Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Feb 18, 2019 at 7:54 PM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Bootcamp works perfectly on Mac.
    Should’ve seen me on 93 loco in the fresh stuff today.
    And @OVTune warning of possible traction loss above 5k is real.
    taco 16 and Hank Heel like this.
  2. Feb 18, 2019 at 7:54 PM
    SpeySquatch
    2016 TRD OR DCSB
    Yep it seems to flash faster.
    UntamedTaco likes this.
  3. Feb 18, 2019 at 7:55 PM
    L-SCHLEGS
    L-SCHLEGS Well-Known Member
    Nashville, TN
    2017 CEMENT TRD PRO
    I haven't "manually" installed the new PCM Flash, but the new PCM Flash is built in to the new Flash Manager, I don't think installing the new PCM flash is needed anymore with the newest flash manager build. @OVTune can you clarify if any extra downloading/installing of drivers or PCM flash is needed once newest flash manager is installed and "install all software" has been selected?
    SC4333 likes this.
  4. Feb 18, 2019 at 7:55 PM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    This is the happiest I’ve seen this thread in...... I think since the beginning!
    Can I get an amen and get everyone to bring it in for an assgrab and sing Kumbaya?!
    skyking3, prodemann, alwaysHI and 5 others like this.
  5. Feb 18, 2019 at 7:57 PM
    perkj
    perkj Well-Known Member
    Wow, quite amazing the flash speed difference.
    @OVTune just curious, how did you speed up the flash by like 10x?
    SpeySquatch[QUOTED] likes this.
  6. Feb 18, 2019 at 8:01 PM
    TWTaco
    TWTaco Well-Known Member
    Dave
    Hopefully he said by the end of the month.
  7. Feb 18, 2019 at 8:03 PM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    Not in low range.
    I could see a need for 6800 in third and fourth out in the glamis sand dunes.
    I’m loving the 91 gear lock tune.
  8. Feb 18, 2019 at 8:06 PM
    SpeySquatch
    2016 TRD OR DCSB
    Correct, everything is in the new Flashmanager.
    Inferno__Taco likes this.
  9. Feb 18, 2019 at 8:07 PM
    SpeySquatch
    2016 TRD OR DCSB
    Newer software and good battery charge levels help according to Mat
    perkj[QUOTED] likes this.
  10. Feb 18, 2019 at 8:15 PM
    L-SCHLEGS
    Nashville, TN
    2017 CEMENT TRD PRO
    Also, just to clarify as I can't find it 100% clear in the instructions, we still just flash "p5-can" and it takes care of ecu and tcu flash correct?
  11. Feb 18, 2019 at 8:16 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    @OVTune
    Tried the new 1.0.4_x86_64 file and still getting the "application was unable to start correctly (0xc000007b) message. Ticket number 4901.
    Thanks
  12. Feb 18, 2019 at 8:17 PM
    SpeySquatch
    2016 TRD OR DCSB
    P5-CANbus, yes
  13. Feb 18, 2019 at 8:18 PM
    SpeySquatch
    2016 TRD OR DCSB
    Did you try the other one? I got the same error but the other one worked (other link)
  14. Feb 18, 2019 at 8:21 PM
    L-SCHLEGS
    Nashville, TN
    2017 CEMENT TRD PRO
    1.1.99 version of PCM Flash only shows me "CAN-bus", "P5-CAN", and "GEARBOX P5-CAN"
    So I'm guess the middle one "P5-CAN" is all I need to flash? just not seeing P5-CANbus like I used too on older version of PCM Flash.
  15. Feb 18, 2019 at 8:22 PM
    SpeySquatch
    2016 TRD OR DCSB
    Apologies, P5-CAN is correct
    Note, if it doesn’t work. Close the software turn truck and retry. Mine was buggy and I had to restart. Went from Can-bus (fail) to P5-Can (success). It should take about a minute or so
  16. Feb 18, 2019 at 8:23 PM
    perkj
    All I can say is 91 gear lock is waaaayyyy too much fun! @OVTune you hit it outta the park brother!
  17. Feb 18, 2019 at 8:24 PM
    SpeySquatch
    2016 TRD OR DCSB
    How are you engaging the gearlock again? Is it ECT or just in S mode?
  18. Feb 18, 2019 at 8:25 PM
    Shellshock
    Iowa
    6800 in low range sounds like a real good way to explode some things
    hr206 and SpeySquatch like this.
  19. Feb 18, 2019 at 8:26 PM
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    ECT + S Mode I do believe
  20. Feb 18, 2019 at 8:28 PM
    L-SCHLEGS
    Nashville, TN
    2017 CEMENT TRD PRO
    And no need to flash TCU? Instructions are deff unclear on this part now. Instructions say flash tcu if needed??
Thread Status:
