Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Aug 30, 2017 at 11:43 AM
    #3301
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    Have no low or high RPM stumbles after 1.01b even when 4 wheeling. Do they go away when you turn traction control off (stopped hold button for about 3 seconds)? Can you describe in detail how they happen and what they are?
  2. Aug 30, 2017 at 11:55 AM
    #3302
    Egnaro
    Egnaro Watch this
    Brett
    AZ
    16 Inferno DCSB Offroad 4x4
    Ricochet full skids, Mobtown rear with swing-out, toytec boss 2.0, OV tuned
    I can make it do this everytime if I wanted. From a stop, if I give half or greater throttle while still in 1st the truck shutters briefly between 1800 and 2000 rpm. d mode. ect or no ect. i dont use s mode unless on hills towing. the shutter is not bad, almost feels like slight wheel hop in sand. It does shake the truck slightly for a second or two. techstream records no misfires and the timing does jump slightly at that time.
  3. Aug 30, 2017 at 12:02 PM
    #3303
    Egnaro
    Egnaro Watch this
    Brett
    AZ
    If anyone here knows how to read the data I have some quick runs saved
  4. Aug 30, 2017 at 12:06 PM
    #3304
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    I always assumed this was the truck trying to go for 2nd and then deciding that your throttle input warrants 1st... in the time it took you to read what I just typed lol
  5. Aug 30, 2017 at 12:44 PM
    #3305
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    bshammer0 likes this.
  6. Aug 30, 2017 at 1:06 PM
    #3306
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    The stumbles I'm describing are stutters felt when you're driving along at speed with the gearing putting you around 1200-1500 rpms. If you then give it just enough gas to try and accelerate while not giving it enough to initiate a gear change, the power surges, feeling like a miss. Give it just a hair more throttle so it downshifts and it goes away.
  7. Aug 30, 2017 at 1:10 PM
    #3307
    acemastr
    Aaron
    Tampa, FL
    OVTune
    Checked intake hoses are tight?
  8. Aug 30, 2017 at 1:25 PM
    #3308
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Yes, the stumbles are documented far and wide across members here.
    shakerhood likes this.
  9. Aug 30, 2017 at 2:16 PM
    #3309
    Cheers007
    Cheers007 Well-Known Member
    DFW
    2017 Tacoma Limited
    I know what youre talking about and I noticed it was gone before the tune when running 93 octane. I think it's knock related (either false knocks detected or actual knock).
  10. Aug 30, 2017 at 2:17 PM
    #3310
    FLJoe
    FLJoe Well-Known Member
    Joe
    Wellington, FL
    16 Blazing Blue Taco Limited AT
    OV Tuned
    I've been having that exact issue, but it's sporadic, took it to the dealer and neither the tech or I could get it to duplicate the issue. The tech tried to tell me I was feeling bumps in the road.
  11. Aug 31, 2017 at 10:46 AM
    #3311
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    I wonder if this low rpm stumble you are describing is the same shudder I get when letting the clutch out... I used to think the clutch was grabbing bad... But perhaps it's the truck?
    MOC221_ likes this.
  12. Aug 31, 2017 at 10:54 AM
    #3312
    avitaco
    avitaco Well-Known Member
    A
    2017 DCSB 4x4
    Who is using this with 4.88 gears?
    What is your experience? Have you noticed that its given issues?
    kashtyaatsi and sig916 like this.
  13. Aug 31, 2017 at 10:57 AM
    #3313
    sig916
    sig916 Well-Known Member
    Has anyone encounter this problem. From 1st to 2nd and 2nd to 3rd gear, if I take it to rev limit, right when it upshift the truck will surge/stall for a sec or so. It feels like fuel cut off or somthing. It only happen on both tune files.
  14. Aug 31, 2017 at 11:04 AM
    #3314
    sphilly28
    sphilly28 Well-Known Member
    2017 DCSB TRD Sport MGM 6MT
    I'm getting a Trojan virus warning when I am trying to download the pcmflash 1.1.83, anybody else seeing that?
    dYL0n likes this.
  15. Aug 31, 2017 at 11:05 AM
    #3315
    Cheers007
    DFW
    2017 Tacoma Limited
    This is normal. Fuel is cut a bit between shifts as part of torque management, to not kill your transmission. Lexus does this too.
  16. Aug 31, 2017 at 11:06 AM
    #3316
    Cheers007
    DFW
    2017 Tacoma Limited
    Not me. Either it's a false alarm or your pc is already contaminated.
    dYL0n likes this.
  17. Aug 31, 2017 at 11:18 AM
    #3317
    sphilly28
    Had to make an exception for the zip file I guess
  18. Aug 31, 2017 at 11:49 AM
    #3318
    Scooby24
    Greg
    2017 DCSB OR 4X4
    I had no warnings using windows defender. Ran a scan too, no threats.
  19. Aug 31, 2017 at 11:54 AM
    #3319
    Cheers007
    DFW
    2017 Tacoma Limited
    I dont think you read your screen correctly. That pop up from the browser is just a "possible warning" not a true flag of a trojan caught. If it were a trojan, you would not be able to bypass anything.
  20. Aug 31, 2017 at 12:41 PM
    #3320
    deadgame
    deadgame Well-Known Member
    2017 Tacoma TRD Pro
    Quick question: I just received my kit and I believe that I heard that I don't need to
    download some of the drivers. If this is true, which step do I pick up with on the OV website instructions? Thx!
Thread Status:
