Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 21, 2019 at 9:17 PM
    Shellshock
    Iowa
    Assuming it’s disconnected you should be fine
  2. Mar 21, 2019 at 9:17 PM
    Shellshock
    Iowa
    Read and identify are 2 different things you can identify. Not read.
  3. Mar 21, 2019 at 9:18 PM
    Totall4285
    Totall4285 Well-Known Member
    Palm Harbor, Fl.
    2017 Tacoma TRD Sport
    Guess I don't know if all the wiring in the dash does something
  4. Mar 21, 2019 at 9:18 PM
    Totall4285
    Palm Harbor, Fl.
    Ok I'll try that. Definitley chose read
  5. Mar 21, 2019 at 9:18 PM
    Shellshock
    Iowa
  6. Mar 21, 2019 at 9:19 PM
    Totall4285
    Palm Harbor, Fl.
    Hopefully not radio then. Not sure why I'm getting unsuccessful
  7. Mar 21, 2019 at 9:29 PM
    Shellshock
    Iowa
    Try this. If that doesn’t work, you can disconnect the battery for 10 minutes then try again. If it still doesn’t work, probably best to email mat
  8. Mar 21, 2019 at 9:33 PM
    Totall4285
    Palm Harbor, Fl.
    Thanks, radio it is. Just started convos with @L-SCHLEGS
  9. Mar 21, 2019 at 9:34 PM
    Totall4285
    Palm Harbor, Fl.
    What did you even type in to search that?
  10. Mar 21, 2019 at 9:37 PM
    Shellshock
    Iowa
    Maestro
    :notsure:
    Totall4285[QUOTED] likes this.
  11. Mar 21, 2019 at 10:28 PM
    Totall4285
    Palm Harbor, Fl.
    Thank TW as always. Had to disable maestro
    SpeySquatch likes this.
  12. Mar 21, 2019 at 10:56 PM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Why aren't you just flashing?
  13. Mar 22, 2019 at 3:30 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    No
    fullsend604[QUOTED] likes this.
  14. Mar 22, 2019 at 5:05 AM
    mauidogg
    mauidogg Well-Known Member
    16 DCSB TRDOR
    Performance options. OVTune, maybe add on the dirty deeds exhaust. Then wait for OVTune turbo setup. That’s about all the real power you are gonna add.
    4x4Lunchbox[QUOTED] likes this.
  15. Mar 22, 2019 at 7:06 AM
    beef ranger
    beef ranger Well-Known Member
    19 OR 4WD 6MT DCSB CEMENT
    I'm a little confused with the instructions...
    There seems to be two different sets of instructions:
    1) Email System ID to Zendesk to get registry file & install
    2) Use Flash Manager to download the correct tune file
    3) Flash tune file
    OR
    2) Use P5Flash to get "Output Info" from ECU - Calibration, Calibration File, and Part #
    3) Email Output Info to Zendesk to get tune tile
    4) Flash tune file
    What's the preferred method? I'd rather not wait for the tune file to be sent if I can just download. Can anyone set me straight?
  16. Mar 22, 2019 at 7:25 AM
    Shellshock
    Iowa
    Email system ID
    get registry file
    Download tune
    Flash tune
    tonered likes this.
  17. Mar 22, 2019 at 8:09 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    FAQ, faq, FAQ!!!!! :D
  18. Mar 22, 2019 at 8:12 AM
    Shellshock
    Iowa
    RTFM!
    nxcess and tonered[QUOTED] like this.
  19. Mar 22, 2019 at 9:37 AM
    Brucey
    Brucey Well-Known Member
    Bruce
    2018 DC LB SPORT 4X4
    Ovtuned
    1. Download program and install
    2. Connect the cable and get system id, email to get reg key.
    3. Install reg key
    4. Flash
    The exact procedure can be found on the ovtune web page.
  20. Mar 22, 2019 at 10:21 AM
    Hichung
    Hichung Well-Known Member
    Arkansas
    '18 TRD OR DCSB Tech+Prem 4x4
    I get where he’s coming from. The documentation from within flash manager is/was different than what’s on the OVTuned website. It confused me for a bit as well until I realized the website had the most recent version.
    johntoyota and rdpoe like this.
Thread Status:
