Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 6, 2019 at 11:06 AM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    I flashed from 04B03 to 04B04 straight to performance tune. I never gave 04B04 stock a chance.
  2. Mar 6, 2019 at 11:09 AM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I had an issue with my FJ that I just learned to live with. It started around 60k miles for me and eventually ended up as a recall(not for me). At just the right acceleration request (light) at just the right rpm, the torque converter would start to shake in a very pronounced manner. It didn’t matter what gear. What mattered most was the right rpm band, and right load.
    I tried to get the dealer to address it and I could reproduce it at will. On the drive after an oil change and tire rotation, he says “Oh, someone left one of your tires loose and it’s wobbling. That wasn’t it of course.
    I think ultimately the problem was that tolerances were just a hair off on manufacturing design and the torque converter would lock/unlock at high frequency. I don’t recall the frequency but I did plot it once with an iPhone app.
    It never did it when not in overdrive: TC locked. I wonder if this could be something similar.
  3. Mar 6, 2019 at 11:19 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    it is TC shudder.
    Mat optimized it on new revision and made it better, but there is certain combination of Engine load and RPM that cause it. In my case it ~1200 RPMs, 80-85% load and TC is locked (or whatever status of 1 means) either on 5 or 6 gear.
    Prior to TSB it was even worst, it was somewhat improved in TSB version. But yes, this is a design issue
  4. Mar 6, 2019 at 11:24 AM
    JPatzig
    JPatzig Active Member
    I'm in the same boat as you, I'm 90% happy except this "dead pedal" feel when highway cruising. Think I might make another post, try to illustrate the relationship between throttle and gear shifting.
  5. Mar 6, 2019 at 11:34 AM
    treimche
    treimche Well-Known Member
    Fargo, ND
    The "dead pedal" feel when highway cruising is so that the transmission doesn't instantly jump down to 4th gear constantly. The engine has plenty of power and torque to use 5th gear at almost any highway speed. The pedal feels dead below 2000 RPMs, where there is zero power or torque. Anything under 2000 rpms is just flat out lugging along.
    TS7xTaco likes this.
  6. Mar 6, 2019 at 11:47 AM
    MajinRonin
    MajinRonin Active Member
    17’ Inferno TRD OR AT
    These trucks w/auto come under geared from the factory. No amount of software is going to make up for the fact you need to change your hardware.
    ITDude likes this.
  7. Mar 6, 2019 at 12:07 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    If you’re gonna change the hardware might as well put an actual truck engine and transmission in. Then have mat properly tune it :)
    ITDude and Shellshock like this.
  8. Mar 6, 2019 at 12:10 PM
    JPatzig
    Let me start with: I love this tune, I think Mat has done some amazing work, and like many others, the tune saved me from strongly considering selling my 3rd gen for something else. I do alot of highway driving, and the stock tune is pure chaos at 60-80mph. I wanted to illustrate what I'm "feeling" on the highway with the various 1.05 tunes. This is ONLY referring to gears 3-6, and how 1.05 appears to handle shifting in relation to how hard the gas pedal/throttle is pressed. I know that Mat posted a few months back, the reasons why the tune reacts this way, I can't find the post for reference. And yes, I submitted a ticket back on January 29th for this issue. And honestly, I realize this is more of an "enhancement" request, rather than a "defect". This "issue" has come up here and there in this thread, but I'm surprised it isn't discussed more, considering some of the other topics that are brought up.
    Full disclaimer, I have no proof or actual data to back up these shift points...the throttle percentages could be way off. I'm simply trying to illustrate what my brain/foot is feeling. I've mostly run the 87 tune on 87 octane, although the 91 and 93 tunes (with respective octane) felt very similar for this particular issue.
    Yellow: Stock tune - the truck shifts to 4th way too early/easily. I think nearly everyone agrees this is frustrating and no fun to drive on the highway with.
    Green: 1.05 Base: 55mph - 65mph - I think this scenario is almost perfect, although if it were up to me, I think 4th could kick in a little sooner, around 50% perhaps. I believe this gap between 25% - 5th and 60% - 4th is what everyone considers "dead pedal".
    Purple: 1.05 Performance: 55mph - 65mph - Dead pedal seems even more accentuated because of the aggressive tip in.
    Red: 1.05 Base: 66mph or faster - This is my biggest concern. I've run 1.05 Base 87 on 87 gas for 8+ tanks now. In Texas, most people drive around 70-80mph on the highway. Outside of the city, people drive 80-90mph. I don't think I'm an aggressive driver, but there's often scenario's where I need more power/torque/response/speed/whatever the right word is, than 5th gear will give me. This includes: big hills, windy days, passing people, heavy loads, towing, etc. In all of these scenario's, when I have been driving over 65mph and I apply considerable throttle, my truck always shifts from 5th directly to 3rd. This happens no matter how quickly or slowly i apply more pressure to the gas pedal. This doesn't seem like a big deal, but on a 5 hour drive, headed into a 20mph wind, with lots of hills, I experience an almost constant dance between being bogged down in 5th, only to apply more throttle and be launched into oblivion in 3rd, then back to 4th, 5th, and repeat. It gets old really fast.
    I realize this is subjective, and most of us want the truck to hold 5th gear well on the highway, but I feel like it's a little bit over exaggerated. In cases where we actually need 4th gear, I think it should potentially shift there sooner, at all speeds, and definitely not be skipped, directly to 3rd.
    It may not even be possible to address this issue, but I think it's worth discussing. If there are more users that feel the same, perhaps adjustments can be made.
    Mat, thanks again for all your hard work, and I think all of us are excited for future development.
    Edit: I drive a 2018 OR AT, 2.5" lift, 31.5" Michelin LTX's. Everything else stock.
  9. Mar 6, 2019 at 12:12 PM
    Shellshock
    Iowa
    SOMETIMES it does not clear learned values
    on some trucks
    on most it works just fine
    people need to stop trying to fix problems they dont have lol
    I've never once cleared values on my truck. No nee too.
  10. Mar 6, 2019 at 12:13 PM
    Shellshock
    Iowa
    this guy gets it.
    if you clear values or flash, ignore anything until you've run a tank of fuel through it.
    Deucer01 and wiljayhi like this.
  11. Mar 6, 2019 at 12:15 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    ....or two.
    Deucer01, wiljayhi and tonered like this.
  12. Mar 6, 2019 at 12:16 PM
    Shellshock
    Iowa
    yeah. drop that slush box and put in a Manual transmission. problem solved :thumbsup:
    ITDude, nxcess, crigg93 and 2 others like this.
  13. Mar 6, 2019 at 1:14 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Exactly what I just did today....didn't even drive 04b04 at all.
    bgoods and TWTaco like this.
  14. Mar 6, 2019 at 1:22 PM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    I feel your pain living in Texas. Was making weekly trips from Lake Charles LA to Houston with min 10-15 mph winds. I had to drive in 4th all the time to keep a 80 mph pace or get run over. Hell the tipping point of getting this tune was a trip back from Big Bend State Park around this time last year couldn't even keep speed up in 4th it was ridiculous. The rest of the convoy was getting 17-18 mpg while I was getting 14 mpg while dancing back and forth through gears.
    kevron likes this.
  15. Mar 6, 2019 at 1:28 PM
    ihatemytruck
    Dave
    Southern California
    Just flashed 1.05 gear lock after updating to 04B40. Only drove a few miles, but didn't think the tip in was that bad. Stock everything but the tune.
  16. Mar 6, 2019 at 1:37 PM
    L-SCHLEGS
    L-SCHLEGS Well-Known Member
    Nashville, TN
    2017 CEMENT TRD PRO
    If 4.88s will make the 60-80 driving better I’m all for it. Will literally do it ASAP.
    Does anyone have feedback on 4.88s with this newest tune? Are the shift points crazy since it’s dialed in with relatively small tires and stock gears?
  17. Mar 6, 2019 at 1:44 PM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    same here, never had an actual need to.
    alwaysHI likes this.
  18. Mar 6, 2019 at 1:48 PM
    MajinRonin
    I can’t give feedback on 4.88s. But I can for 5.29s. When on the freeway, I normally try and stay around 65mph. Haven’t driven it over 70 much since Ive regeared, because I baby it. But 60-70 on the freeway (33’s 10 ply) the truck stays in 6th gear on flat and small hills. Larger hills itll go to 5th. Big ass hills 4th.
    paleh0rse likes this.
  19. Mar 6, 2019 at 1:52 PM
    tacoma28
    tacoma28 Well-Known Member
    Sergio
    Arizona
    05 Speedway blue sr5 4X4
    Thanks! is there any instruction for that?
  20. Mar 6, 2019 at 1:53 PM
    tacoma28
    Sergio
    Arizona
    haha nice!!! how can I do that lol.... do you have any instructions?
Thread Status:
