Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jan 13, 2019 at 10:12 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    You need a financial adviser..
  2. Jan 13, 2019 at 10:15 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    If I am going for MPG's my truck gets better if I drive with a bit more "spirit" getting it up to cruising speed. I also tend to keep an eye on my instant eco in the center display and adjust gears/rpm accordingly once I have reached my desired speed.
  3. Jan 13, 2019 at 10:22 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    In my stock truck I've found I get the best mileage most of the time if I don't display any mpg displays. Just drive like you always would without them and see what happens. It's not great mileage but not bad when it's mostly uphill coming home from town.
    paleh0rse likes this.
  4. Jan 13, 2019 at 11:56 PM
    Totall4285
    Totall4285 Well-Known Member
    Palm Harbor, Fl.
    2017 Tacoma TRD Sport
    Similar to my experience. Mine gets better mpgs on 91 tune running 93 octane gas.
    paleh0rse[QUOTED] likes this.
  5. Jan 14, 2019 at 4:28 AM
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Why would removing the rack "make the truck come alive"
    tjpratt and Melmantaco like this.
  6. Jan 14, 2019 at 4:37 AM
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    This.
  7. Jan 14, 2019 at 4:45 AM
    Rocinante75
    Rocinante75 Well-Known Member
    2018 TRD Pro Cavalry Blue
    RokBlokz Mud Flaps, TufSkinz tailgate lettering, OV Tuned (1.05!!!)
    Just got back from a ~300 mile mostly highway trip using 1.05/93. As many have reported, highway driving is much nicer now. Cruise is serviceable. Mostly bounced back and forth in 5th and 6th, but would drop to 4th on some longer sloping hills. I ended up just dropping cruise and manipulating the pedal to stay in 5th on those occasions. MPGs for the trip were 17.5 (no weight or performance mods on the truck).
    It really is just a matter of learning how to drive the truck again...the shifting can be easily manipulated with subtle use of the pedal.
  8. Jan 14, 2019 at 4:54 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Yeah I loaded 87 Tune yesterday morning. Drives better bc it forces a down shift earlier than 93 tune giving the truck more torque but I can still get the truck to buck between 1200-1500 with slight load. I'm 95% sure its the heavy 33"s throwing the rpm range out of power band which will require a custom tune to fix. My original post wasn't to point out the issue but to seeing if anyone else saw the same behavior.
    I'm still getting an mpg hit above 75mph (1-1.5 mpg) vs the 1.04 93 tune. The TC wont lock in 6th gear but again my tires are messing it all up.
    Yes I've already sent an email to OVTune Saturday.
    bshammer0 likes this.
  9. Jan 14, 2019 at 6:07 AM
    tjpratt
    tjpratt Well-Known Member
    Travis
    Aurora, Colorado
    2016 Limited 4X4 Tacoma
    3.75" Lift / OME OVTuned
    Mine feels pretty "Alive" with the rack still up there..
    taco 16 and 2016trdtacoma like this.
  10. Jan 14, 2019 at 6:18 AM
    60calHowdaHunter
    60calHowdaHunter Well-Known Member
    Dave
    Arizona
    2016 Tacoma 4x4 offroad
    none
    87 is nice because not only is it cheaper but never need worry about what you put in your tank. Some folks love 87 so I tried it, and at first was very happy (after just quick test around the block) but the next day after really driving it, i noticed a longer first gear and subtle idle pulsing while stopped in D, these two things were the only difference 87 and 91 that i noticed, and although minor, these two things alone was enough for me to flash back to 91 and am back to being happy as a clam. Every truck seems to take these tunes differently, i have never read anywhere in this forum about a pulsing idle at stops, or first gear being too long, so this is likely just my truck (or my over-sensitive anal analysis!). Anyway, i am glad i tried it, now i never have the think about 'what if' every time i go to a gas station paying for 91 and thinking i could be just as happy or even happier and paying less on 87! Good luck!
  11. Jan 14, 2019 at 6:41 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    Thanks for the feedback, guys. I'm going to try another Shell tank after I finish this Sam's tank on the 93 tune because I do really love the way the 93 tune handles everything. If that doesn't improve the mpg, I may then drop down to the 1.05-91 tune while still using 93 octane fuel. Hell, I might do that just to see what it's like! :D
    For the record, I live for all of this hacking and experimental shit, so none of this mpg stuff actually bothers me. I'm having a blast with the new tune, and the truck now drives like I hoped it would from the start. I just love talking about it, as well, so please don't interpret any previous or future posts on this subject as complaints.
    Thanks again for the feedback and advice! :hattip:
    Reypac24, ToyoDrew and honey like this.
  12. Jan 14, 2019 at 6:46 AM
    ohioboater
    ohioboater Well-Known Member
    2017 DCLB 4x4 Sport
    I dropped my Sam's membership some time ago after it became obvious that the name brand items they carried were not the same quality as retail. Case in point (no pun intended) - I used to buy cases of StarKist canned tuna from them, and multiple cans in each case would contain bone chunks. Lots of bone chunks, like the processing plant just threw the leftover carcasses into a grinder. I have never gotten a single bone in any can of StarKist bought from a normal retail outlet. Simplest explanation is that Sam's was using its buying power to lowball manufacturers on price, and the manufacturers were responding by producing lower quality, "Sam's specific" product. So the same might be happening with their gas - they are sourcing the cheapest possible version, with resulting poor quality control.
    taco 16 and paleh0rse[QUOTED] like this.
  13. Jan 14, 2019 at 6:47 AM
    SpeySquatch
    2016 TRD OR DCSB
    Mine did that slight rpm jump too at a stop but it goes away after 100 miles or so.
    riz_atx likes this.
  14. Jan 14, 2019 at 7:17 AM
    2016trdtacoma
    Trevor
    Utah
    Costco all the way!
    tater taco likes this.
  15. Jan 14, 2019 at 7:32 AM
    60calHowdaHunter
    Dave
    Arizona
    none
    thanks, did you notice 1st gear revving a little longer before shifting into 2nd? And rpm while stopped in D, mine pulsated from 600 down to 500, about ever 2 seconds, and when down to 500 (for about 1 second) i could feel it in the seat and even the dashboard, did you experience this too?
  16. Jan 14, 2019 at 7:43 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    This could also be perceived power via butt-dyno. If you smooth out power delivery but accelerate quicker, you'll still feel like you have more power if you gave the same throttle position and felt a kick in the ass and snapped your head back, even if that rate of acceleration is slower. You perceived more of a change, and so you think there's more power.
    I don't have Dyno results from 1.04 to 1.05, but a lot of people will likely be fooled by the above IF that's what's happening.
  17. Jan 14, 2019 at 7:45 AM
    yotanut
    yotanut Well-Known Member
    2022 TRD Pro 6MT
    I also experience this same bucking. I have a ticket into Mat. I am stock with the exception of 265/75/16 tires. I don’t have enough miles since flashing to say it is not a learning issue. Does anyone think it should be flashed to stock to figure it out, or should just log more miles to see if it will clear up? Just don’t want to damage the engine in anyway. Besides this the truck drives great. Also noticed the bucking when accelerating hard (getting up to highway speed) within the first 1-4 gears then goes away.
    TacoRD16[QUOTED] likes this.
  18. Jan 14, 2019 at 7:54 AM
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    Has anyone loaded/flashed their truck with a Microsoft Surface (Go, Pro, 3 or other)? Running Win 10
  19. Jan 14, 2019 at 7:59 AM
    cstern1
    cstern1 Well-Known Member
    Caleb
    KCK
    2017 DCSB Sport
    I did it with a Surface Book 2. No issues since its windows 10.
    CoastieRon[QUOTED] likes this.
  20. Jan 14, 2019 at 8:02 AM
    Shellshock
    Iowa
    some people should go back to stock for a couple weeks to recalibrate their butt dyno
Thread Status:
