Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Nov 12, 2018 at 4:42 PM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    Like how Tfly said, advancements in fuel management, distribution and such with direct injection and computers has made it much safer to run on the edge of "too lean" nowdays. Gone are the days of running a lean mixture and 3 valves burned and the rings melted on 2 cylinders cause the intake manifold had some flow issues.
    I'm all for all the extras ESPECIALLY the tire size converter. I've been holding off on buying one for over a year now in hopes that this would be a reality!
    Is there any chance the tune is considered good to release and all the fluff can be added in as part of the custom tuning option?
    niko5055 likes this.
  2. Nov 12, 2018 at 4:50 PM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    TSB = technical service bulletin. TSBs are issued to tell dealers how to do a certain repair if certain issues are present. In this case there are a couple of TSBs (you can search for them, but i think tsb 0062-18 and 0058-18) that say update ecu programming to address some issues with driveability. The latest tune for automatics is 04B04, so thise TSBs update to it.
    Egnaro likes this.
  3. Nov 12, 2018 at 4:59 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    People will pay big money to fix the speedo.
    I can’t wait for 1.05!!!
    :goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy:
    Egnaro likes this.
  4. Nov 12, 2018 at 5:08 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Noooooooo. :)
    That fluff is real meat.
    :woot::woot::woot:
    speedtre, dingel5 and inksin[QUOTED] like this.
  5. Nov 12, 2018 at 5:20 PM
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    How is 1.05 for towing? Any special treats that we can look forward to having?
    :bananadance::bananadance::bananadance:
    GPatriot likes this.
  6. Nov 12, 2018 at 5:21 PM
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    Well, yeah. The conventional wisdom in the piston airplane world was ~75* rich of peak. The new wisdom is ~35* lean of peak. That’s degrees C. And my numbers could be off. It’s been years since I flew a piston.
    Anchovy[QUOTED] likes this.
  7. Nov 12, 2018 at 6:01 PM
    inksin
    Hawaii
    lol, trust me, I WANT the meat (in the most heterosexual way), the only reason I mention it is that things like tire size is still trying to figured out how to be implemented as well as a few other things are being developed but are not sure if they will be in the 1.05 update or not while other things are certain to be in there and are being figured out now. IF the tuning part is done being fine tuned then releasing it while the rest of the stuff would calm a bunch of nerves in here and keep the heard pacified till the "gravy" is released.
    If it's not done being fine tuned then that's all good too, the wait will continue regardless, was just a brainfart after reading the update.
  8. Nov 12, 2018 at 6:05 PM
    Doogle
    Doogle Well-Known Member
    Jonathan
    2017 Black Tacoma Dbl Cab
    Sorry boss I should have went back a few pages and I would have seen you pretty much asked my same question. I’ll email him from now on
    TWTaco[QUOTED] likes this.
  9. Nov 12, 2018 at 6:22 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Pretty exciting updates! Clearly you decided to work on more than just shifting though I realize much of the updates, in the end impact the torque models that control shifting. Take the time you need
    Egnaro, Shellshock and Doogle like this.
  10. Nov 12, 2018 at 7:15 PM
    LDS 77
    LDS 77 Well-Known Member
    2016 OR
    Waiting on my doorstep when I got home from work today!
  11. Nov 12, 2018 at 7:16 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Speedo cal in 1.05... now you’ve peaked my interest
    KTJO 4x4, Shellshock, tjpratt and 5 others like this.
  12. Nov 12, 2018 at 7:25 PM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    piqued*
    Now that I have taught you something new, please make me tail lights with amber turn signals for <$300.
  13. Nov 12, 2018 at 7:41 PM
    treimche
    treimche Well-Known Member
    Fargo, ND
    I'll give it a try then. Can you email me the 1.04R files please? I emailed you asking some questions last Friday, but hadn't heard back. Figured I don't want to be blowing up your inbox with questions and requests, so I was waiting until I got a reply. My email is treimche@gmail.com.
    Tac0Tic0 likes this.
  14. Nov 12, 2018 at 7:46 PM
    Motorrad
    Motorrad Well-Known Member
    +1 this bothers the heck out of me
    KkelX4 likes this.
  15. Nov 12, 2018 at 7:53 PM
    SpeySquatch
    2016 TRD OR DCSB
    1.04r is pretty sweet man. My truck is 6000lbs and it scoots nicely. The smooth shifting and throttle response is better than 1.04 clearly
    As always. Formulate a true opinion after 200 miles
    Tac0Tic0 and treimche[QUOTED] like this.
  16. Nov 12, 2018 at 8:05 PM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Just send him an email requesting files.
    digitaltree515 likes this.
  17. Nov 12, 2018 at 8:38 PM
    KkelX4
    KkelX4 Well-Known Member
    2017 Tacoma TRD OR
    RTT Rack
    Holy shit yes this. Since day fucking one.
  18. Nov 12, 2018 at 9:10 PM
    edyuen888
    edyuen888 Well-Known Member
    18’ Cement DCLB
    OV tuned, 5100’s, airbags, k02s.
    Anyone wanna comment on this comment?
  19. Nov 12, 2018 at 9:20 PM
    RushT
    North Texas
    Sure.... we all have opinions?
    Turd Hawg and edyuen888 like this.
  20. Nov 12, 2018 at 9:22 PM
    TelosHedge
    TelosHedge tiny moron
    Central NC
    18 Inferno Sport DCSB 4x2
    So homeslice is ok with slapping on any old bolt-on mod, but is afraid that a master tuner across multiple platforms is gonna leave a 10 year problem-festering hole in a fuel map somewhere? You mean like the one that came with the truck?
    Also, why does he get to have 'over a decade of professional experience' (in what sounds like software design for something maybe not related to cars?) when Mat only gets to be 'god knows who, regardless of his history in the area?'
    Sorry, I don't like to get personal on the internet, but sometimes you gotta stand up for the good guy.
Thread Status:
