Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 7, 2019 at 10:27 AM
    E$Yota
    E$Yota Well-Known Member
    Ethan
    Dothan, AL
    2016 Tacoma TRD Sport 4X4
    FN wheels' version of the TRD Pro 4Runner, TRD Pro front skid plate, Low Range Offroad 3/1 lift, JBA Offroad upper control arms, TRD Pro Shift knob, OV Tuned, 4.88s, 285/70/17 BFG KO2s
    85 4runner = 80-95 HP and 120ft lb trq
    3rd Gen Tacoma =278 and 265
    Big difference in running a 8 inch ring gear locked full time with 33s with 2.5 times the power. Can it be done? Yes, under a alwats cognizant mind.
    PB FAB likes this.
  2. Mar 7, 2019 at 10:49 AM
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    Roughly 80 miles into the 1.05 87 base, and I’m digging it a lot.
    I’m also geared with 4.88’s.
    Passing slow vehicles on the highway is a breeze without hitting s4, and I can actually climb minor/moderate hills in 5th for once (which was my biggest complaint).
    We’ll see how she does loaded for camping before I even decide on flashing the performance tune. Give me another month and I can update that since I plan on driving thru a major elevation change while being loaded with coolers and fishing crap
    MajinRonin likes this.
  3. Mar 7, 2019 at 11:16 AM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    Many people are experiencing the low rpm stumble. Mat said it may be due to the torque converter but isn’t sure. He told me via zendesk he is working on a tune fix but it isn’t released yet. I believe this is happening on more trucks than are reported because some people are just less sensative to it.
  4. Mar 7, 2019 at 11:35 AM
    Saiji Satoh
    Saiji Satoh Well-Known Member
    Saiji
    I do have experience that "bumpy road feeling" mostly uphill and low rpm with 91 performance tune. When that happened use S-mode as well.
  5. Mar 7, 2019 at 11:35 AM
    tacomabro69
    tacomabro69 Well-Known Member
    You may have to sell your truck..
    Mat said the Tip in is comparable to a Toyota Prius. Your embarrassing us taco owners man!
    maybeme and Chipi3s like this.
  6. Mar 7, 2019 at 11:37 AM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    I spit my drink out
    Edit- im 265/70/17 ko2 and tip feels great(thats what she said). I could see it maybe being harsh for a lighter stock tire?
    Shellshock likes this.
  7. Mar 7, 2019 at 11:44 AM
    AnotherUser256
    AnotherUser256 Well-Known Member
    Magnuson TVS1900 Supercharger with 87mm pulley, Catted OVTune dumptubes, Doug Thorley 2.5in y-pipe, custom mufflers, 76mm Tundra throttle body, 5.29 Yukon gears, JamesT custom fuel rails, Yotawerx 87mm tune, Eibach Pro Truck Stage 2 suspension. And some other stuff.
    @OVTune There has been a lot of talk of updating to the latest TSB, using Techstream, in this thread. (04B04 I believe, correct me if I am wrong) Is it your recommendation to upgrade? Or would you recommend people stay at their current version, assuming they are happy with it? In my case that would be 04B02.
  8. Mar 7, 2019 at 11:47 AM
    Chipi3s
    San Diego
    If you can, do it. If not then just wait for the tune. But if you do it, youll get the tune sooner as its already available for 04B03.
  9. Mar 7, 2019 at 11:56 AM
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    Highway driving characteristic between 91 base and 91 performance is different. Granted I only had 91 performance on my truck for 2 days. Absolutely cannot stand the tip-in. I think it is dangerous driving in snow/icy roads. That was MY experience with 91 performance, plenty of OVT customers love the performance tunes.
    Back to highway driving. With 91 base, truck is much more willing to downshift to 5th on hills to maintain speed. Say I'm doing 65mph uphill, truck slows down, I press skinny pedal slightly, truck unable to maintain speed, it will promptly downshift to 5th to maintain speed. Same behavior when faced with headwind/crosswind conditions. Before you ask, it is downshifting to 5th, not TC unlocking, according to OBD Fusion.
    With 91 performance, say I'm doing 65mph uphill, truck slows down, I press skinny pedal slightly, truck unable to maintain speed, it takes longer compared to 91 base before downshift to 5th. I could be doing 60-62 before truck will downshift. I feel like there is a small "dead zone" in the pedal, truck slows down, I press skinny pedal down little bit, nothing, press down little more, finally downshifts to 5th.
    I prefer the highway driving characteristic of 91 base, the 6-5 shift is so smooth, sometimes I don't even notice it. I rather the truck shift to 5th and maintain speed, then keep 6th and loose speed.
  10. Mar 7, 2019 at 12:13 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    @SpeySquatch
    yep - plenty of power. No issue holding speed and passing up mountain passes - using S mode and locking it down to no higher than 5th gear. So far I would say the new version of 1.05 base on 04B04 is better than prior 1.05 on 04B03. Used some of the skinny pedal today merging with traffic and the response tip-in is way better - no way you could floor it as it has way more getup and go. Very impressed. Power towing seems to kick in just below 3000 and still kicking in mid to upper 4's. I drive with a light foot so I seldom run it past 5k.
  11. Mar 7, 2019 at 12:18 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    @OVTune , actually glad handheld are not ready yet. Looks like tune just keeps getting better.:hattip:
  12. Mar 7, 2019 at 12:22 PM
    Twidget61
    Twidget61 Well-Known Member
    Finally got the first tune downloaded to my truck ( 1.05 91 performance on 2018 TRD OR with 265/75/16 ST Maxx tires). Only driven a few miles, but I can definitely tell there’s been a change for the better. Tip in seems fine to me. Truck definitely has more pick-up. Will post a detailed review after a couple of tanks of gas to make sure it’s settled.
    SpeySquatch likes this.
  13. Mar 7, 2019 at 12:26 PM
    VersaTrax
    VersaTrax Well-Known Member Vendor
    Nicholas
    2019 Toyota Tacoma
    Has anyone noticed a decrease in mpg from going from the initial 1.05 to the updated 1.05? I've consistantly been getting 17+ with the initial realease 1.05, now with the updated 1.05 I'm getting 14 mpg with the same driving conditions. Same 87 base tune for both versions.
  14. Mar 7, 2019 at 12:28 PM
    SpeySquatch
    2016 TRD OR DCSB
    if you are using the performance tune you will see a dip in mpg until you get use to the throttle response. On the highway I was seeing an increase an mpg, but in commuting/traffic/stop-n-go I've seen 15-17
  15. Mar 7, 2019 at 12:29 PM
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    I only use the 87 base for both tune files.
  16. Mar 7, 2019 at 12:30 PM
    cstern1
    cstern1 Well-Known Member
    Caleb
    KCK
    2017 DCSB Sport
    Any temperature changes to coincide with it? Warm up time makes a big difference, and I don't mean just idling. I get better MPG on a trip when its 40F out or above than when its 20F out. My theory is the longer it takes to get to operating temp, the worse the MPG is. Granted you showed whole tanks so maybe temp change isn't it.
    brizower and SpeySquatch like this.
  17. Mar 7, 2019 at 12:31 PM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    I did the same (except to Gearlock). And it turned out just fine.
    DiabloTRD likes this.
  18. Mar 7, 2019 at 12:33 PM
    SpeySquatch
    2016 TRD OR DCSB
    in that case after 300 miles you should see it come back up to norm if not better. This is the case for all tunes.
    I managed to get 12mpg with the performance tune (as my lowest mpg yet) because I was having too much fun when the tune was brand new. Im finding that if I get the truck up to speed then let off the throttle to maintain speed rather than slowly getting to speed I get noticeably better mileage.
  19. Mar 7, 2019 at 12:42 PM
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    Yeah, I'm going to give it another tank to see if it is just a anomaly. That's why I'm just asking around to see if other members are seeing the same.
    SpeySquatch[QUOTED] likes this.
  20. Mar 7, 2019 at 12:57 PM
    ChickoSM1808
    ChickoSM1808 Well-Known Member
    Michael
    2018 dcsb TRD Sport (OVTuned)
    OVTuned, TRD Pro grille, 32's and many more
    thats the issue I've had since I bought my truck
    Saiji Satoh likes this.
Thread Status:
