Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Nov 14, 2018 at 1:53 PM
    Shellshock
    Iowa
    I’ll have 3,000 miles on 1.05 tonight
  2. Nov 14, 2018 at 2:08 PM
    MT-TACO
    MT-TACO Well-Known Member
    Edward
    3rd-Gen
    Thanks shellshock
    I thought that , just wanted to double check
    I can't seem to DL the 1.04R file , and i know the installing system seem to change a bit from when i first upload the tune
    Hopefully there will be some instruction for the Dongle ,
  3. Nov 14, 2018 at 2:16 PM
    ohioboater
    ohioboater Well-Known Member
    2017 DCLB 4x4 Sport
    *LIGHT BULB GOES ON*
    Now all of those bizarre stock shift behaviors that I hated make sense. Well, ok, they still don't make sense, but at least I think I understand why they used to happen. Because there's no differentiation between up and down, the truck just grabs whatever gear happens to be the closest match to the ideal set of parameters, even if that gear choice is completely stupid given the driving context.
    taco 16, Slickwhenwet and Shellshock like this.
  4. Nov 14, 2018 at 2:18 PM
    Frito
    Frito Well-Known Member
    "The Intern" then fluffed it off unfinished on an unsuspecting yet trusting public (Us)
    Those of us that knew what this truck should really drive like thought we were focked and then, Mat entered the picture...
    Shellshock[QUOTED] likes this.
  5. Nov 14, 2018 at 2:32 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    yes exactly. It's definitely a *new* way of doing things. and has made it that much more difficult to tune (before).
    When you think about it, it is actually a really smart way giving the transmission a high degree of "shifting freedom"... basically saying "lets determine the limits only, and let the ECU calculate everything else). Therefore, you the driver will never, ever be in control of the transmission completely. Your accelerator pedal (right foot) only determines 1 piece of the equation to tell the transmission what to do.
    Like this : Shift = A + B + C + 1(D * F) (and your foot is F).. A, B, C, D is completely under the ECUs control.
    Thinking about it is really funny.. you floor it expecting 3rd gear and the ECU says hmm no lets go to 5600 RPM in second and shift 0.5 seconds later. Why, because it's Within the limit boundary. hah
    Reality is though the transmission goes completely insane.
    Best news I can give you is when I tested out disabling all other tables the transmission acted exactly like transmissions did 10 years ago. It would always shift at the predetermined points (axle speed) based on throttle angle. Every time.
    Now, we can create a shift curve so that it shifts at a rising curve based on accel angle... and it will use ONE! Table to determine transmission output torque.
    I'll have a video of it soon.
    The transmission didn't feel loose and sloppy.
  6. Nov 14, 2018 at 2:42 PM
    Shellshock
    Iowa
    Does any of this new stuff you’ve found also affect the MT in any way? I thought you’d mentioned at one point the MT also has some funky table speed voodoo thing
    mZiggy likes this.
  7. Nov 14, 2018 at 2:47 PM
    OVTune
    OVTune
    Not really. The MT is simpler, and uses 3D accelerator table to torque conversion tables to make it all work.
    But those same tables control response for each gear, and can be tuned. It's why 3rd gear may feel amazing and 5th may feel like a dead fish (for example)
    WalkinTaco, dingel5, KTJO 4x4 and 4 others like this.
  8. Nov 14, 2018 at 3:01 PM
    Frito
    There is a time for "Loose & Sloppy" and This ain't it ! :rolleyes:
    Good sleuthin' Mat. Not only am I impressed but I'm glad you're still interested in getting to the bottom of this.
    Some days it seems like a couple of guys here think it's your responsibility to make this truck run right and lose sight of the fact that your name isn't "Toyota".
    Money aside it seems like a personal thing for you to find out where things went wrong and make it better.
    In my mind, it should have been "them" doing for us what you have done.
    Just the same I'm just grateful it is getting done and no-one has pissed you off to the degree of you saying;
    "Sorry boys, that's all I can do".... and walking away. My hat is off to you ! :hattip:
    ihatemytruck, Lt_Dan, PhogDog and 9 others like this.
  9. Nov 14, 2018 at 3:16 PM
    dskakie
    dskakie Well-Known Member
    Dan
    Northern CA
    2016 TRD OR DCSB
    Lots of awesome and exciting info today and yesterday, thank you Mat @OVTune! 1.05 should be great!
  10. Nov 14, 2018 at 3:20 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    And the problem with that is that the driver (of an OEM tuned truck) never ever knows for sure how the vehicle is going to respond. :annoyed:
    Frito likes this.
  11. Nov 14, 2018 at 3:36 PM
    Frank_Zuccarini
    Frank_Zuccarini Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    Thanks for the insight. KNOWING what is going on really helps us DEAL with what is going on. Glad you are continuing to make progress.
    Frank
    Saeros, Inferno__Taco and honey like this.
  12. Nov 14, 2018 at 3:36 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    This the best news I’ve heard all day, cant wait once it’s all dialed in
    honey likes this.
  13. Nov 14, 2018 at 3:41 PM
    joey.taco
    joey.taco Well-Known Member
    2018 Toyota Tacoma OR DCSB
    gooooood ole navy, shipmate... I mean service member.!
  14. Nov 14, 2018 at 3:42 PM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    This is great news. Drive by cable was so much easier.
    How many variables are you using when determining the prescribed shift curve?
  15. Nov 14, 2018 at 3:42 PM
    Egnaro
    Egnaro Watch this
    Brett
    AZ
    16 Inferno DCSB Offroad 4x4
    Ricochet full skids, Mobtown rear with swing-out, toytec boss 2.0, OV tuned
    Can i like a post more than once?
    Reypac24 likes this.
  16. Nov 14, 2018 at 3:44 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    My bad, I misread your post. :cheers:
    Anchovy[QUOTED] likes this.
  17. Nov 14, 2018 at 3:45 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    No worries :cheers:
  18. Nov 14, 2018 at 3:48 PM
    go2cnavy
    Damn you. Stop it already.
    catastrofe likes this.
  19. Nov 14, 2018 at 3:54 PM
    go2cnavy
    I think we’re lucky that he owns a Taco and is now hooked on TacoLife. I am amazed at his patience with chuckleheads in this thread.
  20. Nov 14, 2018 at 4:11 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Major breakthroughs here and it does actually make sense in the context of someone who's been driving this slushbox for the last 2 years and scratching my head numerous times wondering why the trans behaves the way it does, learning is one piece of it but even the learning isn't AS bad on the TSB but the timing of up/downshifts can still be very erratic even though the TSB has smoothed them out quite a bit. A true, predictable shift curve that takes the "what the hell is happening" out of driving this truck would be a huge deal. And if you nail it, I'd suggest hiring more staff to keep up with orders and tickets so you can head to Africa and watch that "mailbox money" roll in :)
    ihatemytruck, Shellshock and Reypac24 like this.
Thread Status:
