Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Feb 13, 2019 at 6:26 AM
    Captndarty
    Captndarty Well-Known Member
    2017 Magnetic Grey limited
    About $2,500. I went with East Coast Gear Supplies pre built front and rea differentials to ensure it was done correctly. Had a local shop swap them out which still cost about a grand. So $1400 after receiving an additional $1100 back on a core charge then $1050 to instal. Sooooo worth it over any other mod including a tune. If you can do them both then perfect.
    riz_atx likes this.
  2. Feb 13, 2019 at 6:46 AM
    navin r
    navin r Well-Known Member
    2017 double cab short bed trd off road 4wd w/ premium pkg.
    So what's going on with the handheld?
    BlkTaco47 likes this.
  3. Feb 13, 2019 at 6:52 AM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
  4. Feb 13, 2019 at 6:55 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Mat is still waiting on the supplier.
  5. Feb 13, 2019 at 7:00 AM
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
  6. Feb 13, 2019 at 7:02 AM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    Totally agree here. 4.88's make the truck drive as it should have about 90%. It doesn't fix the lazy throttle of the factory tune, but ECT fixes that. Hopefully OVTune will have tunes specific for folks with gears soon.
    Sam275 and Captndarty[QUOTED] like this.
  7. Feb 13, 2019 at 7:46 AM
    ChickoSM1808
    ChickoSM1808 Well-Known Member
    Michael
    2018 dcsb TRD Sport (OVTuned)
    OVTuned, TRD Pro grille, 32's and many more
    @OVTune is there an updated 87 file coming out this weekend or should I try the last one u sent out and reset learning values
    Brent2014 likes this.
  8. Feb 13, 2019 at 7:57 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Yes go ahead, you can update on FM release if you'd like to.
    Someone just messaged us this morning saying they installed 5.29s and their truck hits the speed governor @80MPH. Wonder if this is what others are experiencing? This means it throws things way off.
    Also posting again our email is Support@ovtune.zendesk.com, not Orangevirus101@gmail.com anymore
    Inferno__Taco and MOC221_ like this.
  9. Feb 13, 2019 at 8:01 AM
    Oscar I
    Oscar I No longer a toyota driver
    Just recieved my initial batch of tunes. Looking forward to running them.
    So quick question. 85 is the base level gas here. Any issues running it on the 87 tune or are the tunes just labeled for what is common near you @OVTune
  10. Feb 13, 2019 at 8:09 AM
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2024 Tacoma TRD OR (Hybrid)
    Do not run a lower octane on a higher octane tune. You can run higher octane on a lower octane tune (ie 89 on the 87 tune).
    ihatemytruck likes this.
  11. Feb 13, 2019 at 8:12 AM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    This is what the ignore button is for....
    TFly and HelloMyNameIs[QUOTED] like this.
  12. Feb 13, 2019 at 8:14 AM
    Captndarty
    I’d say they’d be too high. Probably over 2600 rpms at 75. First would be so short and jerky.
  13. Feb 13, 2019 at 8:15 AM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Cannot emphasize this more......do NOT run lower octane than what the tune calls for. So 87 octane means minimum of 87 octane, etc.
  14. Feb 13, 2019 at 8:28 AM
    KanPanic
    KanPanic Rock Stacker
    State of Jefferson
    2018 OR
    Nope. Why guess the math isn’t hard?
    My worksheet says an AT @ 75 with 5.29 and “33’s” should be at 2364rpm. @80 2522 and not cresting 2600 till close to 85.
    I’ve posted my worksheet in the 5.29 mega thread.
    The real question is at what rpm/throttle position does the truck go into full Otto. Will 1.05 allow Atkinson at ~2500 rpm cruising down the highway.
  15. Feb 13, 2019 at 9:03 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    And I was literally thinking about doing gears until I saw that. I’d like to see what mat says about how gears mess with the truck first
  16. Feb 13, 2019 at 9:07 AM
    SpeySquatch
    2016 TRD OR DCSB
    Ok...? So do I, but $6k is a lot of money when one considers that is a years wage for some people and could literally feed an entire village
  17. Feb 13, 2019 at 9:10 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    1. My MPG remained mostly the same, or perhaps +1mpg in some situations, at best. Of course, this will vary all over the place depending on which tune file you use, how you drive, your truck's own nuances, etc.
    2. Most of the obnoxious gear hunting goes away, but not all. I believe Mat is currently working on reducing it even farther with a few minor tweaks.
    If we've learned anything about the 3rd gen power train and trans, it's that every single truck has its own quirks and nuances.
    Wixo[QUOTED] likes this.
  18. Feb 13, 2019 at 9:11 AM
    Anchovy
    TRD Ferguson
    OR... or... hear me out, it could buy a turbo kit from mat when they’re done :)
    HelloMyNameIs and Saeros like this.
  19. Feb 13, 2019 at 9:17 AM
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    You painted with a broad brush. I soaked it in turpentine.
  20. Feb 13, 2019 at 9:22 AM
    Captndarty
    That makes no sense to me whatsoever. The truck should still thinks it’s doing only 80 as indicated. Let’s even make believe The GPS incorporates an algorithm. Those gear ratios would still be so far off from tricking the truck into thinking it was doing 80 as aposed to the 105 or so maximum limit
Thread Status:
