Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Feb 19, 2019 at 12:39 PM
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    ...soooooooooo, what size tires can I fit with the 93 performance tune?? :D
    No TSB, so only the base tunes for me for now...but despite being just a BASE/MPG tune, I can say that I loved my ride to work this morning!! @OVTune , you said you can't work magic, but I beg to differ cause I love the tune!!!! Can't wait for gearlock too!!
    Beerpayzdabillz likes this.
  2. Feb 19, 2019 at 12:42 PM
    ChickoSM1808
    ChickoSM1808 Well-Known Member
    Michael
    2018 dcsb TRD Sport (OVTuned)
    OVTuned, TRD Pro grille, 32's and many more
    My truck has had a stumble since I bought it new. I flashed this morning before my trip across ohio. It seems to be non existent so far. A little more power at highway speed and the shifts seem to be better between 3-4. Its a lot smoother also.
  3. Feb 19, 2019 at 12:42 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    you can flash any of your files that match your ecu ID, old or new.
    Lots of registry keys have been sent out.
  4. Feb 19, 2019 at 12:46 PM
    SpeySquatch
    2016 TRD OR DCSB
    Yep, just took 87 base for a spin and it is great. Very stable, shifting is nice, response is a bit better than previous 1.05, power is better through rpms (it seams). This is how these trucks should have come. Nice job @OVTune
    taco abbo and Supr4Lo[QUOTED] like this.
  5. Feb 19, 2019 at 12:58 PM
    Taco16LB
    Taco16LB Well-Known Member
    @OVTune I flashed 91 performance on the truck and it was awesome but the tip in it was a bit much and with ETC was insanely hard to start without spinning tires after 50 miles on it . Then flashed 91 base tune and it seemed to tame so tried to go back to 91 performance and not use ETC. Did identify and all was good , chose 91 performance tune and checked write . It did the chksum and battery check all was good , went to flash and it did it in about 1.5 seconds , and said it was completed successfully . We idled and went for a drive and knew instantly it did not go to the performance tune . the tip in is impossible not to notice so it did not change to the performance tune . Any one else have this happen ?
    I do not know how Mat got this engine to wake up like this in the performance tune but he did , and we want it back !
  6. Feb 19, 2019 at 1:02 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    hoping for new registry key after computer swap (Zendesk request sent) and 04B03 Gear Lock. Soon ??
  7. Feb 19, 2019 at 1:06 PM
    Dirk_Pitt
    Dirk_Pitt Well-Known Member
    Carrollton, GA
    2017 Barcelona Red Tacoma Limited
    Been driving 1.05 93 Performance tune for two days on my completely stock 2017 Limited. A few "observations":
    1. The 2-->1 downshift "clunk" came back cold and hot.
    2. The "tip-in" is a bit much for me.
    3. Easing through parking lots at slow speed would cause the truck to surge/buck.
    4. I would occasionally hear detonation in the higher RPM's (two different tanks of 93 from two different gas stations).
    I never had any trouble installing the new software or tunes. I used TechStream to clear the ECU and TCU after flashing. I did the "idle for 10 minutes" on the first startup. My truck gets 93 octane every fill-up.
    Just a little history, my truck has ~14,500 trouble free miles and I have used tune versions 1.04R, 1.05, 1.05 idle fix, and now 1.05 Performance (all 93 octane). I just flashed back to 93 1.05 Base to give that a try.
    Again, this is not a complaint, bug report, or anything of the such. Just observations over the past two days. 1.04R and 1.05 idle fix are AMAZING in my truck. I am hoping the new 1.05 Base is similar.
    Eticket, Reypac24 and 2017TRDpro like this.
  8. Feb 19, 2019 at 1:07 PM
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    Good. Let them "read it" and let them give me a hard time. I'll be glad to tell them how their piss poor stock tune almost got me killed. Mat has said that he'd provide cold hard data if a case ever ended up in a court of law.
    Tac0Tic0[QUOTED] likes this.
  9. Feb 19, 2019 at 1:16 PM
    OVTune
    OVTune
    If the tip in is a bit much for everyone I can make new versions with a milder tip-in. After 02/03/60/61. With new flash manager its super easy to do wide updates so no problem at all.
    Regarding any detonation, until the ignition trims have fully set in it can happen. Especially the first few times you go through that rpm range.
    honey, 2016trdtacoma, SC4333 and 15 others like this.
  10. Feb 19, 2019 at 1:19 PM
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    Milder tip-in would be awesome Mat :cheers:
  11. Feb 19, 2019 at 1:28 PM
    SpeySquatch
    2016 TRD OR DCSB
    Right now the tip-in is very similar to that of the older 6.2L Ford Raptor. I got to drive Tom Cruise's stuntman's Raptor and it felt just like that...except it was a cable throttle so it was IMMEDIATE. Not sure if that is good or bad
  12. Feb 19, 2019 at 1:29 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Yes, long time ago.
  13. Feb 19, 2019 at 1:30 PM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    yes please! :D
  14. Feb 19, 2019 at 1:30 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    is the latest link in dongle instructions the newest up to date pcmflash?
  15. Feb 19, 2019 at 1:31 PM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    The 93 performance tune is aggressive and some people really like it. I liked it for the fun factor, but it wasn’t to my liking for daily driving.
    I’ve switched to 91 performance and like it much better for my daily drive.
    Just don’t kill the option for those who like the aggressive, when a less aggressive option is already available.
    Beerpayzdabillz and LDS 77 like this.
  16. Feb 19, 2019 at 1:31 PM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Filled up with 91 octane today in preparation of this flash. Now, please send us our registration ID email.
    Rider4 likes this.
  17. Feb 19, 2019 at 1:33 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    I've driven a 6.2L Raptor before and the tip-in wasn't excessive.
  18. Feb 19, 2019 at 1:35 PM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    Willing to test, had submitted my concerns this morning via email ticket#4969. :drunk:
  19. Feb 19, 2019 at 1:36 PM
    mZiggy
    mZiggy Honey badger
    Marc
    @Rocky.Mtn did you ever get everything worked out properly with your tuning software, since you're using a Windows tablet? I'm still interested in replacing my laptop with a Windows tablet as well
  20. Feb 19, 2019 at 1:37 PM
    GoldenBrew
    Golden, Colorado
    yes - flash manager includes both pcm (dongle) and p5flash (dongle-less). Just be sure you select the proper link for your PC (x86 bit or x64 bit) and follow instructions. see the op for links.
Thread Status:
