Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Feb 14, 2019 at 11:08 AM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    Is anyone worried about pinion angle on the 5.29s especially on the 8" sport rear end? That had me real concerned back in the day ( I have a 2016) There wasn't much real world information with this truck at the time I re-geared so I went with 4.56s with 33.5" tires. With armor and gear I ended up grenading the rear anyway and now have 4.56s in a 9" rear end. I would have gone 4.88s at that point but the front would have had to be redone. All that said, I'm happy with the setup (gears, tune, responsiveness, and gas mileage)
  2. Feb 14, 2019 at 11:10 AM
    Oscar I
    Oscar I No longer a toyota driver
    i dont, id like to try the 93 tune but im a cheap ass and will run regular
  3. Feb 14, 2019 at 11:13 AM
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    Your order was canceled.
  4. Feb 14, 2019 at 11:16 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Yeah, and add this one to the mix: Back when we were testing for 1.04, I had stuttering or brief hesitations in quick succession under certain conditions. IIRC, it was 2500-2800 under moderate to heavy load. I was logging for Mat at the time, and didn't see missfires during these events. He sent me another file, and bingo - stuttering was gone. The culprit - VVT. My truck couldn't decide if it wanted to be in Atkinson or Otto in that narrow RPM range according to Mat.
    Reypac24, bensonxj, 2001 4x4 and 2 others like this.
  5. Feb 14, 2019 at 11:19 AM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Yep, had the same thing but not quite as bad. The VVT can cause some very strange behavior by itself.
    bshammer0 and MOC221_[QUOTED] like this.
  6. Feb 14, 2019 at 11:23 AM
    MOC221_
    Frank
    Nobody has it as bad as the Ginger lol.
  7. Feb 14, 2019 at 11:29 AM
    mkivsoopra
    mkivsoopra Member
    2018 Tacoma TRD Off-Road
    I've used a similar feature in my EcuTek/BRZ to switch between boost settings. I can see this being useful for the truck! For example, daily drive on 87, then switch to the 91/93 map (while filling up too, of course) for the extra bump in power when towing or something.
  8. Feb 14, 2019 at 11:30 AM
    Captndarty
    Captndarty Well-Known Member
    2017 Magnetic Grey limited
    Since it’s a wheel speed sensor it doesn’t make any sense. I was throwing a hypothetical with the gps which isn’t a reality.
  9. Feb 14, 2019 at 11:32 AM
    maybeme
    maybeme Well-Known Member
    So this might have been asked before - but can you run the 93 octane tune on 91 octane at higher altitudes? Take for example Winter Park, CO at over 9000'...I don't think the town offers 93. Is there an approximation/table for octane rate of change like there is one for tire pressure at altitude and/or lower temps ?
  10. Feb 14, 2019 at 11:34 AM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Wouldnt it be better if drive was the MPG mode, ECT was the performance, and the gear locking was engaged through the S mode? That way you could essentially have either MPG mode or Sport mode and lock the gears.
  11. Feb 14, 2019 at 11:46 AM
    ohioboater
    ohioboater Well-Known Member
    2017 DCLB 4x4 Sport
    Since these trucks pass a fair amount of road/engine noise into the cab, shouldn't detonation be audible? I used to have a Harley that pinged until I replaced its carb jets with larger ones. That thing sounded like someone put a coffee can full of ball bearings in a paint mixer every time I cracked the throttle more than half open - no way to mistake it for something else. I also remember several POS American cars my parents had when I was a kid in the 70s. The pinging in those was more muted but still a very distinctive, easy to hear sound.
  12. Feb 14, 2019 at 11:54 AM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Agreed
    Shellshock and Wixo[QUOTED] like this.
  13. Feb 14, 2019 at 12:18 PM
    Wixo
    Hank
    Tint, LED interior
    I found a way last night to run windows 10 on a mac. Took me about an hour to download and 20mins to erase. It uses up 48gb minimum of your laptop and you can restart it, hit alt/option, and choose between your windows or MAC OS. I deleted it right away, but it is possible. Idk that I might wanna give up that much GBs...
  14. Feb 14, 2019 at 12:19 PM
    Double Phister
    Double Phister Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
    I don't even want lock. I drive in S4 or S5 all day because 6th isn't useful unless well above 80
    (33s)
    Wixo[QUOTED] likes this.
  15. Feb 14, 2019 at 12:20 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    @Wixo i just bought a 200$ laptop off eBay that was recommended somewhere in this thread.
    I was cool with that. My MacBook is from ‘08 anyways, she’s an old lady now
    Wixo likes this.
  16. Feb 14, 2019 at 12:22 PM
    lapoltba
    CT - 06076
    Any way to just install it on an external hard drive and boot from that?
  17. Feb 14, 2019 at 12:25 PM
    n6vmo
    n6vmo Well-Known Member
    Sahuarita, AZ
    2018 DCLB OR AT Super "Priviledged"
    Bilstein 6112, ICON UCAs, 5160, AAL, 265/75/16 Falken Wildpeaks
    Nice....when is this tune releasing?
    jk
  18. Feb 14, 2019 at 12:27 PM
    Ron1965
    Ron1965 Go Bruins.......
    Ron
    Socal
    2018 Cement TRD ORSB PREMIUM/TECH
    OVtune Mooseditty Custom;DD Exhaust;Nitro 5.29’s;SCS Brushed Copper;AFe Custom CAI
    You can run Windows on a Mac through Bootcamp
  19. Feb 14, 2019 at 12:33 PM
    treimche
    treimche Well-Known Member
    Fargo, ND
    To create more hype and tease? There's been a lot of that the past few days. Teasing on Valentine's day should be illegal..........
  20. Feb 14, 2019 at 12:39 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Bud light...
Thread Status:
