Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 28, 2019 at 11:14 AM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Me, Im in socal!
    My truck is at your disposal. @OVTune
    Jumper15 likes this.
  2. Mar 28, 2019 at 11:38 AM
    txags92
    txags92 Well-Known Member
    2016 DCLB TRD OR 4x4 BBP
    So I may have missed it, but I finally got around to downloading and installing the flash manager software and ran into an interesting little glitch. I figured mentioning it here might help somebody else if they run into the same problem. It may have already been discussed, but I confess that I have not ready every one of the 2233 pages in the thread.
    When it is on my desk, my laptop is plugged into a port replicator and connected to two monitors and an external keyboard. The laptop is closed once I power it on. So when I finished downloading the flash manager application software from OVTUNE, I clicked "run" and the program initiation window popped up...with no buttons in it. It had the normal text in the window, but none of the buttons for "next" or "quit". I closed the window and tried again...same thing. So I rebooted my laptop and tried again. But this time, I had the laptop open and it worked fine. I had forgotten to disable my antivirus, so it wouldn't let me install. After I disabled the antivirus and tried again, it didn't show me the buttons again. I realized it was because I had the laptop closed again and was working through the port replicator and external monitors. When I opened the laptop back up again, it worked perfectly.
    Apparently, for some reason it will only display the buttons on the install window if you are viewing them on the laptop screen, not on external monitors. Anyway, not sure if that has ever happened to anybody else, but hopefully it will help if somebody has that problem in the future.
  3. Mar 28, 2019 at 1:09 PM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    It could be related to your DPI settings. I have seen some apps behave that way as folks are going to higher quality screens. You can mess with the compatibility settings of the app on the shortcut used to start it but I do not believe this is an app bug - more a Windows and DPI setting issue. YMMV
  4. Mar 28, 2019 at 1:17 PM
    txags92
    Yeah, I didn't mean to imply it was the app itself...just to let people know how to deal with it if they had the same issue. I am pretty sure it is probably something in my settings and how my laptop is interfacing with the monitors through the port replicator.
  5. Mar 28, 2019 at 1:18 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Sounds like you are working on the "octane adaptive" tune to eventually run E85 with boost....
    lapoltba likes this.
  6. Mar 28, 2019 at 2:07 PM
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    Still confused....
    I’m still on B03. Does @OVTune reccomend going to B04 as a “better” platform for the 1.05 tunes overall...?
    I’m still on 1.03 and I don’t mind waiting for those tunes, performance/GL. But if the B04 is just a plain better platform for the new tunes then I would try to update the ECU.
    Wish he would clarify this for me.
  7. Mar 28, 2019 at 2:15 PM
    ManInTheMaze
    ManInTheMaze Well-Known Member
    Mendo
    2003 and 2017
    I am interested! Sent you a PM. May be late to the party.
    Jmfw805, nxcess, crigg93 and 4 others like this.
  8. Mar 28, 2019 at 2:28 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You are the Man! Hopefully it works out to get you on the dyno!
    Thanks!
    :cheers:
    ManInTheMaze[QUOTED] and crigg93 like this.
  9. Mar 28, 2019 at 3:22 PM
    Grangis904
    Grangis904 Well-Known Member
    Jacksonville, FL
    2018 White TRD Pro
    Any idea what this tune will be titled as? I’ve had this issue from day one of ownership, the dealer insists that it’s my duratracs that are causing the problem.
  10. Mar 28, 2019 at 3:45 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    I’ve seen the problem from the test drive. It’s a very mild shudder but thought it was just the road surface. (Where I live that’s a real possibility). When I took it in for the TSB, dealer said it was normal so I never thought any more about it.
    Good to hear that it will be resolved.
  11. Mar 28, 2019 at 3:53 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    So, not to be a fly in the soup...
    What causes stuttering in some M/T trucks?
    I may know someone who has had this since brand spanking new.
    mkivr32, nxcess and tonered like this.
  12. Mar 28, 2019 at 4:18 PM
    Jumper15
    Jumper15 Well-Known Member
    Michael
    Hanover pa
    2017 Toyota Tacoma trd off-road
    King lift, 285 ko2s, 1.25 wheel spacers
    Anybody know if I buy somebody’s install kit, I’ll I have to do is buy the rights correct? As well here is a picture can sombody tell me if everything is there. Or is it just worth buying right now New at a discount
  13. Mar 28, 2019 at 4:22 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Correct. Buy the hardware and then send a ticket to OVTune and request to purchase a license. As far as if it's worth it, it all depends what you're paying. I don't remember off the top of my head what he charges for licensing on used hardware.
  14. Mar 28, 2019 at 4:23 PM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    $325 for registration
    Inferno__Taco, Jumper15 and SC4333 like this.
  15. Mar 28, 2019 at 4:23 PM
    Jumper15
    Michael
    Hanover pa
    I’m only paying $200 for the kit
  16. Mar 28, 2019 at 4:25 PM
    wiljayhi
    Jim
    3G, Tuned
    Hardware's all there.
    Jumper15[QUOTED] likes this.
  17. Mar 28, 2019 at 4:26 PM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Good deal! $525 total, and free upgrades.
    wahoobie and Jumper15[QUOTED] like this.
  18. Mar 28, 2019 at 4:31 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I'm pretty sure Mat had confirmed it was the VVTi going nuts, at least on earlier versions of the tune. I wouldn't doubt it's the same thing stock.
    MOC221_[QUOTED] likes this.
  19. Mar 28, 2019 at 4:34 PM
    MOC221_
    Frank
    Same valvetrain on a A/T truck... possibly causing the same symptoms.
  20. Mar 28, 2019 at 4:37 PM
    lapoltba
    CT - 06076
    I think there are two separate problems, with similar symptoms. (They likely feel very similar when driving). Mat also confirmed the TC unlocking and locking very quickly was a problem with some AT trucks.
Thread Status:
