Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 9, 2019 at 6:48 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    [QUOTE="Trdsport19, post: 20061881, member: 272295"
    it seams 4.56 would be a little sweeter for most driving. 3.91 is pretty tall, any idea what gears Mat has on the test truck?[/QUOTE]
    Stock for now. He has some 4.88 gears waiting to be installed IIRC.
  2. Mar 9, 2019 at 7:13 AM
    Trdsport19
    Trdsport19 Active Member
    dan
    2019 magnetic grey metallic trd sport DCSB
    Stock for now. He has some 4.88 gears waiting to be installed IIRC.[/QUOTE]
    Thought I read he has 32” tires, would like to see what he comes up with the 4.88 gears
  3. Mar 9, 2019 at 7:19 AM
    maybeme
    maybeme Well-Known Member
    Hmm...I haven't spent much time with 87 base (~200 miles) and 87 performance is brand-new to me -- but I don't think tip-in is aggressive at all. Starting to wonder if the tune applied correctly, because while I THINK it feels different, it might not be. I guess I need to flash GL to know for sure....
  4. Mar 9, 2019 at 7:29 AM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    When I went to 91 perf with GL, I did not clear learned values and I had tried numerous other versions in the past 1.5 yrs. I did clear going back to 91 base. I might try 91 perf again along with clearing.
  5. Mar 9, 2019 at 8:22 AM
    SpeySquatch
    2016 TRD OR DCSB
    If you cleared the ECU the tip in does seem less aggressive than when I first flashed it without clearing anything
  6. Mar 9, 2019 at 8:39 AM
    5500
    5500 Active Member
    Ed
    Cape Cod
    2019 Cement Sport
    New to TW and new Taco owner. Apologize for not having read all the 2100+ pages of this thread, so if I'm redundant, please excuse me. Just took delivery of my new TRD 4x4 Sport Access cab automatic and was initially very underwhelmed with drivability. Hunting and shifting like crazy, anemic/delayed throttle response and pathetic gas mileage... After driving a 2013 FJ for 175k miles, I guess I was expecting similar performance and mileage (consistently got 19.5-20mpg average with spirited driving). First tank of gas was on the dealer, 87 octane. Struggled to break 17 mpg ( ~320 miles,mostly all highway). 2nd tank is 89 octane and after 100 miles I'm showing 19.4 mpg average (again, mostly highway miles) but more importantly driving is 100% better. Almost no hunting, improved throttle response, will actually accelerate without downshifting (with a gentle squeeze as long as the engine is turning 2k rpm). Its probably way too soon to draw any permanent conclusions but what I'm wondering is will using a higher octane fuel address so many of the drivability issues that are frequently discussed? Are most people who've downloaded this tune still using 87 octane? Anyone else with similar experiences? Although initially disappointed with the drivability, I do love my taco and its the best color! Thanks.
    skyking3 likes this.
  7. Mar 9, 2019 at 8:44 AM
    jekerskel
    jekerskel Well-Known Member
    Zach
    Bellingham WA
    2004 SR5 Extended cab 2wd 5 speed
    V-LED low and high beam headlights.
    Discovered early on before the time that 91 octane improves the truck quite a bit. 11.8:1 compression cannot survive on 87 octane. The .edu has to do all sorts of things to keep detonation from happening.
    The Ford 3.3 has a 12.1:1 and is even worse...
    5500 likes this.
  8. Mar 9, 2019 at 8:52 AM
    5500
    5500 Active Member
    Ed
    Cape Cod
    2019 Cement Sport
    Yeah, my guess is it must be knocking like hell on 87, causing timing to be pulled, and leaving so little power that the tranny is trying to just keep the damned thing rolling.
  9. Mar 9, 2019 at 9:21 AM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    So you listened to the whole video? lol
  10. Mar 9, 2019 at 9:43 AM
    SC4333
    Grant
    FL
    @Trdsport19
    Yes, his tires are 265/75R16 load range E, but up to this point, his gearing is stock.
  11. Mar 9, 2019 at 9:49 AM
    Deucer01
    North Georgia
    On 87 Performance tune and 87 gas. Knock feedback is from -2 to -4 degrees during daily commutes. Is that a lot?
  12. Mar 9, 2019 at 10:03 AM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    That could blow up an engine o_O
  13. Mar 9, 2019 at 10:04 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Normal, baseline is -3
  14. Mar 9, 2019 at 10:07 AM
    Shellshock
    Iowa
    Toyota’s shitty tuning could blow up an engine!
    kevron, chittyrox, hbaade and 2 others like this.
  15. Mar 9, 2019 at 10:14 AM
    Chipi3s
    San Diego
    I was just teasing him :bananadead:
    Deucer01 likes this.
  16. Mar 9, 2019 at 10:47 AM
    Deucer01
    North Georgia
    :rofl:
    Chipi3s[QUOTED] likes this.
  17. Mar 9, 2019 at 11:43 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Yes - very normal to see it between -2 to -4 for me but it will pull/advance timing based on that. Depending on my driving situation (city / highway) my knock correction will be running at 26-29degrees on 93 octane. When it gets lower than -5 is when so can hear audible knock and you’ll notice the timing pulled down to get it back to -3
    Deucer01[QUOTED] likes this.
  18. Mar 9, 2019 at 12:48 PM
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    Just ordered, thanks for the discount @OVTune
    Installing windows with Bootcamp right now and waiting anxiously for the kit to arrive!
    TRDOBSESSED and lapoltba like this.
  19. Mar 9, 2019 at 12:54 PM
    Chipi3s
    San Diego
    I loose throttle responce at highway speeds, it wont raise revs or down shift untill im at about 85% throttle or so. Anyone else having dead peddle issues on highway?
    91octane gearlock tune.
    peppinoss and Ron1965 like this.
  20. Mar 9, 2019 at 12:55 PM
    Deucer01
    North Georgia
    I would see a -5 occasionally right after flashing but never lower. My knock correction runs 20 to 24.
    bshammer0[QUOTED] likes this.
Thread Status:
