Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 9, 2019 at 5:06 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I can't really give you much 1st hand info since I have a MT. From what I have seen, AT guys are still much better off with the tune. One thing to keep in mind is that if the "off the shelf" tune isn't working for you, Mat is going to be offering custom tuning.
  2. Mar 9, 2019 at 5:14 PM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    Congrats. I like 87 Performance, saves $ at the pump and power where I live, low to mid range. Like the tip in too. But have fun finding the tune for you.
  3. Mar 9, 2019 at 5:36 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    I will try to make this simple,there are multiple ECU calibrations for the third gens. Mat has made 87,91,93 base/economy and performance tunes available for all versions of the ecu's (some still pending latest 1.05 update release)
    It appears that almost every truck reacts differently to each tune variation and driver perspective/preferences varies considerably.
    I would venture that is what is causing all the confusion,everyone drives and uses their trucks differently as well as mods and environmental aspects. People also have varying expectations of what this tune can or cannot do regarding shifting/performance,some reasonable and others outright unrealistic.
    That said,I would venture 99% positive feedback from those that have tuned their trucks. Just pick a tune from the tune menu that is compatible with your current ECU version and octane/performance level desired and give it a try...
  4. Mar 9, 2019 at 5:42 PM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    I thought it was ETC and S where GL was active. My bad.
    Boost3 likes this.
  5. Mar 9, 2019 at 5:45 PM
    Deucer01
    North Georgia
    It is. But GL tune in D with ECT will upshift but not downshift.
    Boost3 and Chipi3s like this.
  6. Mar 9, 2019 at 5:55 PM
    peppinoss
    peppinoss Well-Known Member
    Los Angeles
    2016 TRD OR 4x4
    ToyTec Boss 2.0 lift TRD Pro Wheels 265/70/R17 KO2s Mobtown Offroad Sliders
    i notice this as well on 87 perf. i have about 250 miles on it. very annoying
  7. Mar 9, 2019 at 6:01 PM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Tried the base 87 and that tune sucks balls and felt flat all around. Went back to 87 p/g but I prefer the torque of the 91 p/g over 87. Not sure how some are enjoying the ride of a base tune???
  8. Mar 9, 2019 at 7:01 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    Damn, I thought y’all changed it to how the 2nd gen shifts.
  9. Mar 9, 2019 at 7:03 PM
    Shellshock
    Iowa
    That’s on the todo list
    Tac0Tic0[QUOTED] likes this.
  10. Mar 9, 2019 at 7:53 PM
    PRO_Taco
    PRO_Taco Well-Known Member
    Ontario Canada
    2025 TRD PRO
    Ceramic coated Underground ARB rear bumper flush mount lights Trailhunter rock sliders
    Well you got me there. I didn’t listen to the whole thing but once I stopped it checked how long it was then replied I was probably about 3 min 5 sec deep.. lol
    Deucer01[QUOTED] likes this.
  11. Mar 9, 2019 at 8:22 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Got your glasses on gramps? Never used ECT except for gear lock. Also mat already mentioned it has to do with Toyotas shift logic. He mentioned he plans to fix later this year. :burp:
  12. Mar 9, 2019 at 8:32 PM
    5500
    5500 Active Member
    Ed
    Cape Cod
    2019 Cement Sport
    Don't know if its a lot but I do know that the difference in my truck between 87 and 89 octane is very noticeable. After a 1/2 tank of 89, drivability is completely different (improved) and mileage has jumped from 17.3 to 20.6 So its just my guess that it was a combination of knock related ignition retarding compounded by the Atkinson cycle that created a loss in power and resulted in the transmission trying to compensate by constantly downshifting.
  13. Mar 9, 2019 at 9:10 PM
    Totall4285
    Totall4285 Well-Known Member
    Palm Harbor, Fl.
    2017 Tacoma TRD Sport
    Little update on my tsb/techstream/overflashng debacle. Been about 200 miles on 04b04 1.05 87 base and my truck is pretty much back. Weird lag/surge shifting is almost completely gone and smooth. It was rough for about 75 miles, mpg at 1 point was 13 mpg. Now back up to 18.8mpg and rising.
    As far as 87 base goes, I love this tune. Fuel efficient, I get almost 0 gear hunting issues (unless I'm soft on the pedal, which has been discussed), and when I hit ECT this thing moves! I definitley find myself driving more aggressive bc I can now.
    Thanks for the tunes @OVTune !
    SurfratTX, Ron1965 and paleh0rse like this.
  14. Mar 9, 2019 at 10:26 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Second that. 87 base is very nice. Smooth shifting, conquers hills without wheezing and goes nose to nose with beemers...
    Perhaps to add a wee of tip..
  15. Mar 9, 2019 at 10:46 PM
    thedriza
    thedriza Well-Known Member
    Portland, OR
    2017 Tacoma DCSB
    5.29 gears, OME HD lift, OVTune
    1.05 91 octane performance with 33 inch tires and my truck weighs 5200 pounds. On the first tank of gas the tip in was head jerking even when trying to feather the throttle. Just started the second tank of gas and either it's settling down or my pedal control is getting better.
  16. Mar 10, 2019 at 1:42 AM
    Totall4285
    Palm Harbor, Fl.
    Just the tip? :rofl:
  17. Mar 10, 2019 at 3:49 AM
    Stoked4
    Stoked4 Well-Known Member
    2017 trd sport DCLB (OVtuned)
    Very hard
    20tacoma17[QUOTED] likes this.
  18. Mar 10, 2019 at 5:10 AM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Wax on wax off you young keyboard warrior.
  19. Mar 10, 2019 at 7:03 AM
    60calHowdaHunter
    60calHowdaHunter Well-Known Member
    Dave
    Arizona
    2016 Tacoma 4x4 offroad
    none
    I third that - everything said above, I am on also 04B04 base 87, am averaging 20mpg (amazing right?). I am happy and done, mothballed my laptop and enjoying my 'new' the ride! All who ponder buying this tune or not, all i can say is that if it weren't for this tune I would have traded in this truck long ago, any tune is 10x better than the stock truck, but 87 base just happens to be my personal preference and consider it, for my driving style, to be spot on.
  20. Mar 10, 2019 at 7:19 AM
    Deucer01
    North Georgia
    Maybe a combination of both?
Thread Status:
