Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 5, 2019 at 5:57 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Considering that initially I imagined 1.05 being the final version, only to put more into this for 2019 (in terms of custom code and rewriting logic) we're now doing more than we've ever promised and more work in this than ever before.
    But it takes time. Months.. to do some of this stuff.
    That stutter issue is the perfect example. We've solved it. But you think solving it was quick or easy? LOL no. Want to see the code that controls All of the damn shifting and Torque converter controls?
    It's not just finding "the torque converter controls"... because there are dozens.
    it's finding the torque converter controls > Which one > under what conditions > when is this map called
    xxTacocaTxx, Fiatdave, perkj and 34 others like this.
  2. Apr 5, 2019 at 6:01 AM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Mat you dont have to explain yourself. Wannabe tuners are everywhere but have not even contributed anything useful unlike what you've accomplished for our 3rd gens. Ignore the dingdongs and continue to do good things.
  3. Apr 5, 2019 at 6:07 AM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    Why do the trolls always come out on Friday mornings?
  4. Apr 5, 2019 at 6:08 AM
    Shellshock
    Iowa
    Most of the people complaining don’t understand programming and definitely don’t even know what assembly is.
    Sorting through someone else’s code is a nightmare to say the least and then use a low level programming language on top of that
  5. Apr 5, 2019 at 6:18 AM
    Texaslaw
    Texaslaw Well-Known Member
    2018 Quicksand TRD OffRoad (OVTuned)
    Mat said "Improve driveability." Mission accomplished plus a whole lot more.
  6. Apr 5, 2019 at 6:21 AM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    Cruise Control has been "un-fucked" since the initial release of 1.05.
    Fiatdave, rdpoe and ihatemytruck like this.
  7. Apr 5, 2019 at 6:23 AM
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    What’s the chances of being able to disable the “ecu learning period?” There would almost be no point in waiting for the handheld version, if that can’t be disable. The main point of the handheld is to change tunes on the fly, but if the ecu is constantly having to learn after each tune then that would make it kind of useless. Unless, you’re just going from gear lock to performance. So might as well just stick to the computer version.
  8. Apr 5, 2019 at 6:24 AM
    OVTune
    OVTune
    Adaptive cruise still needs work. (which will be worked on when we get a 2020 Development truck)
  9. Apr 5, 2019 at 6:26 AM
    dpippel
    Phoenix, AZ
    Right Mat, I was referring to normal mode CC, which actually works like it should (finally!) in 1.05. Didn't know you were actually working to improve Adaptive as well. Good news! :)
  10. Apr 5, 2019 at 6:26 AM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    But he wants his oompa loompa now!
    Inferno! and Shellshock[QUOTED] like this.
  11. Apr 5, 2019 at 6:27 AM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    With the development Mat is currently working on, there will be no need to swap between different octane tunes. I'm not sure what you mean by "learning" but if you are talking about fuel trims and ignition correction, those are kind of required... .
    wahoobie and ihatemytruck like this.
  12. Apr 5, 2019 at 6:52 AM
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    Case in point of why this dude is on my ignore list.
  13. Apr 5, 2019 at 6:57 AM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    OVtune sent me 2 test files for the shutter issue and subsequently told me he would reimburse me for fuel. I flashed the first one and on a cold rainy day I set out, put on some audio books and went for a 200 mile test drive. When I inquired about reimbursement in my review of test file 1 I got radio silence.
  14. Apr 5, 2019 at 7:00 AM
    ihatemytruck
    Dave
    Southern California
    Did the fix work?
  15. Apr 5, 2019 at 7:03 AM
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2024 Tacoma TRD OR (Hybrid)
    ^ This guy has been a pain for months on end. You can hardly say you're "patient" when you write comments like this.
  16. Apr 5, 2019 at 7:03 AM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    He should have sent it to me, no reimbursement needed. And I would have hooked up a 6000 pound trailer to really see if the shutters are gone :mudding:
  17. Apr 5, 2019 at 7:05 AM
    ChickoSM1808
    ChickoSM1808 Well-Known Member
    Michael
    2018 dcsb TRD Sport (OVTuned)
    OVTuned, TRD Pro grille, 32's and many more
    You really wanted reimbursement for fuel. Wow. That's messed up. I would have gladly done it and not expected reimbursement. Not only would I be benefiting from the data but I would be helping everyone else on the forum and bettering our platform. And all for 20 bucks. Seems to be well worth it to me. And not to mention i wouldn't even have my truck still if not for Matt and ovtune
    Fiatdave, ihatemytruck, hr206 and 5 others like this.
  18. Apr 5, 2019 at 7:36 AM
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    You’re a douchebag. Plain and simple.
    Fiatdave, PatricNV, TS7xTaco and 6 others like this.
  19. Apr 5, 2019 at 7:37 AM
    Deucer01
    North Georgia
    I should have ignored him a long time ago, done. Now if folks would stop quoting him. lol
  20. Apr 5, 2019 at 7:42 AM
    OVTune
    OVTune
    I sent you the two files, you tested file 1, said it fixed it, then said you wanted to test file 2 after putting more time on file 1. I haven't heard back since about file 2, even after telling you that you didn't have to test file 2 you said you were going to anyway.
    I offered you the fuel reimbursement for your time. But now it's radio silence? Want to double check your conversation with us?
Thread Status:
