Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jan 31, 2019 at 1:24 PM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    A locked diff can reduce steering response. Once you do start to turn at least one rear wheel would need to slip (loose traction) to turn. Think about getting up to speed in a straight line and needing to turn. Vehicle resists turning and could snap to tail out.
    Fun when you're wanting that, less so when you weren't.
    paleh0rse likes this.
  2. Jan 31, 2019 at 1:44 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    The other wheel just spins slower. It doesn’t lose traction. But a locked rear diff will make turning more difficult but not impossible
  3. Jan 31, 2019 at 1:47 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Locked, means both wheels spin at the same speed. The inside wheel will want to spin slower while turning, but can't, because - locked. At the very least you will scrub tires with the diff locked going slow. At higher speeds, I can see how there could be reduced steering response.
    Unlocked, yes, the wheels are allowed to spin at different speeds.
  4. Jan 31, 2019 at 2:14 PM
    Anchovy
    TRD Ferguson
    That’s what I was trying to say
  5. Jan 31, 2019 at 2:34 PM
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    FWIW, I average 4 to 10 misfire per drive cycle, 90% of them occur within first few minutes when engine still coming up to temperature. 1.05 91 04B04 using 91 gas, stock TRD Pro.
    So for me, no difference between stock or OVT tune. Not denying your problem, just throwing more data out there. Perhaps bad gas? Try running 87 tune with 91 gas, or fill up at another station. Questionable crank position sensor (CPS)?
  6. Jan 31, 2019 at 2:48 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    That's what I get, around 4-6. 1.05 91 with 91 in the tank. I get maybe a couple more on 1.05 than I did stock. I would also be curious to see people's results when they run higher octane on a lower tune. Like the previous poster said, 91 on 87 tune.
  7. Jan 31, 2019 at 3:10 PM
    yotanut
    yotanut Well-Known Member
    2022 TRD Pro 6MT
    Could be a fuel issue. However, significantly less misfires on the stock tune vs 1.05 87, same fuel in tank. I need to fill up and going to try Shell 92 (can't get 93 here), and will try 1.05 87 on 92 octane to see if the misfires are still an issue. I will report back in the next few days.
  8. Jan 31, 2019 at 3:15 PM
    Neutron
    Neutron Well-Known Member
    East Tennesse
    2016 Tacoma TRD OR, black, 4x4
    Redline hood struts A/C drain hose Rear Diff vent Pop & Lock Hella Sharp Tones RAV4 mirror Clazzio seat covers HomeLink mirror Cargo bed lights (mattgecko) Puddle Lights ShiftSense Pro TRD Pro grille LEDs throughout Many minor mod$$- Thanks TW!
    Sounds like a great plan. We’ll be awaiting your results!
    :popcorn:
    iexc likes this.
  9. Jan 31, 2019 at 3:15 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I would rule out a fuel. I've been running 87 since day 1. During flashing to 1.05 87 I had 1/2 tank and number of misfires caught my attention right away.
  10. Jan 31, 2019 at 3:19 PM
    thedriza
    thedriza Well-Known Member
    Portland, OR
    2017 Tacoma DCSB
    5.29 gears, OME HD lift, OVTune
    Locked 2WD might be nice on a wet boat ramp, but for 4LO is arguably better if it's on a steep incline.
  11. Jan 31, 2019 at 3:22 PM
    Shellshock
    Iowa
    I've had huge differences in performance from one tank of 87 to the next. these trucks are princesses when it comes to fuel, no matter what tune, factory or not.
    SpeySquatch and TRDBRO559 like this.
  12. Jan 31, 2019 at 3:27 PM
    su.b.rat
    su.b.rat broken truck
    and temperature!
    TRDBRO559 and Shellshock[QUOTED] like this.
  13. Jan 31, 2019 at 3:28 PM
    Anchovy
    TRD Ferguson
    And altitude
    TRDBRO559 and su.b.rat[QUOTED] like this.
  14. Jan 31, 2019 at 3:28 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I have the same kind of behavior and I have replaced my CPS sensor and have far less misfires on stock. It's the tune that's causing the spike in misfires for SOME. Period.
    I also do not recommend toying with different octanes on different tunes if you are experiencing misfire and knocking. I have tried that and when I ran the 87 tune w/ 93 in the tank I had knock city and quickly flashed back to stock.
    yotanut likes this.
  15. Jan 31, 2019 at 4:43 PM
    mexanese.502
    mexanese.502 Well-Known Member
    Kentucky
    2017 Limited BADASSMF
    OV Tuned
    So haven't been on this site because enjoying the tune and happy to say. Wow what timing seeing Matt's updated OP.
    Couldn't agree more with commitment about the computer illiterate people. That's half this thread.
  16. Jan 31, 2019 at 5:15 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    How about Locked 2Lo. With my current setup I could try it...it has never occured to me.
    SC4333 likes this.
  17. Jan 31, 2019 at 6:29 PM
    ChickoSM1808
    ChickoSM1808 Well-Known Member
    Michael
    2018 dcsb TRD Sport (OVTuned)
    OVTuned, TRD Pro grille, 32's and many more
    I had been running the 91 tune on 93 gas and it had been great. Tried the 87 tune this week, bad idea. Went from Erie to Pittsburgh and it was misfiring like crazy on the highway. If the rpms were under 2000 at any load it would misfire. Had to switch to S- mode and set at 5 to get home without crazy misfires. Got back into town, filled up with 93 and switched back to 91 tune and all seems good.
  18. Jan 31, 2019 at 6:32 PM
    E$Yota
    E$Yota Well-Known Member
    Ethan
    Dothan, AL
    2016 Tacoma TRD Sport 4X4
    FN wheels' version of the TRD Pro 4Runner, TRD Pro front skid plate, Low Range Offroad 3/1 lift, JBA Offroad upper control arms, TRD Pro Shift knob, OV Tuned, 4.88s, 285/70/17 BFG KO2s
    You ran 87 octane on the 91 octane tune? No shit you had misfiring... it is called pre detonation. You prolly took quite a bit of life off of you engine...
  19. Jan 31, 2019 at 6:36 PM
    ChickoSM1808
    Michael
    No I ran the 87 octane tune on 89. I'm not an idiot. Lol I knew I was making a long trip. So I figured I'd try the 87 tune and filled up with 89
    ihatemytruck likes this.
  20. Jan 31, 2019 at 6:40 PM
    ChickoSM1808
    Michael
    And I actually had about 2.5 gallons of 93 left in the tank when I filled up with 89 and switched to the 87 tune. My truck doesn't like that tune at all..
Thread Status:
