Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Nov 8, 2018 at 5:36 PM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    This was yesterday. Went about 15 miles past zero going 80mph.
    hbaade and Tac0Tic0 like this.
  2. Nov 8, 2018 at 5:44 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Fuely is so much easier... and free. But I recall doing it that way back when.
  3. Nov 8, 2018 at 7:34 PM
    BB2017
    BB2017 Well-Known Member
    So Cal
    2017 Tacoma TRD sport
    Maxtrac 4" spindles, old man emu medium leaf packs, Bilstein 5100 struts and extended length shocks, Mamba M13 17x9 -12mm offset wheels, 3/4" wheel spacers on rear wheels, BF Goodrich LT 265/70R17 KO2 tires, OV tune 1.04, Rough Country steps, Morimoto LED amber Fog Lights, Meso Customs Limited edition Ultimate LED turn signals.
    No, you don't have to flash back to stock first. After you get the TSB you can request 1.04R from Mat, and hopefully 1.05 will be out shortly.
  4. Nov 8, 2018 at 7:37 PM
    perkj
    perkj Well-Known Member
    Not shortly, but soon
    BB2017[QUOTED] likes this.
  5. Nov 8, 2018 at 7:42 PM
    BB2017
    So Cal
    Those that oppose this are right. That's a horrible practice that will eventually damage the carbon canister and cause a check engine light. Which will eventually cost more money to fix. Not sure getting 15-30 more miles per fill up is worth it. Plus you this will most likely decrease the life of your fuel pump which is submersed in fuel to help it stay cool.
    termaesam, gulzeb and SpeySquatch like this.
  6. Nov 8, 2018 at 7:43 PM
    SpeySquatch
    2016 TRD OR DCSB
    I recommend you don’t ever lift your truck. The change in numbers will make you nuts
    TFly, PB FAB and Hank Heel like this.
  7. Nov 8, 2018 at 7:58 PM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    I’ve had stumble since new, flashed tsb to 04b04, then 104r and still have stumble at 1500 rpm to 2000 rpm accelerating from a stop.
    sundogbrew likes this.
  8. Nov 8, 2018 at 8:15 PM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    did you test 04b04?
  9. Nov 8, 2018 at 8:20 PM
    Fiatdave
    Fiatdave The predator in her natural environment!
    David D
    King City Oregon
    17 TRD AC-OR-no pavement princes!
    Icon stage 4 lift, CBI T3 bumpers, front and rear w/swing our tire, 2 jerry can holders and camp table, full CBI skid, Snug Top Rebel canopy. Nitto trail grapplers on ATX Baja wheels times 5. Old taco totalled new taco on tap!
    I had a revtech on my first 17 taco. It was pretty good and cheap. If you can do the work yourself the its less that 500 for the parts and alignment.
  10. Nov 8, 2018 at 8:33 PM
    Reluctanse
    Reluctanse Granny shiftin, not double clutchin
    Sam
    Newberg, Oregon
    '17 Tacoma DCSB Inferno TRD OR 6MT
    OVTuned, Grabbers, 5100s, Bakflip VP
    Filled up to 22... It was all the way empty.
  11. Nov 8, 2018 at 8:41 PM
    Fiatdave
    David D
    King City Oregon
    Wtf, your gas is cheap! I was 5 miles to empty, went to the shell station with 93, took all $60 and could have taken more.
    gulzeb[QUOTED] likes this.
  12. Nov 8, 2018 at 8:44 PM
    Fiatdave
    David D
    King City Oregon
    20tacoma17 likes this.
  13. Nov 8, 2018 at 9:39 PM
    houser1995
    houser1995 Well-Known Member
    Hunter
    Clarendon Pennsylvania
    2017 DCSB 6MT Trd Sport (Ovtuned)
    -Bds 6 in. lift, Fox factory 2.5 coilovers with dsc + remote res and factory 2.0 shocks with comp adjuster + remote res. -Fab fours front bumper -Method MR305 wheels -35/12.50 R18 Milestar Patagonias -Header back 2in. I.D. true duals with 2nd cat deleted (X pipe turbo muffler) -Af Dynamics Intake -Ovtuned running 2.0 SFOB Premium tune with @92ehatch and @tonered throttle edits (1st version with high tip in and sensitivity) -URD Stage 3 clutch (Ceramic/Kevlar) -Custom trail rash and dented bedside
    Yeah my bad it got a Lil off topic but tire size/lift and engine mods should be talked about in my opinion. This thread is the reason I shelled out 770 dollars on a truck I just paid 41k for. And I was curious about anyone running the tune on 35s for sure. You realize how many tunes this thread alone sells? Its one of the first results when you search ovtune on google and the only one that comes up when you google 2016 tacoma ecu,tune,reflash ect. And if It sold me then I'll bet there's hundreds more. On 35s I was at 11mpg and it literally jumped 3 mpg in the first 100 miles. If more people would post about their gains on their setups I'm sure there wouldn't be so many people on edge about ordering Cus for once what seemed like it was too good to be true was actually true the tune works and was more than I imagined and I'm only on 1.04r
  14. Nov 8, 2018 at 10:16 PM
    SpeySquatch
    2016 TRD OR DCSB
    Great...getting the TSB tomorrow morning
    dingel5 likes this.
  15. Nov 9, 2018 at 3:52 AM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    I use 87
  16. Nov 9, 2018 at 4:43 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Try driving on the TSB for a bit before immediately flashing 1.04r
    I don’t get the stumble on the TSB but it is present on 1.04r - of course you give up some ponies but as of now the TSB is the smoothest running calibration available for MY truck until 1.05 drops
    PB FAB and acemastr like this.
  17. Nov 9, 2018 at 7:38 AM
    sundogbrew
    sundogbrew Well-Known Member
    Joe
    2016 Blue TRD OR Double Cab
    Still, 87 here is right around $3. 93 is the better part of $4.
  18. Nov 9, 2018 at 7:42 AM
    Lt_Dan
    Lt_Dan Well-Known Member
    Daniel
    Cincinnati OH
    2017 TRD OR 4x4 DCSB A/T Super White
    What's the TSB number that will take me from 04B02 to 04B04? My dealership has been pretty good when it comes to TSB when I show up with the number and tell them that I want it done.
    Chipi3s likes this.
  19. Nov 9, 2018 at 7:55 AM
    SpeySquatch
    2016 TRD OR DCSB
    I am lifted with weight, but I will try it. The 1.04r files are just for flashing the ECU right? Not the TCU?
  20. Nov 9, 2018 at 8:03 AM
    digitaltree515
    digitaltree515 Well-rounded nerd
    Mark
    GA
    '17 Inferno TRD OR
    T-SB-0062-18
    Lt_Dan[QUOTED] likes this.
Thread Status:
