Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 3, 2019 at 5:13 AM
    RocRan26
    RocRan26 Well-Known Member
    Randy
    Rochester NY
    2017 Black Tacoma Limited DCSB AT
    Nope. That’s it!
    Jumper15[QUOTED] likes this.
  2. Apr 3, 2019 at 7:34 AM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    You're good to go!
  3. Apr 3, 2019 at 8:00 AM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
  4. Apr 3, 2019 at 8:24 AM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    So shutter fix?
    DiabloTRD likes this.
  5. Apr 3, 2019 at 8:39 AM
    DrRoboto
    DrRoboto Well-Known Member
    David
    Salt Lake City, UT
    <s>2017 AC Off-Road</s>
    GoFastCamper. OME 886. Medium Dakars. SSO slimline bumper + Warn VR10-S. OGE dual battery system. Mobtown skids.
    I've worked through multiple hiccups/quirks to try to get the software up and running. My processor is 64-bit but only the x86 version download would install successfully for me. And it installed only after I added a missing DLL, VCRUNTIME140.dll. Then my buttons in P5Flash remained greyed out, after I got my registration key and confirmed in Registry Editor that the changes were made. And my Tactrix cable only connects fully when I do Run as Administrator with the flash manager.
    Perhaps the Bootcamp quirks I am seeing are outliers. But based on my experience so far, I would start over and buy a cheap Windows dedicated laptop:
  6. Apr 3, 2019 at 8:51 AM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Sanity Check please.
    Used standard cruise control today on my routine commute - 8 miles / city streets / under 50mph. It’s the first time I have used cc when not on the highway.
    It seems that the cc logic had much better control over the powertrain than I can accomplish using my right foot. Shifts and tc lock/unlock seemed much smoother.
    I’m guessing that the cc logic and tps are somewhat independent of each other.
    I tried to replicate the same behavior with my right foot only, but was unsuccessful.
    @OVTune can you explain?
  7. Apr 3, 2019 at 8:53 AM
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    Wow, I just went from 1.05 91 base to 1.05 91 performance and what a difference it made! The throttle is a bit touchy and it upshifts a tad too soon but man-oh-man for highway driving this is the best. There truly is no need for ECT now which I have used since day one of buying my truck. I'm keeping this tune for sure. Good work Mat!
  8. Apr 3, 2019 at 8:59 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I had a problem when going down hills that needed a bit of throttle to maintain speed. CC would buck and jerk the whole way done. It was always smooth on level pavement or going up hills. I had this with both the stock and TSB tunes. With 1.05 FOB 87 and 91 (MT), it will get what you could call a slight surge as I crest a hill, then is it smooth the whole way down. I almost shed a tear when I discovered this. In the past, I would shut off CC when going down hills.
    I did ask @OVTune about this, but no comment back.
    It could be the expanded map tables in 1.05 or just a generally happier motor?
  9. Apr 3, 2019 at 9:20 AM
    Brucey
    Brucey Well-Known Member
    Bruce
    2018 DC LB SPORT 4X4
    Ovtuned
    Full kit unless you have a cable.
  10. Apr 3, 2019 at 9:43 AM
    go2cnavy
    My complaint is not about cruise control, but rather the poor throttle control with the gas pedal that has always been present from the day I bought the truck. Cruise control works great in my truck on 91 Base with 33’s and armor.
  11. Apr 3, 2019 at 9:45 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The TSB tune pretty much fixed any throttle control issues that I had. Regardless, CC wasn't good until OVT. It would be hard to go back to stock.
  12. Apr 3, 2019 at 9:54 AM
    ChickoSM1808
    ChickoSM1808 Well-Known Member
    Michael
    2018 dcsb TRD Sport (OVTuned)
    OVTuned, TRD Pro grille, 32's and many more
    Well called the dealer today for routine 15,000 mile service and inspection. They are completely booked for the next 3 weeks. She said there doing a lot of recall work.:censored:.
  13. Apr 3, 2019 at 10:16 AM
    prodemann
    prodemann Well-Known Member
    Phil
    Carver, MN
    2017 TRD Off Road AT DCSB Silver Sky
    TRD Pro grill, OVTune
    You might say he's..... jammin'
    I'll show myself out.
    Shellshock and Bertw192[QUOTED] like this.
  14. Apr 3, 2019 at 10:57 AM
    go2cnavy
    Agree. Maybe post was confusing.
    Mat stated earlier that throttle position alone doesn’t determine the amount of throttle applied by the ECU. My point was that if the ECU can apply throttle and transmission control smoothly with CC, there should be a way that the pedal can do the same. Just my amateur opinion. Nothing more.
  15. Apr 3, 2019 at 11:10 AM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    ya, none of those are bootcamp issues, numerous people have had the same issues including myself with a regular laptop, it's just part of getting a program to run on a computer
    Mike O and Shellshock like this.
  16. Apr 3, 2019 at 11:32 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    Works flawlessly for me on my Bootcamp'd Macbook Air. What issue are you running into?
  17. Apr 3, 2019 at 11:34 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Maybe a little confusing, but I was looking for an opening to post my CC experience.
    In the past, I hated any car / truck with an electronic throttle body. I was in a continuous fight with the odd rubber band feeling. Weirdly, every DI motor that I drove always felt almost like a good old cable throttle EFI, except for the Taco. Mine had a bunch of little issues with a lot of inconsistency. The TSB fixed most of it, but OVT really makes it feel normal.
    PhogDog and go2cnavy[QUOTED] like this.
  18. Apr 3, 2019 at 2:30 PM
    runmc
    runmc Well-Known Member
    Ron
    DFW Texas
    2021 Army Green Tacoma TRD OR DCSB
    One Mod after another
    Picked my 2018 Tacoma up today from dealer. I had TPMS valves put in. I asked for ECU update if possible. Freeman Toyota Ft. Worth said I had the latest ECU - 04A61
  19. Apr 3, 2019 at 2:55 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    go2cnavy[QUOTED], Chipi3s and Saeros like this.
  20. Apr 3, 2019 at 2:56 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I'll raise you..
    iexc, Shellshock and wahoobie like this.
Thread Status:
