Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Nov 2, 2018 at 6:38 AM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    I have to say the TSB is nice, changes a little too early but has decent pull and is smooth.
    Reypac24 and riz_atx like this.
  2. Nov 2, 2018 at 6:47 AM
    lanmaster53
    lanmaster53 Well-Known Member
    Tim
    2019 Tacoma TRD Pro Super White 6MT
    OMG this is so money...
    I'm cancelling my appointment.
    So... should I grab 1.04r afterward or just wait?
    Also, is there any way to extract the current map with the flashing tools we have so that I have it later? I like to keep records and have the ability to revert for whatever reason.
    Thanks guys. This forum is amazing.
  3. Nov 2, 2018 at 6:51 AM
    HeyMrCarter
    HeyMrCarter Well-Known Member
    Once you do the TSB you can’t go back to previous non tsb tunes
    speedtre likes this.
  4. Nov 2, 2018 at 6:53 AM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    Non-issue.
  5. Nov 2, 2018 at 6:54 AM
    lanmaster53
    Tim
    Right, but I'd like to have a copy of the post-TSB ECU map to flash with our standard process. Kinda like how Mat provides the stock tuning file when you purchase the tuning package. That way I can flash back to "stock" if ever needed using the usual process and not the techstream process.
  6. Nov 2, 2018 at 6:55 AM
    speedtre
    speedtre Well-Known Member
    DirtySouth
    '17 DCLB TRD OR AT 4x4
    1.04B>1.04>TSB IMHO having had all three, I would not change to the TSB from 1.04 without throwing 1.04R on top of the TSB...but I don't think everyone agrees with me....YMMV
    dingel5 likes this.
  7. Nov 2, 2018 at 6:56 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    Do understand there are risks involved with doing the TSB yourself, it isn't fool proof.... it may be easy but if something happens then you're going to have a bad day.
  8. Nov 2, 2018 at 6:56 AM
    lanmaster53
    Tim
    That's what I figured. But what's the process of getting 1.04r? Filing a ticket with OV? Man, i don't want to be that guy right now, lol.
  9. Nov 2, 2018 at 6:57 AM
    HeyMrCarter
    Yeah you could read and save the factory TSB tune or ask for it from mat
  10. Nov 2, 2018 at 6:57 AM
    lanmaster53
    Tim
    All the more reason why I'd rather have a file I can flash using OV's system rather than the techstream approach.
  11. Nov 2, 2018 at 6:59 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Currently the TSB can only be applied using techstream because it writes both ECU and TCU simultaneously, and changes the seed key.
    If you do have one of our kits, there is virtually no risk to doing it from home because if techstream fails you can recover the ECU with our kit.
    If you do not have our of our kits, be careful.
  12. Nov 2, 2018 at 6:59 AM
    HeyMrCarter
    I think You have to use techstream to do the TSB originally. Once it’s done and your ECUID updates you can flash back to it with the OVtune method.
    But the original flash is through techstream
  13. Nov 2, 2018 at 7:06 AM
    lanmaster53
    Tim
    Perfect. I've got a kit. What's the process for getting 1.04r? I've already got 1.04 from when I purchased the kit. If it's too much trouble, I'll wait for 1.05... or become a tester. Up to you.
  14. Nov 2, 2018 at 7:07 AM
    JackwagenR
    JackwagenR Well-Known Member
    Jack
    2017 Silver Sky Metallic Tacoma TRD Off Road Double Cab 6' Bed V6 4x4 AT
    Stock
    Same here lol flashed to the TSB last night and had no issues. Thanks everyone that posted earlier how to do so.
  15. Nov 2, 2018 at 7:19 AM
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    An easy way to see if the TSB symptoms are there, and you are need of them is to do the following, preferably on clear streets. I experienced all of these issue repeatedly and I am in S Fl so my altitude is about 15-50 foot above sea level. It is clearly NOT an altitude problem.
    4 lane road, sit in the suicide lane to make a left.
    When you have a sufficient opening, not one big enough for the Chinese army just a safe one for your truck to go through, floor it.
    Start counting seconds when your foot hits the floor
    IF you count more than 1.5 seconds and your opening was closing so much you are now concerned you will not make it ac cross traffic alive... you have the delayed take-off
    IF when you take-off it launches and even after you remove your foot from the skinny pedal the engine continues to rev up and accelerate, you are in need of the TSB.
    IF you can hold the pedal steady at 40-43 MPH and without changing foot pressure your truck randomly, meaning no discernable change in terrain, decides it should be going over 50 and begins to suddenly accelerate you have the symptoms and needs the TSB.
    Since I applied the TSB (Still on stock tune) I have not experienced these problems. I still have clunks and some delays when changing from decel to accel, such as during a city turn.
    Yes both TSB numbers apply the same calibration file to correct the issue.
    dingel5, Inferno__Taco and speedtre like this.
  16. Nov 2, 2018 at 7:21 AM
    Doogle
    Doogle Well-Known Member
    Jonathan
    2017 Black Tacoma Dbl Cab
    I had the dealership flash mine yesterday and they did OP#TC1601 which pulls up T-SB-0077-16 and I was like dang that was an old one. Well I read my ECU last night and I’m 04B04 now.. 1.05 Insane
  17. Nov 2, 2018 at 7:31 AM
    IB87
    IB87 Member
    Ismael
    2017 Tacoma trd off road
    Been patiently waiting for 1.05 dongle-less while sipping on a 14 year balvenie Caribbean cast. If you haven’t tried it get one it’s worth it. Now I go to sleep
  18. Nov 2, 2018 at 7:38 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Do you perhaps have the CUW file of 04B04 so I can flash the tsb myself?
  19. Nov 2, 2018 at 7:40 AM
    OVTune
    OVTune
    I will be out all weekend working further on 1.05 AT.
    MT owners have provided us with plenty of logs to review as well which I appreciate.
    I am sorry for all the frustration and delays on 1.05. I will post here throughout the weekend everything that is being done with some log data.
    Also please don't overthink the TSB. If you need it, get it. If you want it, get it. I know this thread can get confusing very quickly regarding everyone going on at the moment.
    MCDavis, dskakie, dingel5 and 9 others like this.
  20. Nov 2, 2018 at 7:48 AM
    lanmaster53
    Tim
    Do your thang, brother.
Thread Status:
