Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Feb 18, 2019 at 9:02 AM
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    You download the new 1.05 (base/performance/stock) tunes via Flash Manager. It will be saved to your computer, the directory location is on the bottom left hand corner of Flash Manager. You can move your tunes to another folder, or leave it in the default location.
    Open new PCM Flash, point your tune location to the directory specified from Flash Manager.
    su.b.rat likes this.
  2. Feb 18, 2019 at 9:02 AM
    su.b.rat
    su.b.rat broken truck
    yes, they will download to a new folder created by FM. you can open the folder directly through FM, but save the address in file explorer for convenience.
  3. Feb 18, 2019 at 9:02 AM
    tjpratt
    tjpratt Well-Known Member
    Travis
    Aurora, Colorado
    2016 Limited 4X4 Tacoma
    3.75" Lift / OME OVTuned
    Am I the only one that had zero issues??
    Starting to think i'm the one that did something wrong lol
    ridinhigh95, ITDude and Shellshock like this.
  4. Feb 18, 2019 at 9:03 AM
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    Thanks!
    Now I have to wait for the A60 performance tune!
  5. Feb 18, 2019 at 9:04 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I feel something coming on, it feels like it’ll hit me the second B03 tunes are dropped. I’ll have to go home immediately
  6. Feb 18, 2019 at 9:07 AM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    SECOND GEAR PULLS TO 6800 RPM ARE AWESOME :burnrubber:
    SpeySquatch likes this.
  7. Feb 18, 2019 at 9:10 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    No issues with mine either. Went too smooth to be right? ....
  8. Feb 18, 2019 at 9:11 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Either everything in the universe aligned or you read the instructions.
    lol kidding. Working on updating everything guys!
  9. Feb 18, 2019 at 9:12 AM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    This thread should be locked so only @OVTune can post in it for the next 24 hours
  10. Feb 18, 2019 at 9:13 AM
    Shellshock
    Iowa
    maybe you are the only one that can read lol
  11. Feb 18, 2019 at 9:14 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    The new pcmflash executable can be launched on its own (as normal) -OR- from within the FlashManager app. Either launching method works just fine.
    I personally just created a shortcut directly to the new PCMflash executable that I'll use to tune the truck. I may mess with the logging in the other FM app later, but it's otherwise unnecessary after initially grabbing all the tune files and utils.
    With regards to using TechStream to clear the ECU/TCU. Is it better to do so immediately before installing a new tune, or immediately after flashing the new tune file (and before the idle learning process)?
  12. Feb 18, 2019 at 9:15 AM
    catastrofe
    Bob
    Montrose, CO
    2022 F350 Tremor
    My point is that PCMFlash is not available from within Flash Manager. Where do you see it?
  13. Feb 18, 2019 at 9:17 AM
    OVTune
    OVTune
    It is on the new version, which will be available.
    Inferno__Taco and 2016trdtacoma like this.
  14. Feb 18, 2019 at 9:20 AM
    PRO_Taco
    PRO_Taco Well-Known Member
    Ontario Canada
    2025 TRD PRO
    Ceramic coated Underground ARB rear bumper flush mount lights Trailhunter rock sliders
    Just follow instructions and things work! interesting concept... :D:rofl:
    Thats all I did. No issues...
    2016trdtacoma and Shellshock like this.
  15. Feb 18, 2019 at 9:20 AM
    catastrofe
    Bob
    Montrose, CO
    2022 F350 Tremor
    Thanks for the clarification Mat. It wasn’t obvious that your post to Speysquatch was for a “test version”.
  16. Feb 18, 2019 at 9:22 AM
    rlc177
    rlc177 Well-Known Member
    Its not just a matter of following the instructions, if you had a 64 bit windows and followed the instructions you were fine. If you have 32bit windows there is issues that Matt is addressing with the installer. A lot of people use FM on older/limited devices that can only run 32bit OS.
    Vlady and paleh0rse like this.
  17. Feb 18, 2019 at 9:24 AM
    OVTune
    OVTune
    Correct,
    if your computer is x64 you are unlikely to run into any problems with the newest version,
    on x86 it's being reworked
  18. Feb 18, 2019 at 9:24 AM
    Rider4
    Rider4 Well-Known Member
    2017 Tacoma TRD PRO
    I will probably be shot for asking, but are registrations going out or are the understandably on hold while you are working on the new release? @OVTune
  19. Feb 18, 2019 at 9:26 AM
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
  20. Feb 18, 2019 at 9:30 AM
    SpeySquatch
    2016 TRD OR DCSB
    It worked, but after overcoming some weird bugginess which Mat did help with (thank you again). Problems are beyond “just reading instructions” for those of you that think that is the only problem
    BlkTaco47 and catastrofe[QUOTED] like this.
Thread Status:
