Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Nov 13, 2018 at 7:17 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Easy way to prove/disprove this theory:
    Anyone running the hypertech only need monitor the proper PID via scan tool or laptop/techstream to see if there's a difference between the cluster and what the ECU is seeing WRT veh speed. From what I've managed to pull from the 3rd gen SM, the path for speed data is:
    Wheel sensors > skid control ECU > instrument cluster > ECU.
    You read that right, it hits the cluster before the ECU (at least one path does).
    SC4333 likes this.
  2. Nov 13, 2018 at 7:24 AM
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    Ya it’s colder :canada:A
    Shellshock and BlkTaco47 like this.
  3. Nov 13, 2018 at 8:10 AM
    Atl_taco_
    Atl_taco_ Well-Known Member
    Sam
    ATL
    2017 MGM OR
    I just got my dongle kit, having trouble getting the grddrivers installed so that the pcflash manager can see the dongle plugged into my PC to send to Mat. Any ideas?
  4. Nov 13, 2018 at 8:22 AM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    Email the helpdesk
  5. Nov 13, 2018 at 8:32 AM
    Atl_taco_
    Sam
    ATL
    2017 MGM OR
    I did, sent in some screen shots. Just checking the forum if anyone had any ideas / came across this before since they seem a bit bogged down. Not directly trying at all to get Mat to answer me here.
  6. Nov 13, 2018 at 8:43 AM
    Shellshock
    Iowa
    No one ever complains about having too much power, only when there isn’t enough
    shakerhood likes this.
  7. Nov 13, 2018 at 8:46 AM
    digitaltree515
    digitaltree515 Well-rounded nerd
    Mark
    GA
    '17 Inferno TRD OR
    Install the drivers then run the TRU utility in the attached file. Make sure you install the drivers BEFORE plugging in the dongle, then plug in, let the drivers setup, and then run the TRU. If you still can't get it to run, I'll fire up my laptop and pull the driver files directly from the OS and send them to you.
    • GRD.zip
      File size:
      12.9 MB
      3
  8. Nov 13, 2018 at 8:52 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    Have you seen a drawing or something? I don’t see how @OVTune can change the displayed speed then...
    I hope someone here has hypertech and can check.
    MOC221_[QUOTED] and bshammer0 like this.
  9. Nov 13, 2018 at 8:52 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Im just gonna say that putting bolt on parts is far more risky than a tune
    Tac0Tic0 likes this.
  10. Nov 13, 2018 at 9:13 AM
    Atl_taco_
    Sam
    ATL
    2017 MGM OR
    Thank you. I was able to get the TRU to run and have sent the code over to OVtune. The PCflash doesn't show a dongle (or anything) in the dropdown, is this normal? Or is this because I plugged the dongle in before the GRD drivers were installed? Any ways around this now?
  11. Nov 13, 2018 at 9:13 AM
    MOC221_
    Frank
    Inferno__Taco likes this.
  12. Nov 13, 2018 at 9:22 AM
    digitaltree515
    Mark
    GA
    '17 Inferno TRD OR
    That's normal. As long as you don't get a "dongle not found" message, then it's working.
  13. Nov 13, 2018 at 9:24 AM
    E$Yota
    E$Yota Well-Known Member
    Ethan
    Dothan, AL
    2016 Tacoma TRD Sport 4X4
    FN wheels' version of the TRD Pro 4Runner, TRD Pro front skid plate, Low Range Offroad 3/1 lift, JBA Offroad upper control arms, TRD Pro Shift knob, OV Tuned, 4.88s, 285/70/17 BFG KO2s
    Bigger tires change the speedo gear swaps do not. I have a Hypertech speedo calculator for the 33s I have...
    honey likes this.
  14. Nov 13, 2018 at 9:36 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Wouldn't this be ideal now to configure the speed correction to optimize the shift points rather than reprogram the shift point manually now? Assuming speed and loads are variables within the gagillion tables.
  15. Nov 13, 2018 at 9:36 AM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    I use Windows 7 and my dongle only works if I boot to safe mode with the ignore driver signing option. Ymmv
  16. Nov 13, 2018 at 9:38 AM
    hr206
    Western Washington
    "My vehicle has too much power, I should've gotten the small engine", said nobody ever.
  17. Nov 13, 2018 at 10:02 AM
    Atl_taco_
    Sam
    ATL
    2017 MGM OR
    The p5flash that I downloaded runs a utility called ToyFlash 1.0.0, looks similar to the instructions but the instructions I have show it called PCMFlash 1.1.92. Any chance you can send that .zipped? The dongle instructions and links are all scatterred.
  18. Nov 13, 2018 at 10:08 AM
    digitaltree515
    Mark
    GA
    '17 Inferno TRD OR
    I'm not sure if @OVTune wants me to upload the flash manager here. If he blesses it, I'll upload it. Even though the pcmflash needs to be registered with the dongle, the flash manager will allow download of the tune files and that's been an issue lately.
  19. Nov 13, 2018 at 10:10 AM
    Atl_taco_
    Sam
    ATL
    2017 MGM OR
    Okay, no worries, just trying to figure out what I'm supposed to do to get this tune onto my computer. Thanks for helping.
  20. Nov 13, 2018 at 10:14 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
Thread Status:
