Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Dec 28, 2018 at 8:28 AM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    The 02 truck would flash back to stock 02 calibration and 04, the stock 04 calibration.
    GF8er and MOC221_ like this.
  2. Dec 28, 2018 at 8:35 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    I bought the tune for more power/performance, getting rid of the off the line bog as Frank mentioned was a bonus.
    DiabloTRD and Egnaro like this.
  3. Dec 28, 2018 at 8:44 AM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    I got it mostly for drivability and a little extra power never hurts.
    Egnaro likes this.
  4. Dec 28, 2018 at 8:46 AM
    Double Phister
    Double Phister Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
    Using the same "stock" file from OVtuned?
    If you can make a backup of your ECU then later flash that back in then great.
  5. Dec 28, 2018 at 8:55 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    The stock file you receive is the exact same file that’s on your stock ecu. Toyota doesn’t custom tune their vehicles
    Shellshock likes this.
  6. Dec 28, 2018 at 9:00 AM
    veggtaco
    veggtaco Well-Known Member
    2018 TRDSPDC
    The current 4.2 instructions (p1) include a step where you use the software to read your current calibration file#, and then send it to Mat. He would then send you back the tune files, along with the stock file that matched your calibration #. The stock file should have a suffix that matches your "stock" calibration (OB04, etc..) I'm not sure if this step is still required since he's giving us access to the tune via flash manager, but even if you can't extract the current stock tune, you can definitely read it and request a copy from Mat to save before you load the new tune. Also, when flashing back to stock, you're not picking a file that says "stock". You're picking a file that will contain your original calibration number. This way, you will know exactly what you are flashing. If I have this wrong, I'm sure someone will chime in;)
  7. Dec 28, 2018 at 9:21 AM
    Professional Asian
    Professional Asian Ridgeline Enthusiast
    Andrew
    Eureka, California
    2017 DCSB TRD off road MT [OVtuned]
    Well that’s good news!
    mZiggy[QUOTED] likes this.
  8. Dec 28, 2018 at 9:22 AM
    riz_atx
    Sohail
    Spicewood Texas
    You can read your ecu and write it back. but its not that important because as mentioned below, the tunes are the same.
  9. Dec 28, 2018 at 9:32 AM
    Shellshock
    Iowa
    wow that sucks. I've got 78,000 miles on mine and haven't done anything other than fluid changes.
  10. Dec 28, 2018 at 9:36 AM
    speedtre
    speedtre Well-Known Member
    DirtySouth
    '17 DCLB TRD OR AT 4x4
    Are you sure about that? I was under the impression that once an ECU is flashed to 04 (1.05 incorporates 04), that it could not be flashed back to a pre 04
    calibration....or did I miss something?
    Egnaro likes this.
  11. Dec 28, 2018 at 9:38 AM
    Shellshock
    Iowa
    I think you forgot some words :confused:
    SC4333, iexc, mZiggy and 2 others like this.
  12. Dec 28, 2018 at 9:39 AM
    riz_atx
    Sohail
    Spicewood Texas
    That is still true. But Mat has released his tune for various calibration id's in the past. So one can assume that if a truck flashes 1.05 and is on 04B02, that "going back to stock" would still be 04B02. This will of course be known real soon when Mat gives all yall with non-04b04 calibration ids the tune.
    Once you are on 04B04, you cant go back to anything lower. So these trucks's stock tune would be 04B04.
    GPatriot, Anchovy and GF8er like this.
  13. Dec 28, 2018 at 9:40 AM
    speedtre
    DirtySouth
    Ha, that was from another post I decided not to make and it was quoted...I'll take it out..lol
    Shellshock[QUOTED] likes this.
  14. Dec 28, 2018 at 9:40 AM
    TWTaco
    TWTaco Well-Known Member
    Dave
    You are correct!
    speedtre[QUOTED] likes this.
  15. Dec 28, 2018 at 10:11 AM
    SouthtownTaco
    SouthtownTaco Well-Known Member
    San Antonio, TX
    2016 TRD Offroad
    RCI Under Armor, Tailgate Lock, Bakflip F1, derped grill
    That good feedback - but what mpg would you have gotten before? How much of an improvement is 17mpg?
  16. Dec 28, 2018 at 10:18 AM
    E$Yota
    E$Yota Well-Known Member
    Ethan
    Dothan, AL
    2016 Tacoma TRD Sport 4X4
    FN wheels' version of the TRD Pro 4Runner, TRD Pro front skid plate, Low Range Offroad 3/1 lift, JBA Offroad upper control arms, TRD Pro Shift knob, OV Tuned, 4.88s, 285/70/17 BFG KO2s
    I get 17.5 -18 now without even trying. Of course the faster you go the worse the mileage is simply because of RPM. I am around 2300RPM at 72 MPH.
  17. Dec 28, 2018 at 10:20 AM
    SouthtownTaco
    San Antonio, TX
    2016 TRD Offroad
    Cool, but how much of an improvement is that?
  18. Dec 28, 2018 at 10:25 AM
    E$Yota
    Ethan
    Dothan, AL
    Went from 16.5-17.5 to 17.5-18 and can prolly get upwards to 20 if I hyper mile. I haven't just been driving it to see what would happen.
  19. Dec 28, 2018 at 10:40 AM
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    Perfect timing as I am going in for the 60,000 mile service on Monday... will update to 1.05/93 as soon as they are done with her!
    Thanks Mat - much appreciated!
    :yay:
    2016trdtacoma likes this.
  20. Dec 28, 2018 at 11:24 AM
    erok81
    erok81 Well-Known Member
    Imposter
    Has anyone used the gear lock yet? That’s the only thing I’m waiting for. I’d pay the 700 or whatever it was just for that feature. :D
Thread Status:
