Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Dec 25, 2018 at 8:48 PM
    SpeySquatch
    2016 TRD OR DCSB
    Yah, I get the theory, but not sure it would make sense, or really provide any change unless you are WOT alot
  2. Dec 25, 2018 at 9:17 PM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Have you had any issues yet with your steering on the 37’s? Reason I ask is because I’ve already replaced tie rods twice on the left side with my 35’s. Going to be on a superduty axle up front soon so it won’t be an issue anymore, but was just wondering.
  3. Dec 25, 2018 at 9:41 PM
    erok81
    erok81 Well-Known Member
    Imposter
    Nope. I’ve had the 37’s for about 8k and around 5k with 35’s before that. Not a lot of miles, but with the ones I have I haven’t had any issues with anything.
    The 35’s probably had 500 or so off road miles and the 37’s around 100.
  4. Dec 25, 2018 at 10:33 PM
    Trident904
    Brian
    17 4Runner TRD OR
    Hmm, I just had to replace the LBJ on the left front too. I’m wondering if it was just bad for longer than I thought and was causing issues.
  5. Dec 25, 2018 at 10:55 PM
    erok81
    Imposter
    Hmm. Mine’s long travel so I don’t have the same ball joint issues. Steering is basically factory outside of some extenders. I’m fairly careful off road so I’m sure that might have something to do with it too.
    Trident904[QUOTED] likes this.
  6. Dec 25, 2018 at 11:59 PM
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    Well well well, Merry Xmas to all y’all. Been lurking around for about 2yrs & finally signed up to the forums. Figured I should go ahead and use my first post to say, I went ahead and ordered up the OVTune kit (#3690) to flash tune a 2019 OR DC LB truck I plan on purchasing next month :woot:
    brohirrim, iexc, Mr. Nobody and 9 others like this.
  7. Dec 26, 2018 at 2:12 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    Much easier to just plug in your laptop, open PCM flash, and press “reset DTCs”
    1bad2k likes this.
  8. Dec 26, 2018 at 2:13 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    Most buy it after they realize their truck sucks at driving! You’re buying it before you even know your $40k truck sucks!
    gulzeb, MrBrooks, iexc and 9 others like this.
  9. Dec 26, 2018 at 5:01 AM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    I destroyed two LBJs and a steering gear on 32’s even with aftermarket UCA’s. I was running about 2.5 of lift. Geometry is everything on IFS. Anything over 2” on our 3GENs make steering components wear out extremely quick.
    SpeySquatch likes this.
  10. Dec 26, 2018 at 5:12 AM
    tjpratt
    tjpratt Well-Known Member
    Travis
    Aurora, Colorado
    2016 Limited 4X4 Tacoma
    3.75" Lift / OME OVTuned
    I'm running 3.75" of lift. With aftermarket UCA's. On a 3rd Gen. Been on it for years. Haven't destroyed anything yet.
  11. Dec 26, 2018 at 5:47 AM
    BB2017
    BB2017 Well-Known Member
    So Cal
    2017 Tacoma TRD sport
    Maxtrac 4" spindles, old man emu medium leaf packs, Bilstein 5100 struts and extended length shocks, Mamba M13 17x9 -12mm offset wheels, 3/4" wheel spacers on rear wheels, BF Goodrich LT 265/70R17 KO2 tires, OV tune 1.04, Rough Country steps, Morimoto LED amber Fog Lights, Meso Customs Limited edition Ultimate LED turn signals.
    Anyone else getting the idle surge with the latest 1.05 files? I updated mine with the original 1.05 91 file and I didn't have the idle surge. I only updated to the newest 1.05 91 file because Mat recommended it and now have a crazy idle surge. I'm going to email Matt today, but just wondering if it's just me.
    07taco and PNWTacoma like this.
  12. Dec 26, 2018 at 5:51 AM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    I've read a couple people have had success with flashing to 1.05 AFTER the engine is at operating temperature.
  13. Dec 26, 2018 at 6:00 AM
    Rainman70
    Rainman70 Well-Known Member
    2016 Tacoma extra cab 6 speed 4x4
    I'm guessing your a test truck?
  14. Dec 26, 2018 at 6:00 AM
    Feltcycle
    Feltcycle Well-Known Member
    2017 Tacoma SR5 4x4
    I am still experiencing idle fluctuations on newest 1.05 calibration. It’s not as bad as original 1.05, but noticeably there. I have emailed Mat my TS logs of the event, but have not heard back.
    Idle on my truck only fluctuates when the truck is warm. I performed flash & idle learn procedure after truck had been driven a while and was at operating temp.
  15. Dec 26, 2018 at 6:01 AM
    BB2017
    So Cal
    I'll give that a try when I get home from work, but the new files were supposed to fix that.
  16. Dec 26, 2018 at 6:05 AM
    BB2017
    So Cal
    I've never been a test truck. I just have the dongle setup.
    Rainman70[QUOTED] likes this.
  17. Dec 26, 2018 at 6:05 AM
    Feltcycle
    2017 Tacoma SR5 4x4
    I was looking over the TS logs at idle and noticed ignition swings from 9 - 32 deg during idle fluctuation. I would assume this is not normal.
  18. Dec 26, 2018 at 6:08 AM
    BB2017
    So Cal
    When I programmed the first time it was after a long drive and idle was really smooth. This last time I let it warm up for about 10 minutes, but maybe it wasn't hot enough. My idle is crazy at times.
  19. Dec 26, 2018 at 6:17 AM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    Getting a shift dance with 05 just easing into the freeway.
    2-3 3-4 4-3 3-4-5 5-4 4-5-6 6-5-6.
    That going from a left turn up a freeway on ramp to 65 with consistent throttle pressure of I’d say 15-20%.
    I see this around town between 40-50 as well.
    Is this something that can be fixed? I’ve duplicated this multiple times.
    paleh0rse and BlkTaco47 like this.
  20. Dec 26, 2018 at 7:05 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Yes, but remember your truck has a weird thing going on with the tables I've not seen on any other trucks
Thread Status:
