Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Dec 22, 2018 at 6:02 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    @OVTune
    I flashed the revised 1.05 and have no issues to report. I've only put about 60 miles on it but between the city and highway driving, all is well. Idle is smooth, shift points are right on par with where they should be, and best of all the highway drivability has increased dramatically.
    The truck does tend to lug around 1200rpm under low load and 30-55mph city driving, however, I do not see this as a problem. The increase in gas milage is worth the sacrifice (is there even a sacrifice, because it doesn't seem so to me..) If acceleration is needed, the truck immediately downshifts, if necessary, and has plenty of power to get it self moving. If light acceleration is needed, it can usually achieve that without even downshifting. All in all I have to say, you knocked it out of the park with 1.05.
    Fiatdave, honey, Mr. Nobody and 8 others like this.
  2. Dec 22, 2018 at 6:14 PM
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    Thats exactly what Mat said here.
  3. Dec 22, 2018 at 6:16 PM
    tacogravy
    tacogravy Well-Known Member
    Gravy
    Mantua, Ohio
    17 TRD OR 4x4 Quicksand 6MT
    TRD Pro Grill, TRD Sport Hood, BAMF Sliders, Bilstein 5100's F&B, BF Goodrich KO2 265/75R16, Old Man Emu 887 Front, Head Strong 3 Leaf AAL Rear (Overload Leaf Left In), OVTuned, De-Badged. Accumulator Delete Mod.
    Same to you Mat, happy holidays!
  4. Dec 22, 2018 at 6:22 PM
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    Exactly
    GF8er[QUOTED] likes this.
  5. Dec 22, 2018 at 6:34 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Same. I’d get it when coming to a cold stop.. but generally only happens once in the first 5 mins of operation but never after that. These trucks are weird
    With 1.05 I was getting clunk coming to a stop with a warm transmission which is something I know Mat eradicated in his own truck with 1.05
  6. Dec 22, 2018 at 6:38 PM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    You can shift 400 rpms higher in s-mode 1st gear vrs d mode.
  7. Dec 22, 2018 at 6:41 PM
    SC4333
    Grant
    FL
    The one thing I find strange is how some of these trucks will exhibit certain symptoms and others wont. I've never experienced the clunk on my '16 and so far have had every iteration of the tune. One thing I did have with the stock tune, which most seem to not have was a significant shift flair under light load, cold start, during the 2-3 shift. Havent had it for a while now and hoping it doesn't come back!
  8. Dec 22, 2018 at 6:48 PM
    SpeySquatch
    2016 TRD OR DCSB
    Letting the truck warm up at least 30 seconds when starting is a must. The truck ALWAYS drives better and all that malarkey about diluting the oil is pure BS. Any car, especially my Subaru drives better when warmed.
    Kinda like doing some sort of warm up before a workout
  9. Dec 22, 2018 at 6:49 PM
    jekerskel
    jekerskel Well-Known Member
    Zach
    Bellingham WA
    2004 SR5 Extended cab 2wd 5 speed
    V-LED low and high beam headlights.
    Define shift flair?
  10. Dec 22, 2018 at 6:55 PM
    SC4333
    Grant
    FL
    The transmission is essentially slipping during the 2-3 shift. I would see a roughly 300-400rpm increase during the shift, and the truck falls on its face until it gets fully into third gear. This whole process would take roughly a full second for the 2-3 shift to actually occur.
    Keep in mind, this was on the stock tune, and occured in early versions of the OVTune. It have not had this occur since 1.04
    EDIT: If you've ever driven a manual, it would be like shifting from 2-3 under light load, WITHOUT letting off the throttle. RPM goes up, truck stops accelerating, then the truck makes it into third gear and all is back to normal.
  11. Dec 22, 2018 at 6:57 PM
    tjpratt
    tjpratt Well-Known Member
    Travis
    Aurora, Colorado
    2016 Limited 4X4 Tacoma
    3.75" Lift / OME OVTuned
    Sounds more like rev matching to me
    SpeySquatch likes this.
  12. Dec 22, 2018 at 7:02 PM
    jekerskel
    Zach
    Bellingham WA
    I have the exact same issue. Have had it in stock and 1.04. Does it in the morning especially and if it has been sitting for an hour or so. Gets stuck between 2nd and 3rd for a second. 1.04 improved it a bit over stock but not much. It hasn’t gotten worse in 21k tho.
  13. Dec 22, 2018 at 7:03 PM
    SpeySquatch
    2016 TRD OR DCSB
    What is this 1.04 you guys keep talking about?
    :boink:
    PB FAB and jekerskel[QUOTED] like this.
  14. Dec 22, 2018 at 7:04 PM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    I've had it since new, various tunes don't seem to affect it. Only happens in cold weather, cold engine while accelerating downhill. Never noticed it in the spring/summer. But this time of the year, guaranteed every morning.
    There were some involved discussion early on. Don't hear anybody mention it anymore.
    jekerskel likes this.
  15. Dec 22, 2018 at 7:05 PM
    jekerskel
    Zach
    Bellingham WA
    Mine won’t do it under hard acceleration in the morning. It’s just under light or moderate.
  16. Dec 22, 2018 at 7:06 PM
    SC4333
    Grant
    FL
    My 'rev matching' automatic :cookiemonster:
    It's a miracle I have kept this truck, to be honest. ALTHOUGH... 1.05 seems to be the cat's ass so far. If it was not for me realizing early on that Mat was / is working his ass off to make a finished product, there is no doubt in my mind the Tacoma would not be sitting in my driveway right now.
    GPatriot, bgoods and jekerskel like this.
  17. Dec 22, 2018 at 7:07 PM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    I’ve found 1.05 puts me in fifth gear even sooner than any other tune, including stock. 5th gear at 32 mph is unacceptable to me, going to be looking into SSP to compensate....oh well. Good luck all.
    5th gear at 32 mph and 950rpm is lugging, anyone that tells you differently is full of it.
    treimche and Frito like this.
  18. Dec 22, 2018 at 7:07 PM
    jekerskel
    Zach
    Bellingham WA
    Mine either. First time I have been truly disappointed with Toyota, and I have owned and driven many.
    speedtre likes this.
  19. Dec 22, 2018 at 7:08 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
  20. Dec 22, 2018 at 7:09 PM
    SpeySquatch
    2016 TRD OR DCSB
    I’m surprised how many people don’t like the Tacoma. I know it had weird ass problems with the stock tune, but this truck goes places others can’t, especially full-size trucks. And it will always have high-resale and life longevity
    Taco for life.
    taco 16, catastrofe, tjpratt and 3 others like this.
Thread Status:
