Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Feb 20, 2019 at 4:14 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    But Mat has previously said to do the TSB if you wanted to, but it wasn't necessary. I don't recall him mentioning development time.
  2. Feb 20, 2019 at 4:16 AM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    You're missing my point.
    Shellshock, pinochle and mZiggy like this.
  3. Feb 20, 2019 at 4:16 AM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Let's not speak on behalf of mat or ovtune. This will cause plenty of confusion let alone this thread is already confusing.
    Neutron, Shellshock and DES2009 like this.
  4. Feb 20, 2019 at 4:18 AM
    Deucer01
    North Georgia
    If you're referring to me, I wasn't speaking for Mat.
  5. Feb 20, 2019 at 4:38 AM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
  6. Feb 20, 2019 at 5:27 AM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    6mile trip to work this morning got me 28 misfires, the most I've seen.
  7. Feb 20, 2019 at 5:28 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    Cold engine?
  8. Feb 20, 2019 at 5:30 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    Indeed, although it's 74f here so not 'cold cold'.
  9. Feb 20, 2019 at 5:30 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    sheesh! are you on the new 1.05?
  10. Feb 20, 2019 at 5:32 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    Yes, 93 Base
    BlkTaco47[QUOTED] likes this.
  11. Feb 20, 2019 at 5:34 AM
    Deucer01
    North Georgia
    I'd flash back to stock.
  12. Feb 20, 2019 at 5:34 AM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    Try some E3 spark plugs :rofl:
  13. Feb 20, 2019 at 5:35 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    It's odd as I only got 1 going home on Monday, but then it was 85f and got up to temp quickly.
  14. Feb 20, 2019 at 5:36 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    What cylinder, What temp, etc etc
    This does absolutely nothing to help see the situation and only helps to cause more forum discourse. Here we go again. Always the same person too. Sigh..
    I'm starting to think that trucks that get high misfire rates... since it's not a universal problem.. is related to a hardware component on that truck. Just like the stuttering issue on some trucks in 5th and 6th.
    Someone in here, don't know who, has a brand new 2019 and it does it right off the lot. The said they've fought with toyota forever about it.
    I have verified multiple times that our test truck gets no out of the ordinary 2-3 misfires per driving cycle. Tested multiple times in different temps, including extreme cold.
    Mr. Nobody, SigSense, inksin and 9 others like this.
  15. Feb 20, 2019 at 5:37 AM
    TEXAS BS
    TEXAS BS Formerly known as MMXVII
    JB
    Texas
    2017 ACLB TRD OR 4X4
    @OVTune I have noticed on 93 base a momentary deceleration at each shift under 50 mph. It takes place during the actual shift and is enough to feel in the upper body. It feels just like letting the clutch out on a standard with engine rpm too low. 110 miles on 93 base and this sensation has been consistent.
    It makes no difference if constant peddle or accelerating
  16. Feb 20, 2019 at 5:40 AM
    OVTune
    OVTune
    I can't solve anything reading random forum posts.
    I need your ECU ID, octane you flashed, mods, etc.
    To zendesk.
  17. Feb 20, 2019 at 5:43 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    'Always the same person'
    You've got tickets from me, I'm yet to hear anything from you. I get why you don't want this on the forum, it looks bad for the tune.
    28 misfires for a 6 mile trip, across all cylinders (between 3 and 6 mostly). Temp was cold start in 74f weather. Didn't go above 50mph during the trip due to start stop traffic, didn't go over 2500rpm.
    Just because only certain users are actually logging for misfires... does not mean it isn't universal. Stop blaming the hardware and 'it does it stock', 'It's a Toyota thing'.
  18. Feb 20, 2019 at 5:46 AM
    OVTune
    OVTune
    Actually it is mostly you, and it's a repeat thing.
    You have our logger with Flash Manager, you have always been over critical, which you even admit multiple times. I think at this point you just like to bring attention around. There has been times it seems you go out of your own way to find something you don't like just to post here. As if it's in any way helpful.
    If it does it stock it's not a stock issue?
    If your truck has continual issues, I dont think the tune is going to work for you. Flash the truck back to stock, return it I'll happily refund you. I give up.
    There are multiple people who do log misfires and get nothing out of the ordinary. Then there are some trucks that get high amounts at random times.
  19. Feb 20, 2019 at 5:51 AM
    Fearthisbeard
    Fearthisbeard Well-Known Member
    Josh
    Gilbert AZ
    Taco
    So couldn't he just send the TSB tune out with the other tunes that way everyone is on the same starting point ?
  20. Feb 20, 2019 at 5:58 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    I'll email the helpdesk for the address.
Thread Status:
