Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jan 4, 2019 at 9:30 AM
    JJ18ORDBSBMT
    JJ18ORDBSBMT Well-Known Member
    1.05 FOB 91 2018 Off road White DC M/T
    FO91. Like it a lot more than the MA tuned.
    MOC221_[QUOTED] likes this.
  2. Jan 4, 2019 at 9:30 AM
    veggtaco
    veggtaco Well-Known Member
    2018 TRDSPDC
    I did not get this error, but I do have a HU that uses OBD2 communication, so I disabled it before I started. There was a post from someone else that had unsuccessful flashes until he did the same thing. Worth mentioning..
  3. Jan 4, 2019 at 9:34 AM
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    Did you install the tractix openport 2.0 drivers?
  4. Jan 4, 2019 at 9:37 AM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    And disabled anti-virus (or created an exception)?
  5. Jan 4, 2019 at 9:38 AM
    veggtaco
    2018 TRDSPDC
    I think you meant to reply to @Marbleyard .. But since you asked, I actually did forget to install the Tactrix drivers initially, but it didn't make the app crash out. It just left the "Interface" window blank.
  6. Jan 4, 2019 at 9:40 AM
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    I should have it updated, my name is now next to my register number, I assume this is confirmation. I may try turning off the virus scan but I’m updating windows first to see if that’s the snag.
  7. Jan 4, 2019 at 9:42 AM
    Marbleyard
    Virginia
    2019 4Runner Pro
    I don’t know what HU that used OBD2 comm means
  8. Jan 4, 2019 at 9:44 AM
    Ron1965
    Ron1965 Go Bruins.......
    Ron
    Socal
    2018 Cement TRD ORSB PREMIUM/TECH
    OVtune Mooseditty Custom;DD Exhaust;Nitro 5.29’s;SCS Brushed Copper;AFe Custom CAI
    I had to turn off windows defender and Norton.Worked perfectly after that....
    2016trdtacoma and PhogDog like this.
  9. Jan 4, 2019 at 9:51 AM
    veggtaco
    2018 TRDSPDC
    OBD2 is a the data communication protocol our trucks (and most other vehicles) use. Lots of newer audio head units have a harness that uses OBD2 data to display gauges, tire pressure, etc. Apparently, it can interfere with the flash software's ability to communicate.
    Marbleyard[QUOTED] likes this.
  10. Jan 4, 2019 at 9:57 AM
    Marbleyard
    Virginia
    2019 4Runner Pro
    I turned off everything I think could be blocking it (haven’t tried windows defender) computer wouldn’t download new windows 8.1. Went out and tried again. Still same error. I will let it win this battle and come back to fight again later.
  11. Jan 4, 2019 at 9:59 AM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    I'm windows 10 and it's up to date. I just assumed the logger was broken for everyone, and a working version of something or another was provided by OV when he needed logging done. I guess I'll just leave the logging to others willing to help.
  12. Jan 4, 2019 at 10:03 AM
    GF8er
    MT. Hood
    Install these drivers and try again
    https://www.tactrix.com/downloads/openport2_setup_1024791.exe
    The box to the right of the word interface should have the tractix adapter selected.
  13. Jan 4, 2019 at 10:07 AM
    ChickoSM1808
    ChickoSM1808 Well-Known Member
    Michael
    2018 dcsb TRD Sport (OVTuned)
    OVTuned, TRD Pro grille, 32's and many more
    I had the same issue after the windows update. I reinstalled openport software and it worked.
    Marbleyard likes this.
  14. Jan 4, 2019 at 10:12 AM
    TEXAS BS
    TEXAS BS Formerly known as MMXVII
    JB
    Texas
    2017 ACLB TRD OR 4X4
    @OVTune intersting observation. I flashed 1.05 87 about 400 miles ago. Worked/ran perfect from the start. The tank was full of 93 oct. This morning I flashed 1.05 93. Tank still filled with 93. Immediately rpm acting up. On 1.05 87 idle was 500 to 550 and stable. On 1.05 93 the idle swings from 600 to 1000 rpm. After 20 miles it is 600 to 900. I’ll put a few hundred more miles on it to see if it learns it’s was out of it and report back. Hope this info has some use.
  15. Jan 4, 2019 at 10:15 AM
    JJ18ORDBSBMT
    If I may be so presumptuous, I speak for all the MT owners. Just have the MT tune ready by Jan 11th.
    Lol
    Beerpayzdabillz likes this.
  16. Jan 4, 2019 at 10:20 AM
    su.b.rat
    su.b.rat broken truck
    you made your point man!
    MOC221_ and JJ18ORDBSBMT[QUOTED] like this.
  17. Jan 4, 2019 at 10:21 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    :lalala:
  18. Jan 4, 2019 at 10:48 AM
    BT17
    BT17 Well-Known Member
    B
    17 Tacoma TRDORDCSB 4x4 AT KDmax SLT/Reg
    a few...
    Just downloaded new OV Tune 1.05 - 91 octane to Tacoma successfully. I was running the OV Tune 1.04 - 91 octane and 7825 miles on that tune with very minimal problems.
    Gonna see how the new tune works for my needs and report back at a later date.
  19. Jan 4, 2019 at 10:51 AM
    Hawks4life
    Hawks4life Well-Known Member
    Joe
    17 Tacoma Pro
    lol same here, paid cash and have had people talk shit about it that I should have not. And thanks USAA...
    Deucer01[QUOTED] likes this.
  20. Jan 4, 2019 at 10:52 AM
    su.b.rat
    haha same here! usaa!!
    Deucer01 likes this.
Thread Status:
