Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 16, 2019 at 11:50 AM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Nothing to add.
  2. Mar 16, 2019 at 11:57 AM
    Ron1965
    Ron1965 Go Bruins.......
    Ron
    Socal
    2018 Cement TRD ORSB PREMIUM/TECH
    OVtune Mooseditty Custom;DD Exhaust;Nitro 5.29’s;SCS Brushed Copper;AFe Custom CAI
    Mine won’t auto upshift in gearlock.
    Taco16LB likes this.
  3. Mar 16, 2019 at 12:00 PM
    Shellshock
    Iowa
    Correct
    Taco16LB[QUOTED] likes this.
  4. Mar 16, 2019 at 12:10 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    The truck will not shift up by itself and will only downshift around 1200 to avoid stalling
  5. Mar 16, 2019 at 12:11 PM
    GPH36
    GPH36 Well-Known Member
    2019 Black TRD Pro
    Thanks for the updates. I emailed yesterday asking for a status update, and got a response within minutes. You’re doing great work!! Glad to hear it’s all being worked out. Keep up the outstanding work!
  6. Mar 16, 2019 at 12:13 PM
    Taco16LB
    Taco16LB Well-Known Member
    That is what I thought . @wiljayhi must be using the plain S mode . Maybe forgetting to press the ETC button to activate gearlock ?
  7. Mar 16, 2019 at 12:29 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    I posted right after I read his post, but was a few pages behind, sorry for offending you. And I don't usually preach read the thread... Usually just answer a question.
    go2cnavy[QUOTED] likes this.
  8. Mar 16, 2019 at 12:31 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    This has been my experience with 87/GL:
    The trans won’t upshift if you leave it gear 1 but if you select any gear above that it will auto upshift to that gear with shifting happening around 2200 (normal acceleration). Once it attains the gear you’ve selected it is locked there unless you up or downshift manually or come to a stop.
    If you don’t downshift manually to the proper gear, it will auto downshift from whatever gear it’s in to gear 1 when revs get below 1100 or so.
    Another nice feature is you can turn gear lock off at any time by cancelling ECT. Your S mode reverts to auto up/down.
    You may be right about the upshifting from any gear when hitting the red line. I would guess that’s it’s a result of WOT on takeoff but I’ve had no direct experience of redlining since I’ve had no need to go there. (Never tried it)
    I’ve been playing around with gearlock for two weeks now and keep discovering different ways to use it effectively. Early on I emailed Mat when I discovered unexpectedly that it would auto upshift through gears. Normal behaviour said he. Happy was I.
  9. Mar 16, 2019 at 12:50 PM
    wiljayhi
    Jim
    3G, Tuned
    I thought the same as @Anchovy before stumbling on the auto upshift one day when I forgot to downshift ftom 4th gear and came to a stop. Absent mindedly just stepped on the gas (normal acceleration) and it upshifted (2200 or so) through the gears back to 4th. I confirmed with Mat that this is normal operation. It suits me because I like not having to upshift it if I choose. Either auto or manual upshift is possible with the gear lock option.
    (I had ECT on, I didn’t forget, honest :))
  10. Mar 16, 2019 at 1:01 PM
    navin r
    navin r Well-Known Member
    2017 double cab short bed trd off road 4wd w/ premium pkg.
    Not sure what I'm doing wrong. Tried p5 flash utility, got to screen with "interface" and "system Id" in the screen, but identify and all the rest of the buttons are grayed out.
    When I try pcm flash utility, says guardant dongle not found...
    I have both ovt plug and usb cable and tactrix plug and cable, can't get either to do anything
  11. Mar 16, 2019 at 1:20 PM
    wiljayhi
    Jim
    3G, Tuned
    The difference is that you can lock the trans in any gear you choose. If for example you are at speed in 4th gear (gear lock) and you press down on the gas the trans will not down shift. Your rpms may increase and you will speed up but you will remain in 4th gear.
  12. Mar 16, 2019 at 1:30 PM
    wiljayhi
    Jim
    3G, Tuned
    Under normal acceleration it should auto upshift if you have selected any gear above 1st. To verify this, from a stop, move the selector over from D to S, it will select 4th gear by default (don’t change it). Turn on ECT, Bob’s your uncle. Auto upshift, manual downshift.
  13. Mar 16, 2019 at 1:42 PM
    wiljayhi
    Jim
    3G, Tuned
    Yes, correct. Once it attains the chosen gear 3,4,5,6, it is locked in that gear unless you manually change it up or down or come to a stop (auto down from chosen gear to gear 1 without going through gears in between).
  14. Mar 16, 2019 at 2:03 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Video instructions for dongle-less software will be available :
    - OP
    - Each product page
    - instructions page on our site
  15. Mar 16, 2019 at 2:09 PM
    Ron1965
    Ron
    Socal
    I don’t want auto upshifts. When I shift to S I manually downshift to 2 or 1 and then turn on ECT. From there all upshifts and downshifts are manual unless on downshifts I let rpms fall too low. I’ve been to 65 in 2nd and there was no auto upshift. I drive in this mode a lot and have never had an auto upshift.However if you leave it in S4 I can see where it would upshift from 1 to 4,but I would rather shift myself to wind the gears out a little more.
  16. Mar 16, 2019 at 2:12 PM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    Maybe we can catch Mat on his coffee break. :fingerscrossed:
    @OVTune , Would it be possible to customize the gearlock tune to activate gearlock by just simply shifting to S mode, without having to push the ECT button and leave ECT functional in D?
    SK808 likes this.
  17. Mar 16, 2019 at 2:28 PM
    wiljayhi
    Jim
    3G, Tuned
    I’m not advocating for auto upshifts with gear lock, it’s just what I prefer (manual downshifting is a given). Most folks likely want to do their own upshifting, only saying that auto upshifting is one possible outcome if your top gear selection is 2 to 6.
  18. Mar 16, 2019 at 2:31 PM
    Reypac24
    Reypac24 NRA Member
    Mr., but friends call me Sir.
    Republic of Texas
    2017 DCSB Limited 4x4 (SOLD)
    04B04. OV Tune # 1857 dongle 1.04r 91 octane. Nitto Ridge Grapplers 265/60/18. SaBellCo Tailgate Lock. Meso Customs TRD coin holder, gasshole. Tacomods black anodized aluminum radio knobs. Lock'er Down Console Safe. Sig Sauer P238 Desert. Escort Passport 9500i Radar/Laser Detector.
  19. Mar 16, 2019 at 2:37 PM
    wiljayhi
    Jim
    3G, Tuned
    An old figure of speech, means loosely ‘you got it made’ or ‘you’re all set’.
    Don’t ask me why.
    Reypac24[QUOTED] likes this.
  20. Mar 16, 2019 at 3:06 PM
    ihatemytruck
    Dave
    Southern California
    I love using that quote with a friend of mine......he literally has an uncle Bob. :rofl:
    frito-frio, mZiggy and Reypac24 like this.
Thread Status:
