Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Nov 4, 2018 at 3:58 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    Has anyone checked the logs on the ecu with techstream?
  2. Nov 4, 2018 at 4:05 PM
    Sean73T
    Sean73T Well-Known Member
    Sean
    SoCal
    17 Pro
    I'll take a look when I start playing with the next flash.
    Tac0Tic0 likes this.
  3. Nov 4, 2018 at 4:10 PM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    Hype tech only adjust the displayed speed in the cluster.
    I know for 18+ the cruise speed displayed for TSS is not effected by the hype tech module. So your speedo and cruise speeds won’t match.
  4. Nov 4, 2018 at 4:14 PM
    commbubba19
    '23 TRD PRO
    That’s what’s great about running 4.88’s. The load is greatly reduced so the truck doesn’t always think it has to downshift.
    Really 4.88’s are a dream compared to stock.
    Except for the clunk coming to a stop and a still numbish gas pedal my truck drives great.
    BlkTaco47 and SC4333 like this.
  5. Nov 4, 2018 at 4:16 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Good luck with that. We've been begging him since day 1 to incorporate a speedo adjustment in the tune. Don't hold your breath.
    I just went with the hypertech and it works for me.
    KTJO 4x4, MCDavis and perkj like this.
  6. Nov 4, 2018 at 4:29 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    I have all the communications protocols and information on how to reprogram the dash / speedo..with no way to implement it yet
    tdnick, gulzeb, SC4333 and 17 others like this.
  7. Nov 4, 2018 at 4:32 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    RIP
  8. Nov 4, 2018 at 4:41 PM
    07taco
    07taco Well-Known Member
    san antonio
    2017 taco trd dclb
  9. Nov 4, 2018 at 4:42 PM
    JJ18ORDBSBMT
    JJ18ORDBSBMT Well-Known Member
    1.05 FOB 91 2018 Off road White DC M/T
    Exactly. Scope creep.
    Mike O and TEXAS BS like this.
  10. Nov 4, 2018 at 4:45 PM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    Sent let me know if it went through okay
    07taco[QUOTED] likes this.
  11. Nov 4, 2018 at 4:47 PM
    07taco
    san antonio
    2017 taco trd dclb
    Thanks
  12. Nov 4, 2018 at 4:59 PM
    speedtre
    speedtre Well-Known Member
    DirtySouth
    '17 DCLB TRD OR AT 4x4
    Go ahead and quote me where I said I speak for everyone here...I'll wait. It's perfectly acceptable to disagree with people, it's OPTIONAL (see what I did there .:)) to be pleasant about it...go ahead and give that option a shot more often, you might even like it...:thumbsup:
    inksin and Anchovy like this.
  13. Nov 4, 2018 at 5:07 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    Yep I remember you mentioning this. That’s why I’m sort of holding off on hypertech.
  14. Nov 4, 2018 at 5:10 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    So the digital display of speed doesn’t change?
  15. Nov 4, 2018 at 5:15 PM
    speedtre
    DirtySouth
    I went to the NOGA mountains for the second time today since I flashed 1.04R....the shifting, or rather the lack thereof, in the foothills and cruising on the highway is SOOOOO much better than stock. I'm really looking forward to 1.05 but 1.04R is pretty good...not once today did I want to run it into a tree off the highway. That was a regular occurrence with the stock tune and with 1.03 even...:D
    dingel5, dskakie and Tac0Tic0 like this.
  16. Nov 4, 2018 at 5:15 PM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    The speed display for the CC is lower than the speedometer display speed with the Hypertech installed. However, if you're doing 70 MPH and set the cruise, it stays at 70 MPH. Only the CC display is wrong.
  17. Nov 4, 2018 at 5:16 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    So you’re saying if my analog gauge is reading 70, the digital gauge will read lower?
  18. Nov 4, 2018 at 5:17 PM
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
    So I just flashed to 04b04. Idling it right now. How does one go about getting 1.04r?
  19. Nov 4, 2018 at 5:18 PM
    dpippel
    Phoenix, AZ
    I'm saying that if you're doing 70 MPH (speedo) and set the cruise control, the small speed display next to the cruise control icon might read 65. You're still setting your actual speed to 70 MPH when you engage the CC. The speedo is accurate, the CC display is not.
  20. Nov 4, 2018 at 5:25 PM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Yep. I especially like how it uses a combination of the the torque converter, higher rpms, and Otto cycle to pull when needed instead of immediately downshifting - at least that’s what it feels like to me. Before 1.04r, any need to maintain speed in 5th or 6th was met by a downshift. To me it feels very similar to slipping the clutch on my dirt bike to keep rpms in the powerband. BraaaaaP.
    speedtre[QUOTED] likes this.
Thread Status:
