Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Dec 29, 2018 at 8:06 PM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    Mat has never said to warm it up first, if memory serves. But I did it this time cause everyone is doing it. lol
  2. Dec 29, 2018 at 8:07 PM
    tjpratt
    tjpratt Well-Known Member
    Travis
    Aurora, Colorado
    2016 Limited 4X4 Tacoma
    3.75" Lift / OME OVTuned
    That's not what the website says.
  3. Dec 29, 2018 at 8:07 PM
    habanero_taco
    habanero_taco Well-Known Member
    Randy
    2016 Tacoma TRD Sport
    OVTuned
    It was about 20 degrees here when I flashed mine this afternoon.... flashed it cold, let it idle for 3-4 minutes, drove it! All was fine.
    fullsend604[QUOTED] likes this.
  4. Dec 29, 2018 at 8:09 PM
    Deucer01
    North Georgia
    So we agree, it's insane! :crazy::crazy::crazy::crazy:
  5. Dec 29, 2018 at 8:13 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    I basically followed the idle learning process in the FSM, which is to do it when it's at operating temp. YMMV
    SC4333 and Melmantaco like this.
  6. Dec 29, 2018 at 8:14 PM
    Shellshock
    Iowa
    I’ve flashed hot, cold and everywhere in between and never had an issue. Once you get some miles on it, it sorts itself out. Back in the day we never even idled after flashing.
    DakoTaco, inksin, go2cnavy and 2 others like this.
  7. Dec 29, 2018 at 8:15 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    I have to agree with this,start from a cold engine so it can learn cold fuel trims and adjust as the engine reaches operating temp. YMMV
  8. Dec 29, 2018 at 8:15 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Lol at worst I'd get a stumble within the first 50mi following cold start flash and then my trusty honeybadger would figure out its life and return to having no problems
    Tac0Tic0 and lapoltba like this.
  9. Dec 29, 2018 at 8:16 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Fuel trims aren't set it and forget it. They change quickly right after flashing but settle into some base value that moves slowly over time based on environmental conditions, driving habits, and other variables. The maps are set up in such a way that the truck will run just fine (safely) with no trims established. Cold or hot starting on a new flash doesn't really matter much.
    habanero_taco likes this.
  10. Dec 29, 2018 at 8:18 PM
    Shellshock
    Iowa
    Exactly. I basically ignore anything that happens in the first 400 miles. Some people seem to constantly be reflashing and never logging enough miles for things to settle in.
  11. Dec 29, 2018 at 8:21 PM
    habanero_taco
    Randy
    OVTuned
    Yup, and pretty sure LTFT's arn't updated until the engine is up to temp anyway.
  12. Dec 29, 2018 at 8:23 PM
    Justin85
    Justin85 Well-Known Member
    Justin
    Rebel!
    habanero_taco[QUOTED] likes this.
  13. Dec 29, 2018 at 8:23 PM
    M1Awolf
    Rob
    Montana
    This is why I flash from a cold start,it allows the engine to establish a base value from cold to operating temp. It then has a "base value" to go off of when adapting to other conditions /scenarios. Again YMMV and I may be off on my hypothesis.
    lapoltba[QUOTED] likes this.
  14. Dec 29, 2018 at 8:24 PM
    lapoltba
    CT - 06076
    Don't really know all the nitty gritty details, but that would make sense. Bottom line, the EFI electronics in modern vehicles are so good it probably doesn't matter.
  15. Dec 29, 2018 at 8:25 PM
    ksj
    Pacific NW
    265/70-17 KO2
    I think the point of giving it time for idle learning is so that happens sooner. Personally I flashed 1.04 once, did the idle learning and forgot about it until the learning made it somewhat horrible to drive again. Then I disconnected the battery for 10 min and it was back. I flashed 1.05 three times because I figured I missed something when my idle was crazy after the first time, so I did it again. Same issue. Sent ticket in to support@ovtune.zendesk.com and had a fix in less than an hour. :thumbsup::thumbsup:
  16. Dec 29, 2018 at 8:26 PM
    Shellshock
    Iowa
    It’s not going to make a difference. I can flash on a cold truck here where it’s 15 degrees or I can do it cold in Phoenix where it’s 100. Or I can do either after up to temp. The engine temp and air temp are going to vary drastically depending on where you are and the time of year you flash. It’ll be fine.
    Just flash the truck. Idle 10 minutes. Drive it.
    DakoTaco likes this.
  17. Dec 29, 2018 at 8:28 PM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    I've also flashed cold and warm, saw no real difference.
    DakoTaco and Shellshock like this.
  18. Dec 29, 2018 at 8:29 PM
    Shellshock
    Iowa
    BINGO
    The idling is only to speed up the initial calibration.
    10 minutes is all that’s recommended.
  19. Dec 29, 2018 at 8:32 PM
    SpeySquatch
    2016 TRD OR DCSB
    Just flashed the updated blog file tonight, the 1>2 shift has changed, but I’m not making any opinion until it breaks in (2-300 miles)
    I enjoyed the more aggressive 1st in the “idle surge fix” version because I can control my take-off a lot more which is nice For DD and gets my weight moving.
    So far so good, can tell that mpg bar sits higher more often.
  20. Dec 29, 2018 at 8:33 PM
    SpeySquatch
    2016 TRD OR DCSB
    Shit. I did 11.
    :D
Thread Status:
