Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 9, 2019 at 2:33 PM
    Lita4x4
    Lita4x4 Well-Known Member
    Daniel
    California
    2017 DCLB TRD Sport
    do you drive with ect on?
  2. Mar 9, 2019 at 2:39 PM
    Shellshock
    Iowa
    Auto guys:
    “MY TRUCK SHIFTS ALL THE TIME!!!!1! MAKE IT STOP!!”
    *flashes gearlock and truck doesn’t shift*
    “GUYS WHY WON’T MY TRUCK SHIFT???”
    :frusty:
    hr206, Hank Heel, dually and 9 others like this.
  3. Mar 9, 2019 at 2:42 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Manual guys:
    *shifts to R for race mode while doing 60*
    “GUYS MY TRANSMISSION JUST BLEW UP”
    :rofl:
    Boost3, alwaysHI, TWTaco and 5 others like this.
  4. Mar 9, 2019 at 2:45 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Only when gear locked. Matt already explained its the messed up shift logic from Toyota. He will fix it sometime this year
  5. Mar 9, 2019 at 3:11 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    When in S gear lock it will down shift just fine if you manually intervene and select the lower gears.
    You can select a higher gear to up shift but it won’t upshift unless RPM is high enough. 2200 sounds about right.
    The way I’ve been using my gear lock is to limit the top gear to either 4 or 5 and allow the trans to auto upshift and manually intervene on the downshifts. I found that it was a bit jerky in 1st gear if I did the manual upshifts. That may change when I hook up my travel trailer and have the added weight resistance to counter the torque in the lower gear.
  6. Mar 9, 2019 at 3:19 PM
    Iceman_JD
    Iceman_JD RIP Nicky
    Phoenix Az.
    2017 Tacoma off road
    Magnaflo catback exhaust, K&N cool air intake, Xenon Headlights, Led high beams, Led yellow fog lights, Gentex rear view mirror with homelink auto dimming and compass, TRD Pro Tail lights, TRD front Grill, side steps, Led backup lights.
    Off topic and this is to Mat hopefully he'll see this post.
    I just bought a V6 2019 SXE Toyota. (looks badass) Do you have any plans in the future to add a tune for this car. It's my understanding that the engines are the same that is used in the Tacoma?
  7. Mar 9, 2019 at 3:29 PM
    JabambyBrew
    JabambyBrew Well-Known Member
    JB
    Denver NC
    2019 Toyota Tacoma TRD PRO
    Thank you! Now I understand.
  8. Mar 9, 2019 at 3:31 PM
    Anchovy
    TRD Ferguson
    Not as similar as you think. Mat said he copy and pasted the tune from the Camry to his Tacoma and only saw a 5(?) horsepower gain which is a far cry from the camry’s 22 more horsepower over the Tacoma
  9. Mar 9, 2019 at 3:33 PM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    This is embarrassing. :D
  10. Mar 9, 2019 at 3:35 PM
    Iceman_JD
    Iceman_JD RIP Nicky
    Phoenix Az.
    Yeah but there is so much to be done for throttle response and shifting. Oh yeah a nice flat peak torque curve around 3000-4000 rpm.
  11. Mar 9, 2019 at 3:37 PM
    Anchovy
    TRD Ferguson
    I’m sure once the Tacoma gets ironed out mat will spread the orange virus across more Toyota vehicles
  12. Mar 9, 2019 at 3:51 PM
    jrdills
    jrdills Well-Known Member
    Im on 1.05 87 base and was curious if the 91 base is any better. Anyone on 91 base have any input? Just filled with 87 or else i would test it out myself
  13. Mar 9, 2019 at 3:55 PM
    Iceman_JD
    Iceman_JD RIP Nicky
    Phoenix Az.
    I hear ya, My ECU is the 04B03.
  14. Mar 9, 2019 at 4:13 PM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    I'm on 91 base and it is smooth . I like it! Have not ran 87 base for any comparison.
  15. Mar 9, 2019 at 4:34 PM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Come on fellas. GL in D w/ ECT on and complaining it won’t downshift. It’s not supposed to...
  16. Mar 9, 2019 at 4:55 PM
    Xenor
    Xenor Member
    3" Spacer Lift, Bestop Supertop
    Been watching this since I got my truck and I’m ready for this truck to be more driveable.
    Just placed my order. When do you think it will ship?
    Tac0Tic0, lapoltba and TRDOBSESSED like this.
  17. Mar 9, 2019 at 4:56 PM
    nxcess
    nxcess Well-Known Member
    '17 Tacoma MT 4x4
    OVTuned
    Soon...
  18. Mar 9, 2019 at 4:59 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    IDK if you are AT or MT, but the answer is 100% yes regardless. You will need to be patient with the ECU learning after flashing, and finding the tune that works for you best. In the end you will have a truck that Toyota should have given you off the lot.
  19. Mar 9, 2019 at 4:59 PM
    Xenor
    Xenor Member
    I am a little confused between how the ECU versions work with the version of the tune after reading this thread. Seems you can run 1.05 on one ECU version, and 1.05 on a newer “TSB” ECU version with different results.
  20. Mar 9, 2019 at 5:03 PM
    Xenor
    Xenor Member
    I have a 2017 TRD OR, AT. It is a dog at lower RPMs. Gear hunts on the highway. Power spike at ~3500rpm. I love this truck but the trans and power delivery is annoying.
Thread Status:
