Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Dec 21, 2018 at 1:46 PM
    Doogle
    Doogle Well-Known Member
    Jonathan
    2017 Black Tacoma Dbl Cab
    Just sent u some data to Zendesk. I’m on the 93
  2. Dec 21, 2018 at 1:48 PM
    frito-frio
    frito-frio Well-Known Member
    Gregg
    Nashville Tennessee
    Black 17 Off Road
    2017 Off Road 3" Lift, KMC XD wheels, 305/70r16 KO2 tires, 4.88 Nitro gears, ADD front bumper, Body Armor rear bumper, 9.5k Rough Country winch, Leer shell, OVTune 1.04R
    Just curious. Could the idle fluctuations by any chance come from the air compressor kicking on and off for the windshield defroster?
  3. Dec 21, 2018 at 1:51 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Thought about that as well so I turned off all load - no air / defrost and even turned off radio or anything that could be spinning up the alternator or anything.
    To be clear, Mat is right, the idle thing doesn't appear to be a MAJOR issue, but for some of us it does bounce when sitting in D idling. Very impressed @OVTune is reacting quickly to the feedback to adjust for this small item.
    Unless you were sitting in traffic, bored or have an aftermarket intake/exhaust that magnifies this sort of thing you could likely go some time and never even notice it, it's that minor, but it is a "bug" and Mat's doing the right thing by holding off on release to iron out any minor wrinkles before full general release!
    speedtre and Tac0Tic0 like this.
  4. Dec 21, 2018 at 1:51 PM
    Doogle
    Jonathan
    Good ? I did have defrost on for 8 hours today speed 1 but if I hadn’t looked at RPMs I would not have noticed otherwise
  5. Dec 21, 2018 at 1:57 PM
    CrisMag16SPRT
    CrisMag16SPRT Well-Known Member
    Oregon
    16 DCLB TRD Sport (Silver St Cloud)
    275/KO2s, 5100s, Morimoto hids/fogs, OVTune. Softopper.
    I had seen in the past people were flashing the TSB them selves to run 1.04r without going to the dealer. Are they doing that via tune file from mat?
  6. Dec 21, 2018 at 1:58 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    No. Via techstream.
  7. Dec 21, 2018 at 2:00 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    The idle fluctuations are seen in D only with the brake applied. AC compressor was off. Steering held steady.
    I sent in some logs to Mat while it was doing it. I can assure you, he’s actively working on it.
    MOC221_ and bshammer0 like this.
  8. Dec 21, 2018 at 2:02 PM
    CrisMag16SPRT
    Oregon
    ah now thats ringing a bell! I never paid much attention about it before since I was perfectly happy with 1.04. except now the 1.05 thirst is real haha
  9. Dec 21, 2018 at 2:06 PM
    Dan's TRD
    Dan's TRD Well-Known Member
    Dan
    '16 TRD offroad dcsb 6MT
    So probably a stupid question here that I can't find the answer to....But what exactly is Flash Manager and how do i download it, or open it? I assume its not the same thing as p5flash/Toyflash. The only things i downloaded to flash 1.04 was ToyFlash and the Tactrix drivers, Mat had emailed me the tune files as well as the original ecu tune file.
  10. Dec 21, 2018 at 2:07 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    If you have the files, don’t worry about flash manager.
    Flash manager is a way for him to distribute files and updates.
  11. Dec 21, 2018 at 2:09 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    @OVTune
    Mat any chance you can release the 04b13 file for the M/T to see if this idle glitch is present in the manuals as well....;)
    RedBeard1, mZiggy, disk_55FL and 3 others like this.
  12. Dec 21, 2018 at 2:10 PM
    Shellshock
    Iowa
    Ready to be a guinea pig over here :wave:
    RedBeard1 and mZiggy like this.
  13. Dec 21, 2018 at 2:12 PM
    M1Awolf
    Rob
    Montana
    Ditto,I have all evening available and will be putting in a fresh tank of 91 after work in about two hours.
  14. Dec 21, 2018 at 2:12 PM
    chadabear
    chadabear Well-Known Member
    Chad
    Louisiana
    2018 DCSB 4x4
    Where can I find the 04A61 file? Was it released today also??
  15. Dec 21, 2018 at 2:13 PM
    Dan's TRD
    Dan
    The reason I was asking about flash manager was because i would like to be ready to download 1.05 when it becomes available, and as i understood it flash manager is where I would look for new releases.
  16. Dec 21, 2018 at 2:14 PM
    Shellshock
    Iowa
    It’s not available. It’ll be posted with the 1.05 release blog
  17. Dec 21, 2018 at 2:14 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    He posted a link yesterday when 1.05 was available.
  18. Dec 21, 2018 at 2:15 PM
    Shellshock
    Iowa
    Same. I’ve got nothing else to do so I might as well go drive around
  19. Dec 21, 2018 at 2:15 PM
    M1Awolf
    Rob
    Montana
    @chadabear
    Not yet,looks like release is on hold until idle problem is solved...
    chadabear[QUOTED] and Tac0Tic0 like this.
  20. Dec 21, 2018 at 2:21 PM
    Dan's TRD
    Dan
    Ok thanks for the help guys I knew I must have been missing something. I didn't realize that Flash Manager was something released with each new tune, i was under the impression that it was something that you downloaded and stayed the same.
Thread Status:
