of ECT in the updated 1st page, is that still just for more agressive shifts in 1.05 ir is it a tow mode now
  7. Nov 1, 2018 at 12:10 PM
    MacFly
    MacFly Well-Known Member
    2018 Cement Tacoma TRD Off Road AT
    OVTune, AT Habitat, Firestone RRs, ARB CKMA12 compressor
    https://www.tacomaworld.com/threads...-alpha-release.495735/page-1094#post-18467047
  8. Nov 1, 2018 at 12:12 PM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    glad u mentioned that, I need to remember to turn it off when I
    test it. I installed the always-on mod for ECT.
  9. Nov 1, 2018 at 12:12 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    Exactly what I did. Ran V12.30.017, used the CUW attached
    I’m thinking that I let the battery get too low (but i was watching).
    I may try again tomorrow morning!
  10. Nov 1, 2018 at 12:13 PM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    speedtre[QUOTED] likes this.
  11. Nov 1, 2018 at 12:14 PM
    MacFly
    I asked that question and was told by people on here that you CAN'T go back to old or "stock" tunes once you update....
  12. Nov 1, 2018 at 12:16 PM
    MacFly
    Wish I knew how you guys were doing it... even babying this thing I haven't gotten over 17mpg yet. :mad:
  13. Nov 1, 2018 at 12:16 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
  14. Nov 1, 2018 at 12:16 PM
    BlkTaco47
    BlkTaco47 Unhinged
    I ask him the questions directly in email so there's no miscommunication and that's
    exactly what he told me. I did not ask him about stock, only older tunes such as
    1.03//1.04.
  15. Nov 1, 2018 at 12:16 PM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    I used a battery tender when I did mine just to be safe and had no issues.
  16. Nov 1, 2018 at 12:17 PM
    Supr4Lo
    Surprise, AZ
    From what I understand is if you update to the TSB your choices are stock, 1.04R or 1.05 when released. If you don't update you can go stock, 1.03, 1.04, and 1.05 when released. This is for automatics.
    Frito, go2cnavy and riz_atx like this.
  17. Nov 1, 2018 at 12:19 PM
    MacFly
    But just to be completely clear, once you go 1.05 can you ever flash back to factory stock, even if you don't get the TSB?
  18. Nov 1, 2018 at 12:22 PM
    Supr4Lo
    Surprise, AZ
    As far as I understand you can. When Matt released the 1.05 files to the manual guy's last night he said if there are any issues flash back to stock.
    dingel5 and go2cnavy like this.
  19. Nov 1, 2018 at 12:26 PM
    Supr4Lo
    Surprise, AZ
    You don't have any weird communication drivers running in the task bar or background do you. If so disable them. I did that before hand, but I use my computer for automation programming so I got all kinds of crazy services running at start up. Just a thought....
    riz_atx and speedtre like this.
  20. Nov 1, 2018 at 12:26 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Luckily... or unluckily, my stock battery died within 6 months and instead of getting the dealership to replace I put a X2 Power / Northstar AGM batter in there and no matter what I pretty much always have a solid 13v for flashing, no tender or trickle needed... FWIW
    dskakie, SC4333, dingel5 and 2 others like this.
Thread Status:
