Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Dec 19, 2018 at 4:58 PM
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    Same here :pccoffee:
    ... I have a 99.999999% feeling we will not be in a pelfreybilt situation though. If we don’t see that change by tomorrow, get comfortable, we won’t for at least another week.
    peavey02 and bshammer0 like this.
  2. Dec 19, 2018 at 5:11 PM
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    I had a similar issue...it took several days for UPS to show an update after Mat’s confirmed ship date.
    Marbleyard likes this.
  3. Dec 19, 2018 at 5:18 PM
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    i really dont think you can get much more, if any engine braking using the valves because there is very limited air do to the closed throttle plate and low compression.
    diesel engines dont have a throttle plate thus require valve manipulation to take advantage of the higher compression ratio to give it effective braking force.
    i personally dont like the idea of modifying the valves for this purpose,but i am willing to try as i could be wrong.
    as for DFCO, it would be AMAZING!!! if we hard wire it to a switch and mount it to the shifter (like on a semi)but that's definitely a far shot.
    so for now you will be seeing this more often. DFCO :frusty: REVHANG :frusty: hopefully MATT will notice and have some mercy? :notsure:
    Shellshock and MOC221_[QUOTED] like this.
  4. Dec 19, 2018 at 5:21 PM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    These engines aren't low compression! (they are compared to diesel)
    MOC221_ likes this.
  5. Dec 19, 2018 at 5:22 PM
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    sorry MT bro .got excited someone talking about DFCO and REVHANG, i am doing great :thumbsup: like wise hope.
    MOC221_[QUOTED] likes this.
  6. Dec 19, 2018 at 5:29 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Good to hear, and same here!
    Yeah, once the big tune release is done and we're past the holidays we can get on it again.
    Cheers!
    iexc[QUOTED] likes this.
  7. Dec 19, 2018 at 5:31 PM
    MOC221_
    Frank
    He's talking about when you lift and the engine goes to Atkinson mode (lower compression).
  8. Dec 19, 2018 at 5:37 PM
    Kclamer
    Kclamer Well-Known Member
    Konstantin
    2018 Toyota Tacoma TRD Off-Road 4x4
    2.5" lift, 4.88 gears
    My order was ready to ship for almost two weeks. Mat creates a shipping label and then tries his best to get the packages out as quickly as he can. Remember this is not Amazon, it's a solo act.
    PhogDog and FtWayne Gen3 like this.
  9. Dec 19, 2018 at 5:48 PM
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    no way!!,wow, i will check it out.
    regardless, engine braking is not free energy as it applies force on the engine. the stronger the braking the greater the force the greater the wear.
    the purpose of engine brakes is it is economical on semis as they pull, carry 3 or more times there wait and this is on trucks with 4 axles or more.
    plus i really dont think most of the guys are going to like the sound it makes !! if it works as intended.also keep in mind there are many gas 1 tons that would have benefited from this for while. maybe over-site . hell ,if works MATT should patent it if possible.
    as for me,no way ,DFCO to much a pain in stop and go traffic.:)
  10. Dec 19, 2018 at 6:00 PM
    sixlxvi
    sixlxvi "break stuff"
    It just updated. Thanks guys!
  11. Dec 19, 2018 at 6:00 PM
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    IIRC, an earlier post from Mat said that for the full lock out option the process was shift in S mode, THEN drop down to S1, THEN hit ECT, and you're good to go full lock out.
    If that's the case, simply selecting ECT while in S mode would ('should') be the usual S-mode auto shifting option with the added benefit of ECT. Basically a dual map scenario. At least that's what I'm hoping for...
    Then again, I simply don't have the time to keep up with this massive thread and my memory has gone to shit...
  12. Dec 19, 2018 at 6:25 PM
    MacFly
    MacFly Well-Known Member
    2018 Cement Tacoma TRD Off Road AT
    OVTune, AT Habitat, Firestone RRs, ARB CKMA12 compressor
    Mm, if I recall correctly the talk about needing to be in S1 was just a formality. I *think* S mode (any gear) + ECT button= gear lock with that tune option. But, best to hear it from the horses' mouth, not mine.
  13. Dec 19, 2018 at 6:27 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Nope, mat said he only put the truck into s1 in the video to demonstrate gear lock through every gear
    MacFly likes this.
  14. Dec 19, 2018 at 6:28 PM
    Anchovy
    TRD Ferguson
    But your profile picture is bojack horseman
    MacFly[QUOTED] likes this.
  15. Dec 19, 2018 at 6:29 PM
    MacFly
    Kinda why I went with that saying, lol. I just couldn't think of anything more witty to add
    GF8er and Anchovy[QUOTED] like this.
  16. Dec 19, 2018 at 6:30 PM
    treimche
    treimche Well-Known Member
    Fargo, ND
    @OVTune can I just request the gear lock feature right away with 1.05 and not have to wait on customized options?
    TFly likes this.
  17. Dec 19, 2018 at 7:24 PM
    sig916
    sig916 Well-Known Member
    Insane mode still an option?:fingerscrossed:
    DiabloTRD, iexc and M1Awolf like this.
  18. Dec 19, 2018 at 7:39 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    This, in for 1.05 91 insane mode,someone needs to test it:burnrubber:
  19. Dec 19, 2018 at 7:45 PM
    tjpratt
    tjpratt Well-Known Member
    Travis
    Aurora, Colorado
    2016 Limited 4X4 Tacoma
    3.75" Lift / OME OVTuned
    By the sounds of it there is no MA/FO anymore. Just 1.05.
  20. Dec 19, 2018 at 8:01 PM
    SpeySquatch
    2016 TRD OR DCSB
    Hey Mat, great news! Will you post the blog link here? Or if someone else has the link please feel free...
Thread Status:
