Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Dec 26, 2018 at 7:07 AM
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    riz_atx likes this.
  2. Dec 26, 2018 at 7:12 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    You're not seriously "working" today, are you?
    Cripes, it's only the 26th.
    Nobody's truck is going to blow up.
    Hope you had a merry Christmas,
    Cheers
    iexc, nxcess, DakoTaco and 1 other person like this.
  3. Dec 26, 2018 at 7:16 AM
    DSIM
    DSIM Well-Known Member
    Daniel
    Raleigh, NC
    2017 MGM Tacoma TRD Off-Road
    wahoobie and iexc like this.
  4. Dec 26, 2018 at 7:19 AM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    right i know my truck is a bit weird. yay. haha
    however others have reported similar behavior so i assumed maybe it's all related to what was quoted above about the changes made to make sure the truck didn't hang up in 4th.
    hence my question :)
  5. Dec 26, 2018 at 7:27 AM
    Venator_2033
    Venator_2033 Well-Known Member
    4" inch lift Dakar leafpacks/Bilstein 5100 B110/Fox 2.0 coil-overs/Catless Dual Exhaust w/H-pipe/OVtuned1.05/RCI Sliders/HID kits Hi/Low/AFE Intake with scoop and 76mm throttle body/Total chaos Fab UCA's
    I've also noticed the idle fluctions in D and that it only did so once up to temp on the updated 1.05 93 file. I also logged and sent it to OVTune.
  6. Dec 26, 2018 at 7:28 AM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    Remember that a slight rise in revs is the torque converter unlocking, it may seem like it changed down when it just unlocked to get you going a bit quicker
    Reypac24 and Shellshock like this.
  7. Dec 26, 2018 at 7:34 AM
    commbubba19
    '23 TRD PRO
    i know.
    however these are +500 rpm gear changes, not small fluctuations.
    i do notice that it likes to leave the converter unlocked during shifts which also drives me kinda nuts. the truck will shift 3-4-5 with the converter unlocked.
  8. Dec 26, 2018 at 7:39 AM
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    I am having slight idle fluctuations when engine is COLD, on latest 1.05 91. If I put truck in gear before engine is up to operating temp, RPM would jump between ~1000 and ~500. This only occur when I first go into gear and start moving. Rock solid RPM once engine is warm. 265/76/17 Falken tires, otherwise stock 2017 TRD Pro. I had zero idle issues on the initial 1.05 release, but didn’t care for the long first gear shift. I flashed the latest 1.05 twice, on cold and warm engine, idle each time for 20 minutes, didn’t make difference regarding cold idle fluctuations.
    I did notice 4th gear hang couple of times getting on the highway, under moderate acceleration, on either slight grade or headwind.
    I’m confident Mat will figure out the 4th gear hang, might need to figure how to send logs for the cold idle fluctuations. Plan to send Mat video of cold idle later today.
    speedtre likes this.
  9. Dec 26, 2018 at 8:04 AM
    Feltcycle
    Feltcycle Well-Known Member
    2017 Tacoma SR5 4x4
    I’m on 93 file also. I thought about flashing the 91 file to see if it fixes it the idle issue.
    93 file is so nice on the highway. It’s incredible. I have about 250 highway miles on the newest 1.05. Truck hasn’t downshifted to 4th one time at speeds over 70 mph.
  10. Dec 26, 2018 at 8:28 AM
    Venator_2033
    I'm waiting on custom tuning at this point mostly because of my engine mods and since the idle only fluctuates by about 50 rpm so it doesn't bug me. I agree with the highway performance as well my truck stays in 6th quite a bit now. But What would irritate me the most was how the truck performed at low speeds on previous tune versions, so like 40 mph and below, which is so much better with 1.05 93 truck can cruise at 1100 rpm and not feel like it's lugging anymore the truck just feels so much lighter on it's feet Mat's made me love driving my truck finally.
  11. Dec 26, 2018 at 8:49 AM
    chadabear
    chadabear Well-Known Member
    Chad
    Louisiana
    2018 DCSB 4x4
    My truck experienced same thing this morning. Same scenario. I was going to work, getting on the interstate, downshifted and upshifted multiple times. I held the throttle and had to accelerate it past the point to stabilize it. It seemed to do it right at 40-45mph. Mostly between 4th and 5th
    commbubba19 likes this.
  12. Dec 26, 2018 at 9:17 AM
    VersaTrax
    VersaTrax Well-Known Member Vendor
    Nicholas
    2019 Toyota Tacoma
    I wonder if this is truly the only transmission that uses shift tables like this.
  13. Dec 26, 2018 at 9:25 AM
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    Please stop, we need mat to work 16 hours plus over this holiday.1.05 is more important than family.
    MOC221_[QUOTED] likes this.
  14. Dec 26, 2018 at 9:33 AM
    SpeySquatch
    2016 TRD OR DCSB
    Are you letting the truck warm up 30 seconds? This is a must with these new trucks
  15. Dec 26, 2018 at 9:37 AM
    Neutron
    Neutron Well-Known Member
    East Tennesse
    2016 Tacoma TRD OR, black, 4x4
    Redline hood struts A/C drain hose Rear Diff vent Pop & Lock Hella Sharp Tones RAV4 mirror Clazzio seat covers HomeLink mirror Cargo bed lights (mattgecko) Puddle Lights ShiftSense Pro TRD Pro grille LEDs throughout Many minor mod$$- Thanks TW!
    Just a reminder.... Remember to give the tune a couple hundred miles to sort itself out. A number of drive cycles may also be required (number of cold starts to operating temps). I know many of you have already driven hundreds (thousands?) of miles on the newest tune, so any issues you are seeing with this bipolar truck are certainly valid and I have no doubt Mat will address in time.
    Merry Christmas to all!
    @OVTune
    sig916 and SpeySquatch like this.
  16. Dec 26, 2018 at 9:53 AM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    Users Viewing Thread: 137 ( 94 members and 43 guests ) - wow!
    lucytaco227 likes this.
  17. Dec 26, 2018 at 10:08 AM
    MOC221_
    Frank
    Apparently you are correct.
  18. Dec 26, 2018 at 10:12 AM
    L-SCHLEGS
    L-SCHLEGS Well-Known Member
    Nashville, TN
    2017 CEMENT TRD PRO
    If I was Mat I’d stop fighting this “base” tune thing and just get started on custom tunes.
    I think every single person would prefer and will need a “custom” tune. So why not sell the kit with logging instructions, log it, then tune each persons truck individually. That’s what’s going to happen anyways I feel like. Too many different little issues people are having, everybody’s trucks are different, very different.
    Gmarq and paleh0rse like this.
  19. Dec 26, 2018 at 10:15 AM
    SpeySquatch
    2016 TRD OR DCSB
    Drove my commute today in light city traffic with stop and go. Avg 19mpg 1.05 tune. Sure is nice
    G Tek Fab likes this.
  20. Dec 26, 2018 at 10:16 AM
    Gjr003
    Gjr003 Well-Known Member
    Its an odd combination of Man, I hope Matt enjoys his family and Man, I hope the Tune becomes self aware and drops itself...
    Shellshock, paleh0rse and Livinserene like this.
Thread Status:
