Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Feb 2, 2019 at 6:48 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Or you could use Techstream to clear the codes which would have the same result.
  2. Feb 2, 2019 at 7:00 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    I don't think it's a matter of simply clearing codes. The battery disconnect also clears residual "learned" variables that appear to be causing issues with the tune.
    Don't try to shortcut the instructions. Do exactly as Mat suggests.
    ChickoSM1808 and yotanut like this.
  3. Feb 2, 2019 at 7:01 AM
    Gjr003
    Gjr003 Well-Known Member
    Thinking of doing the same keep us posted
  4. Feb 2, 2019 at 7:01 AM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    There's a function entech stream for doing exactly this. It's called something like clear stored values.
  5. Feb 2, 2019 at 7:04 AM
    paleh0rse
    Raleigh, NC
    That would be different than merely "clearing codes." If techstream also has a way to clear all "learned values," then maybe that would be enough.
    I personally wouldn't take the chance, though. It's not like it's difficult to disconnect the battery...
  6. Feb 2, 2019 at 7:12 AM
    lapoltba
    CT - 06076
    It is not just clearing codes It clears all learned values. I have used it before...
    paleh0rse likes this.
  7. Feb 2, 2019 at 7:28 AM
    habanero_taco
    habanero_taco Well-Known Member
    Randy
    2016 Tacoma TRD Sport
    OVTuned
    To clear up any confusion... if you're worried about old learned values stored in your ECU, do the following:
    If you've already flashed 1.05:
    Disconnect battery for 10 minutes or so
    Start truck, let it idle for a few minutes if you want to speed up idle learning, because you've cleared idle also with battery disconnect.
    If you're flashing 1.05:
    Flash truck per the process
    Start the truck to ensure the flashing was successful
    Turn off truck, disconnect battery for 10 minutes
    Start truck and do idle learning process
    That's it, you're good to go!
    jholc21, yotanut, SurfratTX and 3 others like this.
  8. Feb 2, 2019 at 7:45 AM
    SpeySquatch
    2016 TRD OR DCSB
    He specifically said there is nothing better than disconnecting the battery...
  9. Feb 2, 2019 at 7:57 AM
    lapoltba
    CT - 06076
    I'm not asking anything. He said "nothing better" because it is the easiest way for ANYONE to clear learned values. It does not require any additional software or computer knowledge. He already has to deal with computer literacy issues with the tune even though it is dead simple.
    I was merely confirming that Techstream does in fact have a function to accomplish the same thing as @Ruggybuggy suggested.
    It's not a matter of ease, it's a matter of preference and convenience. If I'm sitting in my truck to flash and it's -10 degrees F out, I would much rather click a button in Techstream (it's on the same computer I use to flash), than get out of the truck and screw around under the hood with the battery.
  10. Feb 2, 2019 at 8:57 AM
    jbehrens5898
    jbehrens5898 Well-Known Member
    Josh
    Huntington Beach, Ca
    2017 Gray TRD Off Road Long Box
    Fox 2.5 w/DSC REM 4.88 Icon Mini Pack OVTuned Caliraised LED's Bakflip MX4 WeatherTech's
    PM Sent
    iexc likes this.
  11. Feb 2, 2019 at 8:58 AM
    SpeySquatch
    2016 TRD OR DCSB
    -10...makes sense.
    catastrofe likes this.
  12. Feb 2, 2019 at 9:28 AM
    SurfratTX
    SurfratTX Well-Known Member
    Lee
    SE Texas
    2017 Tacoma TRD OR Quicksand
    To the point!
    Thanks Randy!
    habanero_taco[QUOTED] likes this.
  13. Feb 2, 2019 at 11:04 AM
    yotanut
    yotanut Well-Known Member
    2022 TRD Pro 6MT
    I flashed back to 1.05 87 and followed the instructions to a “t” including the battery disconnect. Took it for a 5 mile loop at 55 mph (completely warm engine) had 8 misfires. Something else is going on. Hoping Mats testing goes well this weekend.
  14. Feb 2, 2019 at 11:09 AM
    TWTaco
    TWTaco Well-Known Member
    Dave
    Quirks of this 3rd Gen :annoyed:
  15. Feb 2, 2019 at 11:50 AM
    ChickoSM1808
    ChickoSM1808 Well-Known Member
    Michael
    2018 dcsb TRD Sport (OVTuned)
    OVTuned, TRD Pro grille, 32's and many more
    I'm back on the 91 tune and all seems good again.
    bshammer0 and PhogDog like this.
  16. Feb 2, 2019 at 1:10 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Consolidating some information here for those interested. I've never had a vehicle where clearing the DTCs would not reset learned values, however Mat alludes to this potentially being an issue with some Toyota ECU's. At least thats how I interpret his comments. I will say though, having to disconnect the negative battery terminal is a bit annoying. Thanks Toyota!
    2017TRDpro[QUOTED] likes this.
  17. Feb 2, 2019 at 1:12 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Reflash that I did last Sunday helped and results were better after 200 miles.On a few last drives I had no more than 5 misfires.
    So this morning I reset ECU. Started up and it was 0. Went shopping and on the way back had 2 - 0 on startup and 2 while navigating through parking lot.
    Took a truck to the hills and it performed even better. Spooled to 90. Zero misfires..
    Hope the herpes is cured ...
    paleh0rse, lapoltba and Taco16LB like this.
  18. Feb 2, 2019 at 3:34 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Not available until new Flash Manager is released.. an update to Gearlock has been posted on the first page. Flash Manager is very very close to complete.
    Other than that gear locking is working perfect so it will be available release day of FM update.
    taco 16, ihatemytruck, Rus$ and 17 others like this.
  19. Feb 2, 2019 at 4:34 PM
    erok81
    erok81 Well-Known Member
    Imposter
    Woohoo!
    TRDOBSESSED likes this.
  20. Feb 2, 2019 at 5:07 PM
    Gjr003
    Could we get definitions or explainations of each choice? How much more powerful is performance than base? Is 87 performance better then 91 base? How does 4 and 5 feel compared to base? Etc
    1. 1.05 base mpg
    2. 1.05 Performance 87 octane, Stage 1 91 octane, Stage 2 93 octane
    *3. 1.05 Gear Lock map
    *4. 1.05 Legacy Shift(All drive modes will use a modified ECT Shift table)
    (ECT enhances performance, does not modify shift)
    5. 1.05 6900 RPM
Thread Status:
