Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 18, 2019 at 4:19 PM
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    Quick question: is gear lock base or performance?
  2. Mar 18, 2019 at 4:27 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Performance.
    GPatriot[QUOTED] likes this.
  3. Mar 18, 2019 at 5:05 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    From the SM:
    MONITOR DESCRIPTION
    Under closed-loop fuel control, fuel injection volumes that deviate from those estimated by the ECM cause
    changes in the long-term fuel trim compensation value. The long-term fuel trim is adjusted when there are
    persistent deviations in the short-term fuel trim values. Deviations from the fuel injection volumes estimated by
    the ECM also affect the average fuel trim learned value, which is a combination of the average short-term fuel
    trim (fuel feedback compensation value) and the average long-term fuel trim (learned value of the air fuel ratio).
    If the average fuel trim learned value exceeds the malfunction thresholds, the ECM interprets this as a fault in the
    fuel system and stores a DTC.
    Example:
    The average fuel trim learning value is +35% or higher, or -35% or less, the ECM interprets this as a fuel system
    malfunction.
    MONITOR STRATEGY
    Related DTCs
    P0171: Fuel trim Lean (bank 1)
    P0172: Fuel trim Rich (bank 1)
    P0174: Fuel trim Lean (bank 2)
    P0175: Fuel trim Rich (bank 2)
    Required Sensors/Components (Main) Fuel system
    Required Sensors/Components (Related)
    Air fuel
    Inferno__Taco likes this.
  4. Mar 18, 2019 at 5:12 PM
    JabambyBrew
    JabambyBrew Well-Known Member
    JB
    Denver NC
    2019 Toyota Tacoma TRD PRO
    @OVTune, I been waiting to register the new flash manager on my new tablet for about two weeks now. I sent my information with my system ID to the Zendesk address about 3 times. I know you are busy but is there any way you can check my status. I just want to register the software so I can use the new FM. Thanks for you time.
  5. Mar 18, 2019 at 5:30 PM
    ohioboater
    ohioboater Well-Known Member
    2017 DCLB 4x4 Sport
    Having dead space at the top of the curve makes sense - if you're getting to 100% twice as fast, then the second half of the pedal throw won't do anything. But dead space at the bottom seems weird. Shouldn't the request curve start from zero and simply have a steeper slope, instead of skipping the first degree or two of pedal movement and then catching up? Or is my foot just getting fooled by how steep the rise is in those first few degrees, and it really is starting from zero?
    BTW, I'm pretty sure I rode a bike once with a quick twist throttle, but it was a long time ago, and I don't remember if it had any weird slack or lag in it. I just remember it taking a very light touch if I didn't want to wind up looking at the sky unexpectedly. :)
    taco 16 and treimche[QUOTED] like this.
  6. Mar 18, 2019 at 5:55 PM
    IBNetMan
    IBNetMan Member
    New to the Forum. Had my first Tacoma for around 6 months, Love it! Trying to get cought up on this MASSIVE thread. Have read 150-250 of the last pages. Question, has anyone used a laptop to OV Tune their Tacoma and the laptop becomes unusable. Does it cost more money to move to a new laptop with OVTune?
  7. Mar 18, 2019 at 6:07 PM
    TheTacoChrist
    TheTacoChrist Well-Known Member
    Dick
    2018 TRD PRO Taco
    Lettuce removed Ghost pepper sauce added Subbed: Tortured baby cow for tofu.
    Got the new tune up and running.
    Helllloooooo tip-in.
    It’s a different vehicle.
    Thanks, Matt @OVTune
    TRDOBSESSED and tacopromatt like this.
  8. Mar 18, 2019 at 6:15 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    I haven't heard of anyone "crashing" their laptop from tuning. It doesn't cost anything to switch to a new laptop if the need arises just don't be doing it all the time. Mat said switching laptops a couple times is reasonable but any more than that.....
  9. Mar 18, 2019 at 6:15 PM
    Shellshock
    Iowa
    You just email Mat and register the new laptop. No big deal as long as you aren’t switching hardware excessively
    LVLAaron and IBNetMan[QUOTED] like this.
  10. Mar 18, 2019 at 6:39 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    @OVTune Just flashed to 04B04 from 04B03 ( thanks to @KanPanic ) and new FM version of 1.05 87 Base last week. Just got back from a 700 mile high altitude trip - Denver to Durango and back (6000 ft base over 11,000 + ft max to 6500 destination). Took different routes down and back. Averaged 23 mpg down using S mode. Lots of high elevation passes along US 285. Drove great. Locked it down to 5th except in long flat sections (still 6500 + elevation). Drove D mode back except Wolf Creek Pass where I used S mode - Drove great. Pulled Eisenhower Pass (6% grade) easy - 5th gear at 65 mph and 3500 rpm with no issues - total control and power. Averaged 24 mpg. No way this truck would preform like this without your efforts. Thanks! Looking forward to future revisions and improvements!
    hbaade, taco 16, ToyoDrew and 7 others like this.
  11. Mar 18, 2019 at 7:45 PM
    IBNetMan
    IBNetMan Member
    Thanks for the reply. Glad to know. I saw someone asked and was confirmed the "ASUS VivoBook E203MA" works. Does anyone have any other confirmed new laptops (small/affordable) that would be durable and have better specs? Also I saw in the pages on this thread Mat is working on getting a hand held ( I know, ready when he knows). Does anyone know if the hand held could be purchased separate /stand alone?
    Thank you all and thank you for future help!
  12. Mar 18, 2019 at 7:48 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    You can buy the handheld as an add on to an existing kit.
  13. Mar 18, 2019 at 7:48 PM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    I was waiting on handhelds, but couldn’t pass up this deal! Thanks Tim for a great deal. I already downloaded FM and tunes on my laptop and got everything ready to go. (Was very easy, new instructions are simple)
    @OVTune, I sent a request to you via zendesk email to pay for my registration. Can’t wait!
    SC4333 likes this.
  14. Mar 18, 2019 at 8:06 PM
    SpeySquatch
    2016 TRD OR DCSB
    Stock tires and setup? All you guys getting 20+mpg are making me jelly
  15. Mar 18, 2019 at 8:17 PM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    I hear you! I have 33” E rated tires and 3” lift (2016 TRD Sport Auto) and I’m happy to get 16mpg. I’m usually in the 14-15mpg range per tank. I’m hoping the tune will atleast get me a tad better. We shall see. On 04B04 until I get my registration key.
    What kind of mileage are you getting?
    taco abbo likes this.
  16. Mar 18, 2019 at 8:20 PM
    SpeySquatch
    2016 TRD OR DCSB
    I’m running just standard ply (4 I think) 265/70/17 Falken AT3’s and get about 18-19 on the freeway (16-17 around town) if a drive like an adult. I do have sliders, bumper, winch, full 2.5 suspension with aftermarket leafs and a softopper with some gear though. Sure miss the good old days driving through Wyoming getting 20-25mpg on stock setup...damn mod disease caught up to me, but I’m cured now :D
    PapaRee[QUOTED] likes this.
  17. Mar 18, 2019 at 8:21 PM
    Shellshock
    Iowa
    Driving like an adult isn’t allowed in this thread
    SpeySquatch[QUOTED] likes this.
  18. Mar 18, 2019 at 8:53 PM
    SpeySquatch
    2016 TRD OR DCSB
    I switched to the 87 base tune just for that
  19. Mar 18, 2019 at 10:34 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Are you using spacers? I like the stance
  20. Mar 18, 2019 at 10:46 PM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Thanks. No spacers. I have the GTS Dobinson’s suspension. I bought it from @eevaldes (Eric) at Mainline Overland. I got the Medium load springs for 2.75” in front. And extended shocks in rear with tapered blocks. $740 shipped in 4 days.
    A0E7AFF2-7B4A-4231-8E57-CCDF1F09F66E.jpg 20B1FCF5-F21E-4605-A587-6CCED5AFE775.jpg 5428C35E-9821-4EE6-B2F6-5B23108B289A.jpg
Thread Status:
