Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Feb 19, 2019 at 3:33 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    The suspense is like torture. All of the build up which is going to lead to let down when the performance tune isn’t going to be as great as expected
    Chipi3s likes this.
  2. Feb 19, 2019 at 4:12 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    1.05 performance is the best tune to date.
    There are many changes between base and performance, not just throttle.
    We will be working on pending registrations, tickets, etc today
    dskakie, honey, Hank Heel and 15 others like this.
  3. Feb 19, 2019 at 4:33 AM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Any plans to post the most recent dyno results on your website?
    Edited: never mind.
    sig916 likes this.
  4. Feb 19, 2019 at 4:35 AM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    Do you have an ETA on late model ECU versions for 1.05 performance/GL?
  5. Feb 19, 2019 at 4:44 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Is the new 1.05 not available for 04B02? I can download other ECU ID's but get an Error on 0402 base and performance. I didn't see any comments on the first page so are all the ecu available at this time?
  6. Feb 19, 2019 at 4:47 AM
    Shellshock
    Iowa
    HelloMyNameIs and pinochle like this.
  7. Feb 19, 2019 at 5:16 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    1.05 FOB 91 is definitely the best tune file I've run to date.
    Smooth AND powerful. The Ginger likes it so far.
    ~150km on it, plenty more to go before I'll call it settled in.
    Thanks Mat, can't wait to see what the M/T single table torque map file brings (please keep working on that lol).
    inksin, 2001 4x4, Shellshock and 2 others like this.
  8. Feb 19, 2019 at 5:31 AM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    2020 us Dongles will have a chance at Performance :boink:
    TRDOBSESSED and BlkTaco47 like this.
  9. Feb 19, 2019 at 5:42 AM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    This is worth quoting for the new guys to this thread who want to flash the TSB themselves.
  10. Feb 19, 2019 at 5:50 AM
    Deucer01
    North Georgia
    I'm on 87 Performance on 32s. I like the shift points. If I want to hold the gear a little longer I give it a little more throttle, shift earlier I give it less. Shifting is much more responsive than the Pre-FM 1.05 93/87 Base tune. And it should shift early at light throttle.
  11. Feb 19, 2019 at 5:51 AM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Be careful flashing .CUW files as you can easily brick your ecu. They are not as forgiving as OVtune files.
  12. Feb 19, 2019 at 5:53 AM
    OVTune
    OVTune
    Luckily if you have our tune kit you can unbrick it and try again
  13. Feb 19, 2019 at 5:53 AM
    Deucer01
    North Georgia
    I see you're on 33 BFGs, load C I assume, which are much heavier than my SL Falken Wildpeaks. You might want to try the 93 Performance tune or 4.88s.
    paleh0rse likes this.
  14. Feb 19, 2019 at 5:53 AM
    Chipi3s
    San Diego
    Wait so we can use mats flashing kit to get the tsb? Wth
  15. Feb 19, 2019 at 5:55 AM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    Can we have it with the Base tip in? It really isn't possible to be smooth with it on stock wheels.
  16. Feb 19, 2019 at 5:56 AM
    Deucer01
    North Georgia
    No. You can unbrick it if you manage to brick it doing the TSB. But this is rare.
  17. Feb 19, 2019 at 5:58 AM
    OriginalMan
    Oahu 808
    2017 TRD OR 4x4
    Tunekits meaning the FM software?
  18. Feb 19, 2019 at 5:59 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    It does seem that quite a substantial amount of throttle is required to maintain shifts at 3500-4000 rpm (when trying to get up to speed quickly, say 50mph), even when I think I've already put my foot in it quite a bit. I would like to see a more even spread on gears, if 1st shifts at 3k, 2nd goes to 3k, 3rd goes to 3k with a steady throttle position. Difficult to explain, but basically just keep accelerating at the same pace with a steady throttle.
    Tharris242 and Reegsy like this.
  19. Feb 19, 2019 at 5:59 AM
    tacogravy
    tacogravy Well-Known Member
    Gravy
    Mantua, Ohio
    17 TRD OR 4x4 Quicksand 6MT
    TRD Pro Grill, TRD Sport Hood, BAMF Sliders, Bilstein 5100's F&B, BF Goodrich KO2 265/75R16, Old Man Emu 887 Front, Head Strong 3 Leaf AAL Rear (Overload Leaf Left In), OVTuned, De-Badged. Accumulator Delete Mod.
    Tip in is perfect.
  20. Feb 19, 2019 at 6:00 AM
    Deucer01
    North Georgia
    I should also let you know I run ECT on all the time (thanks MESO) so you might want try that with 93.
Thread Status:
