Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 12, 2019 at 4:36 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Dyno Jet result is what we can expect to see with 91, slightly more due to additional ignition advance allowance with 91.
    What we are focused on now is implementing Ignition Octane learning. (don't freak out on the "learning") We've figured out how to use the Knock correction counters to alter Ignition MBT, so people don't have to flash different tunes to get more power.
    04B02 and 04B03 are being worked on. Along with 04B23 (south america).
    We are looking into this. seems to only be a problem on 04B30 and not 04B31. It's not really a "problem" the shift tables just need a *slight* adjustment.
  2. Mar 12, 2019 at 4:40 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    So is there any real power gains from 91 over the 87? Should I justify the extra couple dollars on gas?
  3. Mar 12, 2019 at 4:49 PM
    OVTune
    OVTune
    yes there are real gains over 87. Especially on older ECUs (pre-TSBs), however the gap in total gains are smaller on post-TSB. (that does NOT make pre-TSB better).
    The dyno-jet results are with our hybrid octane ignition setup, but with STOCK MBT allowance (which means 87 safe). The truck tested with 93 octane, so you can consider those results similar to what we should see with 91/93 octane. More ignition ( a few degrees ) was definitely possible but not the point. We wanted realistic results so the truck was ran almost 15 times hot. Previous truck test with true-87 you see the gains are considerably less everywhere (results on first page).
    If the TSB didn't make a 6whp difference by itself then 23whp @ 6000 would be right in line with the pre-tsb premium octane results.
    So everyone is clear > the dyno jet result tune is being developed to be 87 octane safe, but to make best result still requires 91/93 fuel. You'll still make a majority of the low end gains through throttle code, but not top end.
    Totally understand if that is confusing. We are just waiting for the test truck to get us the rest of the pics / videos and all that for us to give a in depth explanation of what we did.
    jholc21, jekerskel, paleh0rse and 9 others like this.
  4. Mar 12, 2019 at 5:15 PM
    Anchovy
    TRD Ferguson
    Still confused, I’ll just wait for the dyno sheets
  5. Mar 12, 2019 at 6:35 PM
    CementTaco2019
    CementTaco2019 Well-Known Member
    2019 TACO
    K&N Intake
    Hope to have some answers soon. Mat sounds promising. I do wonder what is so different with our ECU from the rest.
    paleh0rse[QUOTED] likes this.
  6. Mar 12, 2019 at 7:33 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Pretty cool stuff there! No more worrying about being on a 91 tune and only finding 87.
    jholc21, Neutron, wahoobie and 3 others like this.
  7. Mar 12, 2019 at 8:08 PM
    Trdsport19
    Trdsport19 Active Member
    dan
    2019 magnetic grey metallic trd sport DCSB
    Is there any way to find your ecu id without a Tactrix cable?
    Thanks
    Dan
  8. Mar 12, 2019 at 8:32 PM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    Good to hear. Looking forward to those adjustments. As always, thank you Mat!
  9. Mar 12, 2019 at 8:37 PM
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    Some OBD2 scanners will show you the calibration id.
  10. Mar 12, 2019 at 8:37 PM
    paleh0rse
    Raleigh, NC
    I'd personally like to know whether or not there's a TSB available that would update our ECUs from 04B30 to 04B31.
  11. Mar 12, 2019 at 8:39 PM
    CementTaco2019
    2019 TACO
    K&N Intake
    I never thought of that.
  12. Mar 12, 2019 at 10:26 PM
    HardTaco712
    HardTaco712 I like to Party
    Greg
    2018 Tacoma TRD Sport AT Cement
    Stock 04A61 here having same issue. Email sent.
  13. Mar 13, 2019 at 7:41 AM
    ihatemytruck
    Dave
    Southern California
    OBD2 scanner......what city are you in, maybe someone nearby can read it for you.
  14. Mar 13, 2019 at 8:20 AM
    JPatzig
    JPatzig Active Member
    This is awesome, thanks Mat.
    @Chipi3s @maybeme I outlined in detail my take on highway dead pedal in post #43034. https://www.tacomaworld.com/threads...-alpha-release.495735/page-2152#post-20036989
    I feel like it's closer to 60% than 85%, but regardless it does "feel" like you have to press the pedal way too far.
  15. Mar 13, 2019 at 8:25 AM
    Frito
    Frito Well-Known Member
    And ^^ This ^^ is how the rumors begin ! :rofl:
    kevron, taco 16, Chipi3s and 7 others like this.
  16. Mar 13, 2019 at 9:00 AM
    jekerskel
    jekerskel Well-Known Member
    Zach
    Bellingham WA
    2004 SR5 Extended cab 2wd 5 speed
    V-LED low and high beam headlights.
    I will personally attest to the fact that the tsb does change a lot. 1.05b is different on post tsb then pre. Better I would say with better mpg so far. If anyone is on the fence update ur truck to 04! It’s fairly easy and makes life so much easier with Mat’s tunes.
    hr206 and Shellshock like this.
  17. Mar 13, 2019 at 9:14 AM
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    I don't know if its fuel switching from winter to summer fuel, or 1.05 base 91 finally "settling in". My MPG went from about 18 consistently to 20. I have close to thousand miles on 1.05 base, I would think that is far past "settling in".
    Only change besides possibly summer blend fuel, I changed my oil recently.
    Anyone else using Quik Trip fuel recently see a jump in MPG?
  18. Mar 13, 2019 at 9:34 AM
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    Where would have switched back to summer fuel already?
  19. Mar 13, 2019 at 9:40 AM
    2017TRDpro
    2017 TRD Pro
    I'm not sure, hence my question with regards to my sudden MPG bump. Surely oil change wouldn't improve my MPG by 2 :confused:
  20. Mar 13, 2019 at 9:43 AM
    GF8er
    MT. Hood
    Has the outside temperature in your area warmed up?
Thread Status:
